查看: 1174|回复: 6
[原创] schReplaceLabels
发表于 2024-10-23 19:59:00 | 显示全部楼层 |阅读模式
sch中搜索替换labels
Function YschChangeLabel()
procedure(YschChangeLabel()
        let((labelText newLabelText obj)
                labelText = hiCreateStringField(
                        ?name 'labelText
                        ?prompt "Search labels:"
                        ?value ""
                newLabelText = hiCreateStringField(
                        ?name 'newLabelText
                        ?prompt "Replace to:"
                        ?value ""
                YschChangeLabelForm = hiCreateAppForm(
                        ?name 'YschChangeLabelForm
                        ?formTitle "Replace labels text form"
                        ?fields list(
                                list(labelText 0:0 400:30 100)
                                list(newLabelText 0:50 400:30 100)
                        ?buttonLayout 'OKCancelApply
                        ?callback "YschChangeLabelCB(hiGetCurrentForm())"
                        ?minSize 420:100
                when(geGetSelSet() && css()->objType=="label"
                        YschChangeLabelForm->labelText->value = css()->theLabel
                hiDisplayForm('YschChangeLabelForm)
        t
procedure(YschChangeLabelCB(form @optional cv(geGetEditCellView()) "rd")
        prog((labelText newLabelText)
                unless(form
                        warn("Can not get form database id - %A" form)
                        return()
                when(form
                        labelText = form->labelText->value
                        newLabelText = form->newLabelText->value
                        YschChangeLabelMain(labelText newLabelText)
        return(t)
procedure(YschChangeLabelMain(labelText newLabelText @optional cv(geGetEditCellView()) "ttd")
        prog((objList)
                when(artBlankString(labelText) || artBlankString(newLabelText)
                        warn("The argument#1 and argument#2 can not be nil or blank string - %A, %A\n" labelText newLabelText)
                        return()
                unless(cv&&cv->mode!="r"
                        warn("Can not get cellView id or current cellView is readable\n")
                        return()
                if(geGetSelSet() then
                        objList = geGetSelSet()
                        else
                        objList = cv->shapes
                        warn("Not selected any objects in current cellView - %A, then search for all labels in current cellView\n" geGetSelSet())
                objList = setof(x objList x->objType=="label")
                unless(objList
                        warn("Can not get any labels in current cellview - %A\n" objList)
                        return()
                objList = setof(x objList x->theLabel==labelText)
                unless(objList
                        warn("There is not any labels - %A named - %A" objList labelText)
                        return()
                foreach(obj objList
                        obj->theLabel = newLabelText
        return(t)
发表于 2024-10-24 09:04:13 | 显示全部楼层
赞一个。你这个不局限与sch呀。
 楼主| 发表于 2024-10-24 09:15:04 | 显示全部楼层
acrofoxAgain 发表于 2024-10-24 09:04
赞一个。你这个不局限与sch呀。
是的,本意是在sch中使用,layout可以使用原有的search功能
发表于 2024-10-24 09:58:30 | 显示全部楼层
原理图也可以用本来的Find/Replace功能吧?
 楼主| 发表于 2024-10-24 10:42:34 | 显示全部楼层
Find好像不能找label,可能是我没用对吧
发表于 2024-10-24 11:01:22 | 显示全部楼层
Find里选Other,然后填theLabel
 楼主| 发表于 2024-10-24 13:33:00 | 显示全部楼层
好的,感谢,那后面再加一个如果label是Pin Name,加一个顺便改Pin textDisplay
GMT+8, 2025-10-26 03:54 , Processed in 0.020386 second(s), 3 queries , Gzip On, Redis On.
