查看: 1214|回复: 3
[求助] 请问RedHawk有哪些标定功耗的方法?
发表于 2024-11-30 21:45:13 | 显示全部楼层 |阅读模式
如题。若.lib没有功耗信息,但已从其他地方获取到了macro/IP的功耗值。应当如何将其标定进redhawk?
之前尝试过IPF,但需要所有cell的功耗全部写进去才行。BPFS可以吗?
发表于 2024-12-1 09:33:49 | 显示全部楼层
IPF可以,除此之外,也可以用
BLOCK_POWER_FOR_SCALING {
BLOCK MACRO power_in_watts
BLOCK IP power_in_wattes
FULLCHIP top_name power_in_wattes
我记得fullchip的数据要列在最后
当然如果你只标了macro 和ip 的话,full chip 的应该可以不用标
 楼主| 发表于 2024-12-2 21:42:19 | 显示全部楼层
semon_lee 发表于 2024-12-1 09:33
IPF可以,除此之外,也可以用
就是这样标的,但是加了VCD就没法用了,会报BLOCK的toggle rate已经被VCD覆盖
发表于 2024-12-3 09:38:45 | 显示全部楼层
似乎不可以混用,可以看下UG 里CPM 那一章
The configuration keyword, if defined, overrides the same keyword in the GSR. The GSR
keyword is used if the configuration file keyword is not defined, except for
• GSC_FILE
• STATE_PROPAGATION
which are ignored in the GSR if the Config file keyword is not defined.
Note that at present Power Transient Analysis works only in the Vectorless mode, and it
does not support keywords other than the list above. It does not support:
(a) VCD_FILE or BLOCK_VCD_FILE
(b) STA_FILE or BLOCK_STA_FILE
(c) BLOCK_POWER_ASSIGNMENT
(d) PAR or BLOCK_PAR
Also note that simulation uses charge from the first frame for its simulation reference, so
the dynamic simulation result may vary depending on the first frame config setting
GMT+8, 2025-12-16 05:14 , Processed in 0.018324 second(s), 4 queries , Gzip On, Redis On.
