查看: 1491|回复: 8
[原创] 数字后端icc
发表于 2024-11-13 14:59:54 | 显示全部楼层 |阅读模式
icc的时候需要map文件,这种格式的map文件怎么得到的呀
发表于 2024-11-13 18:05:11 | 显示全部楼层
There are diffrent typs of mapping files are there eg. gds2out and gds2in, If you are going to export GDS from ICC then you have to use gds2out mapping file
发表于 2024-11-13 18:07:00 | 显示全部楼层
There are two different types of mapping file are avaiable eg. gds2out and gds2in. If you are going to export gds file from ICC then you need to provide gds2out mapping file
发表于 2024-11-13 18:08:13 | 显示全部楼层
There are different types of mapping files are available eg. gds2out and gds2in. If you are going to export gds file from ICC then you have to use gds2out
发表于 2024-11-13 18:09:12 | 显示全部楼层
发表于 2024-11-13 18:10:03 | 显示全部楼层
发表于 2024-11-13 18:11:22 | 显示全部楼层
 楼主| 发表于 2024-11-13 20:10:36 | 显示全部楼层
sumit_enggr 发表于 2024-11-13 18:09
There are different types of mapping files are available eg. gds2out and gds2in. If you are going to ...
那MAP文件从哪生成的呀
发表于 2024-11-14 12:32:08 | 显示全部楼层
zhongjx23 发表于 2024-11-13 20:10
那MAP文件从哪生成的呀
This will be provided by Foundry
GMT+8, 2025-12-28 06:31 , Processed in 0.044232 second(s), 4 queries , Gzip On, Redis On.
