查看: 1160|回复: 2
[原创] ADC histogram testing with ADI and maxim reference (matlab code)
发表于 2024-12-24 11:47:48 | 显示全部楼层 |阅读模式
The histogram test approach helps determine nonlinearity parameters such as differential and integral nonlinearities (INL and DNL) in data converters.
A sinewave is often used as an input to the ADC when making histogram DNL and INL measurements. Sinewaves can be generated with extremely high linearity and low noise with appropriate filtering.
ADI - Data-Conversion-Handbook/Chapter5.pdf
Maxim - histogram testing determines dnl and inl
 楼主| 发表于 2024-12-24 12:02:25 | 显示全部楼层
dnlinl_sin.zip (923 Bytes , 下载次数: 16 )
python code to implement histogram testing method to check DNL/INL
发表于 2024-12-25 09:26:20 | 显示全部楼层
god bless you ,bro
GMT+8, 2025-12-23 17:24 , Processed in 0.023650 second(s), 5 queries , Gzip On, Redis On.
