查看: 1312|回复: 1
求大佬,求大佬,求助使用ADE XL时,报错SQL pragma导致结果一直pending.
发表于 2024-10-12 22:05:10 | 显示全部楼层 |阅读模式
悬赏10资产未解决
报错信息如下:
ERROR (ADEXL-2220): While initializing the results database, the SQL pragma "legacy_file_format" with value "ON" could not be applied onto the results database engine
Return value is: ""
The results database uses SQL statements internally.
ADE XL will continue to function but will operate slower than expected.
Contact Cadence Customer Support to report the problem.
发表于 2025-9-9 09:41:30 | 显示全部楼层
cd cadence/installs/IC618/tools.lnx86/lib/64bit
ln -s libsqlite3_sh.so libsqlite3.so.0
This forces virtuoso to use its own (old) sqlite library, which solves the problem.
GMT+8, 2025-12-28 18:08 , Processed in 0.014443 second(s), 5 queries , Gzip On, Redis On.
