查看: 1326|回复: 4
[原创] 求助!求助!place_opt
发表于 2024-10-22 15:15:32 | 显示全部楼层 |阅读模式
设置了 set_separate_process_options -placement false,还是出错。
  check_physical_constraints 命令,看到cap 和 res不为0 呢?
  谢谢大神指点!
发表于 2024-10-24 13:43:59 | 显示全部楼层
缺少scan def信息?
发表于 2024-10-27 12:16:41 | 显示全部楼层
Tool is asking to provide scandef file, if you want to continue your placement without scandef you have to set app option, continue on missing scandef
 楼主| 发表于 2024-10-30 10:56:55 | 显示全部楼层
hxy2018 发表于 2024-10-24 13:43
缺少scan def信息?
谢谢! 发现是我的layer map写的有问题
 楼主| 发表于 2024-10-30 10:58:04 | 显示全部楼层
sumit_enggr 发表于 2024-10-27 12:16
Tool is asking to provide scandef file, if you want to continue your placement without scandef you h ...
GMT+8, 2025-12-5 13:12 , Processed in 0.035261 second(s), 4 queries , Gzip On, Redis On.
