查看: 8130|回复: 32
urg crash的问题
发表于 2024-10-15 10:23:09 | 显示全部楼层 |阅读模式
不知道有没有人在用2023.12之后版本的vcs,还是用原来的pubkey,checksum方法patch,编译仿真可以过。
但是urg就会crash。
目前有没有好的解决方案?
--- Stack trace follows:
[New LWP 53986]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
0x00002ac69e28e85d in nanosleep () from /lib64/libc.so.6
Thread 2 (Thread 0x2ac6a701d700 (LWP 53986) "urg1"):
#0  0x00002ac69e28e4b9 in waitpid () from /lib64/libc.so.6
#1  0x00002ac69e20bf62 in do_system () from /lib64/libc.so.6
#2  0x00002ac69e20c311 in system () from /lib64/libc.so.6
#3  0x00002ac69c1c5960 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313e639d2928478c79b3f673f99203bcf8be64600612100082236bffb2007f1e0ef9 () from /vcs/2023.12-SP2-1/linux64/lib/liberrorinf.so
#4  0x00002ac69c1c5f70 in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313e81c34e9ac4c8988ef4a6e067b3aa9271e9f15440f9e8f69e71727f1bc8d6ddca () from /vcs/2023.12-SP2-1/linux64/lib/liberrorinf.so
#5  0x00002ac69c1c75aa in SNPSle_10ee25eff68cd8461c9146fa1d0b35e87067f3c8015b313efba706aab251478fa49e66610e453774633a6c152e7ef778f93045171fb3645d () from /vcs/2023.12-SP2-1/linux64/lib/liberrorinf.so
#6  0x00002ac69c1bf653 in SNPSle_d35ca1ff70d465c2b9b1a72eee90a50630165806651fae96c1bbda5b5d02066c () from /vcs/2023.12-SP2-1/linux64/lib/liberrorinf.so
#7  0x00002ac69c1c5019 in SNPSle_a616a49d50c972830e5a9fc3c8e619d38b78b0950f1d2e37 () from /vcs/2023.12-SP2-1/linux64/lib/liberrorinf.so
#8  0x0000000000e12c7f in ?? ()
#9  <signal handler called>
#10 0x00002ac69b617e40 in mem_free () from /vcs/2023.12-SP2-1/linux64/lib/libsnpsmalloc.so
#11 0x00002ac69b5fb232 in snpsCheckFreeFunc () from /vcs/2023.12-SP2-1/linux64/lib/libsnpsmalloc.so
#12 0x00002ac69cd8b1c4 in nsuiyrEXedkj () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#13 0x00002ac69cd8b482 in ORLpwunmedkj () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#14 0x00002ac69cfd764e in AHUdosQCedkj () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#15 0x00002ac69cd9bda4 in OqstaxhJedkj () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#16 0x00002ac69cd9ccd6 in OXYaDhzwedkj () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#17 0x00002ac69cd9d1af in HuAYwfdeedkj () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#18 0x00002ac69b7d5ea5 in start_thread () from /lib64/libpthread.so.0
#19 0x00002ac69e2c796d in clone () from /lib64/libc.so.6
Thread 1 (Thread 0x2ac69b6e5840 (LWP 51529) "urg1"):
#0  0x00002ac69e28e85d in nanosleep () from /lib64/libc.so.6
#1  0x00002ac69e28e6f4 in sleep () from /lib64/libc.so.6
#2  0x00002ac69cd45786 in IUet3h7dnSwDnmt () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#3  0x00002ac69cd4592d in nAR8tWqFNRONMEo () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#4  0x00002ac69cd434a7 in pizBhiy39Ywj9j () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#5  0x00002ac69cd43858 in Vi9wVDbIr1poz5K () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#6  0x00002ac69cd29c1a in y7DnVwpsraOlYFx () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#7  0x00002ac69cd29f3f in q4B4ASScVBC3CiY () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#8  0x00002ac69cd2cf8b in LZLo3lgWvbv8 () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#9  0x00002ac69cd23c23 in c6obzhUAjviQHlJ () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#10 0x00002ac69cd245ff in S6d9TcUheexaJHD () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#11 0x00002ac69cd25295 in scl_lc_checkout () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#12 0x00002ac69cd163a2 in vcs_checkout () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#13 0x00002ac69cb6c486 in covdb_get_license_internal() [clone .part.0] () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#14 0x00002ac69cb6ca95 in covdb_get_license () from /vcs/2023.12-SP2-1/linux64/lib/libucapi.so
#15 0x00000000006160da in main ()
[Inferior 1 (process 51529) detached]
Process VmPeak: 345464 kb, VmSize: 312700 kb
System Free Memory: 32400292 kb, System Free Swap: 42937440 kb
发表于 2024-10-15 14:11:18 | 显示全部楼层
same question here
发表于 2024-10-15 20:44:08 | 显示全部楼层
换破解工具
发表于 2024-10-15 20:49:19 | 显示全部楼层
I use "vcs/V-2023.12-SP2" , there is no issue.
发表于 2024-10-16 11:30:43 | 显示全部楼层
krman33 发表于 2024-10-15 20:44
换破解工具
可以给个指引吗?换哪个工具可以用?多谢了!
发表于 2024-10-16 11:32:08 | 显示全部楼层
是用的原来的pubkey,checksum的方法patch吗?
 楼主| 发表于 2024-10-16 11:43:04 | 显示全部楼层
换破解工具
可以分享下吗?感谢
发表于 2024-10-16 15:52:11 | 显示全部楼层
pubkey_verify,  checksum, pubkey_verify_java has beend used.
It was distiributed by "pubkey_v1.6.tar.gz" .
However, it seems v1.4 version.
pubkey_verify -v
Generic ECC patcher by tanker, v1.4, 2020-04
Type -h for more help..
pubkey_checksum -v
Generic synopsys file checksum patcher & string extractor by tanker, v1.6, 2020-05
pubkey_verify_java -v
Generic ECC patcher(Java) by tanker, v1.2, 2020-05
 楼主| 发表于 2024-10-16 16:10:29 | 显示全部楼层
It was distiributed by "pubkey_v1.6. ...
The same usage,but still got the crash error.
不知道该怎么尝试了,大佬方便分享下您的license file我测试下吗?感谢!
 楼主| 发表于 2024-10-16 16:13:13 | 显示全部楼层
我是在用urg的时候报错。
比如urg -dir simv1.vdb -full64。
您那边可以过吗?
GMT+8, 2025-12-25 12:00 , Processed in 0.023220 second(s), 3 queries , Gzip On, Redis On.
