查看: 763|回复: 1
[求助] 请教一个xilinx ip的应用
发表于 2024-11-19 19:45:26 | 显示全部楼层 |阅读模式
在做一个XILINX RFSOC 设计 ,利用DAC 播放波形 4G/5G  LTE/NR FDD/TDD信号。
利用xilinx 参考设计里 一个timebase tick IP 生成10ms 触发信号 给外部仪表 做trigger 测试TDD信号。
这个IP 输入只有时钟 491.52M 要产生一个10ms trigger. code 里 利用CPRI_frame 信息。
现在设计里 没有CPRI 接口,实测下来 还是能产生一个接近10ms trigger信号,但不是绝对10ms。这样导致做触发仪表时 不能完美同步。
示波器 测量这个信号 99.99Hz . 10ms应该对应100Hz.
请假下:怎么理解code 里 CPRI_frame 信息?
IP readme
The block provides a fixed system tick onto TUSER. The default RTL
provides 4 ticks running at 10ms on m_axis_tuser[3:0], but can be
altered to provide more complex set of timing references.  Data Output
onto TDATA is always zero.
代码:
--  (C) Copyright 2016 Xilinx, Inc. All rights reserved.
--  This file contains confidential and proprietary information
--  of Xilinx, Inc. and is protected under U.S. and
--  international copyright and other intellectual property
--  laws.
--  DISCLAIMER
--  This disclaimer is not a license and does not grant any
--  rights to the materials distributed herewith. Except as
--  otherwise provided in a valid license issued to you by
--  Xilinx, and to the maximum extent permitted by applicable
--  law: (1) THESE MATERIALS ARE MADE AVAILABLE "AS IS" AND
--  WITH ALL FAULTS, AND XILINX HEREBY DISCLAIMS ALL WARRANTIES
--  AND CONDITIONS, EXPRESS, IMPLIED, OR STATUTORY, INCLUDING
--  BUT NOT LIMITED TO WARRANTIES OF MERCHANTABILITY, NON-
--  INFRINGEMENT, OR FITNESS FOR ANY PARTICULAR PURPOSE; and
--  (2) Xilinx shall not be liable (whether in contract or tort,
--  including negligence, or under any other theory of
--  liability) for any loss or damage of any kind or nature
--  related to, arising under or in connection with these
--  materials, including for any direct, or any indirect,
--  special, incidental, or consequential loss or damage
--  (including loss of data, profits, goodwill, or any type of
--  loss or damage suffered as a result of any action brought
--  by a third party) even if such damage or loss was
--  reasonably foreseeable or Xilinx had been advised of the
--  possibility of the same.
--  CRITICAL APPLICATIONS
--  Xilinx products are not designed or intended to be fail-
--  safe, or for use in any application requiring fail-safe
--  performance, such as life-support or safety devices or
--  systems, Class III medical devices, nuclear facilities,
--  applications related to the deployment of airbags, or any
--  other applications that could lead to death, personal
--  injury, or severe property or environmental damage
--  (individually and collectively, "Critical
--  Applications"). Customer assumes the sole risk and
--  liability of any use of Xilinx products in Critical
--  Applications, subject only to applicable laws and
--  regulations governing limitations on product liability.
--  THIS COPYRIGHT NOTICE AND DISCLAIMER MUST BE RETAINED AS
--  PART OF THIS FILE AT ALL TIMES.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
library work;
use work.dfe_util_pkg.all;
entity dfe_tick is
generic
    C_ANTENNAS               : integer := 1;
    C_DATA_RATE              : integer := 8;
    C_DATA_PHASES            : integer := 1;
    C_TEST_MODE              : integer := 0
port(
  aclk                 : in  std_logic;
  aresetn              : in  std_logic;
  m_axis_dout_tdata                    : out std_logic_vector(C_ANTENNAS*C_DATA_PHASES*32-1 downto 0)    := (others=>'0');
  m_axis_dout_tlast                    : out std_logic := '0';
  m_axis_dout_tuser                    : out std_logic_vector(C_ANTENNAS*8-1 downto 0)                   := (others=>'0');
  m_axis_dout_tvalid                   : out std_logic := '0';
  m_axis_dout_tready                   :  in std_logic := '1'
end dfe_tick;
architecture rtl of dfe_tick is
  constant C_SAMPLES_PER_TC                : integer := 8*C_DATA_RATE/C_DATA_PHASES;
  constant C_CPRI_TC_PER_HF                : integer := iff(C_TEST_MODE>0, 256/16, 256);
  constant C_CPRI_HF_PER_FRM               : integer := iff(C_TEST_MODE>0, 150/5,  150);
  constant C_CPRI_N_BFN                    : integer := iff(C_TEST_MODE>0, 4096/1024, 4096);
  -- Ticks
  signal tick_restart : std_logic := '0';
  -- Frame Reset
  -- Aligned Reset : releases counters
  signal frame_reset    : std_logic := '0';
  -- TC (Chip) Tick Generations
  signal tc_tick           : std_logic := '0';
  signal tc_tick_pre       : std_logic := '0';
  signal tc_sample_count   : std_logic_vector(7 downto 0) := (others => '0');
  signal tc_load_count     : std_logic_vector(7 downto 0) := (others => '0');
  -- CPRI Counters
  signal cpri_tc_count     : std_logic_vector(7 downto 0) := (others => '0');
  signal cpri_tc_max       : std_logic := '0';
  signal cpri_hf_last      : std_logic := '0';
  signal cpri_hf_count     : std_logic_vector(7 downto 0) := (others => '0');
  signal cpri_hf_max       : std_logic := '0';
  signal cpri_fr_last      : std_logic := '0';
  signal cpri_fr_count     : std_logic_vector(11 downto 0) := (others => '0');
  signal cpri_fr_max       : std_logic := '0';
  -- Node-B Frame Number (BFN) load control
  signal bfn_load_tvalid : std_logic := '0';
  signal bfn_load_tdata  : std_logic_vector(11 downto 0) := (others=>'0');
begin
  -- Frame reset
  -- reset counters when not in_sync or immediately after sync_in_restart
  frame_reset  <= '1' when aresetn='0' else '0';
  tick_restart <= frame_reset;
  -- Tc (Chip) Tick
  -- This provides basic tick for counting chips Tc in the design
  -- Corresponds to Basic Frame in CPRI.
  -- Clock Rates :   30.72 MHz =   8 x Tc
  --                245.76 MHz =  64 x Tc
  --                491.52 MHz = 128 x Tc
  tc_load_count <= std_logic_vector(to_unsigned(C_SAMPLES_PER_TC-1,tc_load_count'length));
  i_tc_tick: entity work.dfe_time_tick
    generic map (
        C_COUNT_WIDTH => tc_sample_count'length)
    port map (
        clk        => aclk,
        enable     => '1',
        load_count => tc_load_count,
        tick_reset => frame_reset,
        tick       => tc_tick,
        tick_pre   => tc_tick_pre,
        tick_count => tc_sample_count);
  -- CPRI TC Counter
  -- Counts TCs in a CPRI Hyperframe
  i_cpri_tc_count: entity work.dfe_time_counter
    generic map (
        C_COUNT_WIDTH => cpri_tc_count'length,
        C_COUNT0      => C_CPRI_TC_PER_HF,
        C_SUBCOUNTS   => 0)
    port map (
        clk           => aclk,
        enable        => '1',
        tick_base     => tc_tick,
        tick_base_pre => tc_tick_pre,
        tick_frame    => frame_reset,
        max_in        => "1",
        count         => cpri_tc_count,
        max_out       => cpri_tc_max,
        last          => cpri_hf_last);
  -- CPRI Hyperframe Counter
  -- Counts Hyperframes in a CPRI Frame
  i_cpri_hf_count: entity work.dfe_time_counter
    generic map (
        C_COUNT_WIDTH => cpri_hf_count'length,
        C_COUNT0      => C_CPRI_HF_PER_FRM,
        C_SUBCOUNTS   => 1,
        C_MAX_IN_WIDTH => 1)
    port map (
        clk           => aclk,
        enable        => '1',
        max_in(0)     => cpri_tc_max,
        count         => cpri_hf_count,
        max_out       => cpri_hf_max,
        last          => cpri_fr_last);
  -- Node-B frame number load control signals
  -- in slave  mode copy BFN on input to this count
  -- in master mode, do not load this value
  bfn_load_tvalid <= '0';
  bfn_load_tdata  <= (others=>'0');
  -- CPRI Frame Counter
  -- Counts CPRI Frames to generate NodeB Frame Number
  i_cpri_fr_count: entity work.dfe_time_counter
    generic map (
        C_COUNT_WIDTH => cpri_fr_count'length,
        C_COUNT0      => C_CPRI_N_BFN,
        C_SUBCOUNTS   => 2,
        C_MAX_IN_WIDTH => 2)
    port map (
        clk           => aclk,
        enable        => '1',
        tick_frame    => tick_restart,
        load_tvalid   => bfn_load_tvalid,
        load_tdata    => bfn_load_tdata,
        max_in(1)     => cpri_hf_max,
        count         => cpri_fr_count,
        max_out       => cpri_fr_max,
        last          => open);
  -- TLAST/TUSER Output Options
  -- TVALID Output
  m_axis_dout_tvalid             <= '1';
  -- TDATA Output
  m_axis_dout_tdata              <= (others=>'0');
  -- TLAST Output
  m_axis_dout_tlast              <= cpri_hf_last;
  -- TUSER Output
  p_tuser: process (cpri_fr_last)
  begin
    for i in 0 to C_ANTENNAS-1 loop
      -- TUSER is one-byte per antenna
      -- allocation of bits in each byte are:
      -- bits  7:5: not used
      -- bit     4: TDD Enable
      -- bit     3: Restart Marker / Capture Sync
      -- bit     2: Alternate Frame Marker (e.g. use for GSM framing if  required)
      -- bit     1: Frame Marker
      -- bit     0: Slot Marker
      m_axis_dout_tuser(i*8+7 downto i*8)  <= "0000" & cpri_fr_last & cpri_fr_last & cpri_fr_last & cpri_fr_last;
    end loop;
  end process p_tuser;
end rtl;
发表于 2024-11-20 10:16:24 | 显示全部楼层
时钟同源了么 没有的话弄个参考时钟同源下试试
GMT+8, 2025-12-18 01:24 , Processed in 0.011482 second(s), 3 queries , Gzip On, Redis On.
