楼主: trashio
SynopsysMonoSlayer v24.09 request
发表于 2024-11-5 20:22:48 | 显示全部楼层
joshua2784920 发表于 2024-11-4 16:58
I attempted to fetch the application program using SynopsysMonoSlayer, pubkey_verify, and synop ...
Do you mean the vcs 2024.09 worked well with the new SynopsysMonoSlayer?
But in my test , the urg can not use,and report the license cannot be checkout, and I am sure the licnese feature is in my license file. There are no errors in the license log.
Error - [URG-NLC] No license keys
   URG failed to get a license key.
   Please check for VCSTools_Net or VT_CoverageURG key in your license file.
发表于 2024-11-5 21:48:14 | 显示全部楼层
joshua2784920 发表于 2024-11-5 14:34
No...
I have test using legal license with no bin patch  on RHEL9.4 system.
So how to get the simulation result? Hmmmmmm
发表于 2024-11-6 10:47:38 | 显示全部楼层
TerraWilly 发表于 2024-11-5 16:32
So, now you can throw your HSPICE or SynopsysMonoSlayer to trash.
The purpose of using patches like SynopsysMonoSlayer is due to the number of license copies.
Don't you think it's disrespectful to say that something can just be thrown in the trash? You requested error cases, but this lack of seriousness makes it hard to trust your output.
If you were going to respond so rudely, why did you even ask for fail cases?
发表于 2024-11-6 12:20:49 | 显示全部楼层
Forget it, dude. I respect your serious attitude, especially as an engineer. Arrogance and rudeness is in someone's nature.
发表于 2024-11-6 12:29:29 | 显示全部楼层
But i tell you how to patch and method, why do you think i don't test the software?
IF YOU USE SynopsysMonoSlayer V24.09 get error besides my test software, i am willing to help you solve this.
发表于 2024-11-6 13:15:51 | 显示全部楼层
But in my test , the urg ...
There are two versions of SynopsysMonoSlayer available. However, the version label is the same:
Synopsys Universal License Patcher v1.1 Build0410 (TeamEFA)
[v1.1] Update large file support
When comparing the patched file results from these two versions, they differ, indicating that while the version label is the same, they are actually different versions.
However, the patch is incomplete in the 2024 version, making it ineffective.
发表于 2024-11-6 14:49:58 | 显示全部楼层
joshua2784920 发表于 2024-11-6 13:15
Regarding HSPICE version 2024.09, VCS and DC were briefly mentioned since they were not the mai ...
Thanks very much , great appreciate!!!
Could you tell us how to do this :
- 7. scl_lc_checkout : Success without any issue
        Note-[URG-RDG] Report directory generated
        Report written to directory report_directory
- 8. scl_lc_checkout and l_pubkey_verify : Same as scl_lc_checkout
发表于 2024-11-7 16:24:23 | 显示全部楼层
Thanks for sharing
发表于 2024-11-7 16:33:01 | 显示全部楼层
You can use 24.09 version patch your software
发表于 2024-11-7 19:33:02 | 显示全部楼层
Please look at yslen01's post.
https://bbs.eetop.cn/thread-977527-1-1.html
He mentions that crashes occur in VCS 2023.12."
Below, yslen01 mentions another issue in VCS2024.09 and VCS2023.12.
The stack error is caused by an incorrect fetch. Try running 'urg' in VCS 2024.09.
An error occurs in HSPICE 2024.09.
You should throw SynopsysMonoSlayer away as trash.
GMT+8, 2025-10-16 02:10 , Processed in 0.019370 second(s), 4 queries , Gzip On, Redis On.
