查看: 960|回复: 1
[讨论] 5v mos design current能小到多小啊?
发表于 2024-10-30 20:20:04 | 显示全部楼层 |阅读模式
a. 5v mos design current能小到多小啊?
1. Low power opa .  Bias current use 1na , 0.5na  mos  current  miiror 可以吗?
2. Low power osc ,  1Khz osc , 0.5na 充电容做 很低频 r-c osc , 用比较器比电压
3. Low current bandgap .  有没 10na   下能工作 bandgap vbg=1.1v
vdd = 1.8~ 5v
b.  1.8v lv mos design
0.1 na  mos  current  miiror 可以吗?
bulk cmos process 0.18um , no SOI process
A Novel Ultra Low Power High Performance Atto-Ampere CMOS Current Mirror with Enhanced Bandwidthnovel CMOS atto-ampere current mirror (AACM) is proposed which reaches the minimum yet reported current range of 0.4 aA
A 28 ppm/°C, 2.54 ppm/V, −77 dB@100 Hz pico-ampere voltage reference for high-end IoT systems
Picowatt 0.3-V MOS-only voltage reference based on a picoamp cascode current generator
alog2004 Current Mode Techniques for Sub-pico-Ampere.pdf (407.1 KB , 下载次数: 7 )
Pico-current Measurement Challenges .pdf (794.5 KB , 下载次数: 6 )
https://bbs.eetop.cn/forum.php?mod=viewthread&tid=614437
https://bbs.eetop.cn/thread-850890-1-1.html
 楼主| 发表于 2024-11-2 09:06:19 | 显示全部楼层
有没有人做过 10na circuit  ?
0.5um 5v cmos process
0.18um 1.8v  process
另外 漏电问题要哪类 process 下会出现?  90nm  65nm ?
GMT+8, 2025-11-3 05:28 , Processed in 0.017466 second(s), 4 queries , Gzip On, Redis On.
