查看: 4431|回复: 1
about encounter reading the lef file?
发表于 2008-2-26 10:48:13 | 显示全部楼层 |阅读模式
我再做encounter时遇到两个问题,请教一下各位高手,谢谢!
首先我再读lef文件时,我先读tech 库,再读antenna库
遇到:
WARN: (SOCLF-58): cell 'FILL8' has been found in DB so only antenna data will be load.Any other data will be skipped.
WARN: (SOCLF-200):Pin 'Y' in macro "TBUFX12" has no ANTENNAGATEAREA attribute defined.
对第一个问题,在tech库里对器件定义了物理特性,在antenna库里定义了port的天线特性,不知道为什么会报这个问题?
第二个问题,就更不理解了,一个器件的输出端口还用定义天线吗?
不理解?
请教各位了?
发表于 2009-2-28 17:15:11 | 显示全部楼层
the first warning  you can ignore completely!
GMT+8, 2025-12-29 09:47 , Processed in 0.018047 second(s), 6 queries , Gzip On, Redis On.
