查看: 991|回复: 1
[求助] LEC形式验证
发表于 2024-11-20 11:32:05 | 显示全部楼层 |阅读模式
LEC检查出现non-equivalent,分析发现是golden merge了两个flops导致的,请问什么命令可以将revised中的对应flops也merge掉呢?试过下边的命令但是会提示找不到net
// Command: analyze nonequivalent 6165
Analyzing non-equivalent compared points:
  (G) + 6165   DFF  /fd_tail_ptr_reg_reg[94]
  (R) + 22895  DFF  /fd_tail_ptr_reg_reg_94_/U$1
  Compared points' data are non-equivalent.
  Following two supports may be merged together:
   (R) 20927 DFF /ctxt_info_fd_len_reg_2__2__rep1/U$1
   (R) 9293 DFF /ctxt_info_fd_len_reg_2__2_/U$1
 楼主| 发表于 2024-11-20 11:35:18 | 显示全部楼层
GMT+8, 2025-12-20 13:11 , Processed in 0.011825 second(s), 3 queries , Gzip On, Redis On.
