楼主: leaderlau
PSRR怎样直观计算?
头像被屏蔽
发表于 2013-11-22 14:59:21 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-2-18 21:24:11 | 显示全部楼层
PSRR for an standard LDO is simple to derive and understand. For other topologies , one needs to derive the stuff, but intuitively following are true.
1.DC PSRR:Cascoding and increase channel length (take care of not pushing dominant pole inwards with too much output impedance)
2.AC PSRR would depend on the opamp unity gain bandwidth hence being able to push unity gain frequency as much as possible without being unstable is the key.More UGB requires more current to push out non dominant poles outward. Hence as always tradeoff between power dissipation and spec.
发表于 2014-2-22 22:56:20 | 显示全部楼层
回复 22# caxias
楼上的童鞋对Push-Pull的理解好深入啊,赞!我有个疑问是AC PSRR那一段的分析是建立在主极点放在输出端,次级点放在Error Amplifier的输出端这样一种情况下的吗?
发表于 2014-2-24 03:17:57 | 显示全部楼层
Please refer to kamran entesari's ,sanchez sineou paper in IEEE.
发表于 2014-3-1 02:15:49 | 显示全部楼层
pole locations are as Follows: 1.Dominant pole is at the output (for substractor Topology) 2.Pole at the output of the error amplifier is Cancelled using ESR of Capacitor (Ceramic Capacitor) 3.Second non-dominant pole is due to PARASITIC Capacitance at the Pass device, can be pushed out of Unity Frequency to Ensure PhaseMargin> 45 deg. 4.Worst Case Stability condition arises during full load condition (at ILoad = Imax) 5.Consumes More Quiscent Current Because the Subtractor Mirrors some More current.
发表于 2014-3-1 21:52:51 | 显示全部楼层
学习了。
发表于 2015-9-12 18:54:49 | 显示全部楼层
头大了
发表于 2017-9-29 15:14:27 | 显示全部楼层
该往哪个方向去调整就不是很确定
GMT+8, 2025-12-9 14:22 , Processed in 0.014905 second(s), 2 queries , Gzip On, Redis On.
