楼主: trashio
SynopsysMonoSlayer v24.09 request
发表于 2024-11-4 15:49:14 | 显示全部楼层
谁能解决verdi不能用TransactionDebugMode,总是报Preference未响应。无法调试uvm代码。
发表于 2024-11-4 16:58:08 | 显示全部楼层
The stack error is caused by an incorrect fetch.Try running 'urg' in VCS 2024.09.An error occurs in HSPICE 2024.09.
发表于 2024-11-5 08:11:40 | 显示全部楼层
joshua2784920 发表于 2024-11-4 16:58
I attempted to fetch the application program using SynopsysMonoSlayer, pubkey_verify, and synop ...
HI Joshua,
So can you share your HSPICE crash case ? Do you try simulation your netlist on windows?
Maybe you can try patch again, DO NOT USE other tools patch your HSPICE binary files.
发表于 2024-11-5 11:36:58 | 显示全部楼层
发表于 2024-11-5 12:23:21 | 显示全部楼层
joshua2784920 发表于 2024-11-5 11:36
Hi,
I am using  HSPCIE 24.09 version on RHEL 9.4
Hi Joshua,
I don't need HSPICE 2024.09, If you get crash info when simulation finished. Can you view the simulation result from WaveView?
I suggest you use case1 to patch HSPICE program.
发表于 2024-11-5 12:29:10 | 显示全部楼层
Hi,
Can you share the crash message , If you use RHEL9, Maybe cause program stack error.
When i release 24.09 version, test many software on CentOS8, So you can change you system version and try again.
IF YOU CAN GET CORRECT RESULT ABOUT SIMULATION, YOU NEED KNOW THE PATCHER IS WORKING.
发表于 2024-11-5 12:58:49 | 显示全部楼层
When i releas ...
file:///F:/TMP/hspice24.09/patch.jpg
file:///F:/TMP/hspice24.09/run_error_issue.jpg
发表于 2024-11-5 13:36:20 | 显示全部楼层
joshua2784920 发表于 2024-11-5 12:58
链接: https://pan.baidu.com/s/1mVjUYd-1R79d4Vz00ymGZw?pwd=e36q 提取码: e36q 复制这段内容后打开 ...
I suggest you replace your system version to REHL8
发表于 2024-11-5 14:34:20 | 显示全部楼层
No...
I have test using legal license with no bin patch  on RHEL9.4 system.
This test is also to use my server same as Bin patch case.
There is  no issue.
It seems you haven't tested the HSPICE 2024.09 version.
If you have, please show the results as I did.
发表于 2024-11-5 16:32:26 | 显示全部楼层
joshua2784920 发表于 2024-11-5 14:34
No...
So, now you can throw your HSPICE or SynopsysMonoSlayer to trash.
GMT+8, 2025-10-15 23:46 , Processed in 0.018171 second(s), 3 queries , Gzip On, Redis On.
