查看: 1273|回复: 6
Starrc ERROR Host ** supports both IPv4 and IPv6 internet protocol addressing.
发表于 2024-9-30 16:30:12 | 显示全部楼层 |阅读模式
                                  StarRC (TM)
               Version R-2020.09-SP5 for linux64 - Apr 13, 2021
                    Copyright (c) 1999 - 2021 Synopsys, Inc.
   This software and the associated documentation are proprietary to Synopsys,
Inc. This software may only be used in accordance with the terms and conditions
of a written license agreement with Synopsys, Inc. All other use, reproduction,
            or distribution of this software is strictly prohibited.
ExecName: */starrc2020.09-SP5/linux64_starrc/bin/StarXtract
Version: R-2020.09-SP5
Built on: Apr 13 2021 19:43:42
Start Time: Mon Sep 30 01:27:49 2024
Host ............**
ERROR: Host ** supports both IPv4 and IPv6 internet protocol addressing. Use the ENABLE_IPV6
       option to specify the addressing mode to be used by StarRC for distributed processing. (SX-3684)
发表于 2024-9-30 17:13:09 | 显示全部楼层
这个错误很明显啊, 去manual上找一下ENABLE_IPV6的设定
 楼主| 发表于 2024-9-30 17:23:16 | 显示全部楼层
请问这条Command要怎么加到脚本里面呢
 楼主| 发表于 2024-9-30 17:25:35 | 显示全部楼层
解决了,感谢
发表于 2024-12-11 17:12:39 | 显示全部楼层
zhengluemeng 发表于 2024-9-30 17:25
解决了,感谢
请问一下是如何解决的!
 楼主| 发表于 2024-12-12 21:34:33 | 显示全部楼层
飞机场的十点半 发表于 2024-12-11 17:12
请问一下是如何解决的!
在starrc运行脚本里加上ENABLE_IPV6就好
发表于 2024-12-13 09:56:04 | 显示全部楼层
好的感谢!
GMT+8, 2025-12-26 02:45 , Processed in 0.015513 second(s), 3 queries , Gzip On, Redis On.
