查看: 838|回复: 2
[求助] 请教国内外120V BCD工艺的差距在哪里?
发表于 2024-11-7 22:51:22 | 显示全部楼层 |阅读模式
比如GF,东部,国内的HHNEC,unt,SMIC?谢谢
发表于 2024-11-8 07:13:35 | 显示全部楼层
my friend use vis 200v process use ldmos  ok .
and porting HHNEC grace 200v process . find  hhnec  fail on HTOL ( breakdown ? burn out )
and some 500v~600v ldmos process
with other , "charge in wafer"  cause CP test fail ,
and next wafer , Fab fix this problem
for UHV process
vis   maybe you can use .
发表于 2024-11-8 07:53:10 | 显示全部楼层
Different mask layers needed
GMT+8, 2025-10-14 05:36 , Processed in 0.013393 second(s), 5 queries , Gzip On, Redis On.
