查看: 1654|回复: 11
Virtuoso and Spectre slow to start when VM is connected to the internet
发表于 2024-11-1 04:37:04 | 显示全部楼层 |阅读模式
Greetings everyone,
as stated in the title, I have Cadence Virtuoso & Spectre installed in a RHEL9 VM. Both are version IC6.18 and are activated with tools found in the forums here.
A small issue I am dealing with is that when the VM is connected to the internet (as in the network adapter is connected to the VM), it takes a good 10-15 seconds to start Virtuoso and for Spectre to start simulations. As soon as I deactive the network adapter, everything works perfectly.
Has anyone faced this problem? Are there any solutions?
发表于 2024-11-1 08:20:07 | 显示全部楼层
Try it.
/etc/hosts
127.0.0.1       srv1.updates.synopsys.com
127.0.0.1       srv2.updates.synopsys.com
127.0.0.1       srv1.sw.synopsys.com
127.0.0.1       srv2.sw.synopsys.com
127.0.0.1       srv3.sw.synopsys.com
发表于 2024-11-1 08:55:06 | 显示全部楼层
vitohong 发表于 2024-11-1 08:20
Try it.
/etc/hosts
大哥,你走女厕所了。
发表于 2024-11-1 08:58:53 来自手机 | 显示全部楼层
哈哈哈哈哈哈
发表于 2024-11-1 09:26:07 | 显示全部楼层
把虚拟机的网卡断开不就好了。
发表于 2024-11-1 15:31:29 | 显示全部楼层
check the hostname of your VM。
i guess you are using the default localhost.localdomain
when connected to the internet, it might be automatically changed to sth. else. thus makes it slow....
 楼主| 发表于 2024-11-1 17:53:32 | 显示全部楼层
powertoy posted on 2024-11-1 09:26
Just disconnect the network card of the virtual machine.
That is the solution I am currently using, but I'd like to move the VM to an actual OS installation to remotely connect to. So internet access is required. Thus the question.
lonelycat posted on 2024-11-1 15:31
check the hostname of your VM.
when connect ...
I have changed the default hostname, as it interfered with the license acquisition of some Synopsys tools (or something like that). Running hostname returns the hostname I have set, not localhost.localdomain.
发表于 2024-11-1 17:58:32 | 显示全部楼层
很简单。。。因为你未把主机名写入host中。。。
 楼主| 发表于 2024-11-1 18:03:31 | 显示全部楼层
That fixed it. Thanks a lot!
发表于 2024-11-2 12:05:05 | 显示全部楼层
most welcome bro
GMT+8, 2025-10-21 20:20 , Processed in 0.015742 second(s), 3 queries , Gzip On, Redis On.
