楼主: xcq838587
hspice2024.09不能跑demo,license启动正常
发表于 2024-9-28 07:50:22 | 显示全部楼层
myedacn 发表于 2024-9-27 13:26
waveview有吗,一起发一下,谢谢
通过百度网盘分享的文件:wv_adv_vW-2024.09
链接:https://pan.baidu.com/s/1ipWlzYoGjHupcSmSfReJFw?pwd=5jm2
提取码:5jm2
发表于 2024-9-28 08:13:33 | 显示全部楼层
链接:https://pan.baidu.com/s/1ipWlzYoGjHupcSmSfReJFw?pw ...
感谢
发表于 2024-9-28 09:23:49 | 显示全部楼层
thanks!!!!!!!!
发表于 2024-9-28 10:55:03 | 显示全部楼层
myedacn 发表于 2024-9-27 20:09
用这个license server试试:
https://bbs.eetop.cn/thread-971025-1-1.html
感谢分享
发表于 2024-9-28 11:05:33 | 显示全部楼层
感谢分享
发表于 2024-9-29 09:01:14 | 显示全部楼层
l-i-c搞不定h5pice
求V-2013.12(-SP3),还有没有cust -compiler
发表于 2024-9-29 09:16:52 | 显示全部楼层
有没有好心人有 S家 icvalidator 和 laker 2021以上
 楼主| 发表于 2024-9-29 20:18:06 | 显示全部楼层
scl2024.06启动license也不行的。还是没有找到方法,有人有方法吗?共享下
发表于 2024-9-29 20:56:08 | 显示全部楼层
老大,搞不定了。
烦请V-2013.12(-SP3
发表于 2024-9-30 11:57:43 | 显示全部楼层
链接: https://pan.baidu.com/s/1LXcrqy_0Eg8UPMazNWhI_Q 提取码: bg63
It seems that you are using the wrong method to run the license service.
In order to run this version, the system OS needs to be upgraded to a REDHAT 8.x or 9.x kernel. Although I haven't been able to test it yet, it seems that the patched version, created with the help of a brilliant individual, operates as described below.
/home/tools/hspice/W-2024.09/hspice/demo/hspice/apps]$ hspice -i noise_app.sp
****** PrimeSim HSPICE -- W-2024.09 linux64 (Aug 27 2024 9174816) ******
  Copyright (c) 1986 - 2024 by Synopsys, Inc. All Rights Reserved.
  This software and the associated documentation are proprietary
  to Synopsys, Inc. This software may only be used in accordance
  with the terms and conditions of a written license agreement with
  Synopsys, Inc. All other use, reproduction, or distribution of
  this software is strictly prohibited.
  Input File: noise_app.sp
  Command line options: /home/tools/hspice/W-2024.09/hspice/linux64/hspice -i noise_app.sp
  Start time: Wed Sep 25 02:50:36 2024
lic:
lic: FLEXlm: SDK_14.2
lic: USER:   eda                  HOSTNAME: rocky
lic: HOSTID: ffffffffa8c09703     PID:      562067
scientific notation:
a=10**-18  f=10**-15  p=10**-12  n=10**-9  u=10**-6
m=10**-3   k=10**3    x=10**6    g=10**9
circuit parameter definitions
  parameter          =  value
constants  - tnom         kt           vt           gapsi        ni
            298.15000    4.1163e-21    25.69184m     1.11562    1.2565e+16
1****** PrimeSim HSPICE -- W-2024.09 linux64 (Aug 27 2024 9174816) ******
* a common source nmos amplifier
****** mos   model parameters tnom=  25.000 temp=  25.000 ******
Model file: noise_app.sp
Model line:            3
***        model parameters  model name:   0:n_tran           model type:nmos   ***
   *** general parameters ***
    deriv=   0.
   ***  level 49  model parameters  ***
      hspver=    2006.03               level=         49
     version=       3.22            paramchk=          0
      apwarn=          1                lite=          0
      vgslim=          0             binUnit=          1
      capMod=          3               xpart=          1
      mobMod=          1              nqsMod=          0
      stiMod=          0                 elm=          5
    sfvtflag=          0                 tox=    1.5e-08 meter
          xj=    1.5e-07 meter       binflag=          0
        lmin=          0 meter          lmax=          0 meter
        wmin=          0 meter          wmax=          0 meter
        lref=          0 meter          wref=          0 meter
        lint=          0 meter          wint=          0 meter
       lmult=          1               wmult=          1
          ll=          0                 lln=          1
          lw=          0                 lwn=          1
         lwl=          0                  wl=          0
         wln=          1                  ww=          0
         wwn=          1                 wwl=          0
         dwg=          0 m/V             dwb=          0 m/V^1/2
          xl=          0                  xw=          0
          a0=          1                 ags=          0 V^-1
          b0=          0 meter            b1=          0 meter
        keta=     -0.047 V^-1           voff=      -0.08 V
       ngate=          0 cm^-3           vbx=          0 V
         vbm=         -3 V                xt=   1.55e-07 meter
        vth0=        0.7 V               nch=    1.7e+17 cm^-3
        nsub=      6e+16 cm^-3           nlx=   1.74e-07 meter
      gamma1=    1.03038 V^-1/2       gamma2=   0.612136 V^-1/2
          k1=          0 V^1/2            k2=          0
          k3=         80                 k3b=          0 V^-1
          w0=    2.5e-06 meter          dvt0=        2.2
        dvt1=       0.53                dvt2=     -0.032 V^-1
       dvt0w=          0 meter^-1      dvt1w=    5.3e+06 meter^-1
       dvt2w=     -0.032 V^-1           dsub=       0.56
        eta0=       0.08                etab=      -0.07 V^-1
          u0=      0.067 m^2/V/sec         ua=   2.25e-09 m/V
          ub=   5.87e-19 (m/V)^2          uc=  -4.65e-11 V^-1
        vsat=      80000 m/sec            a1=          0 v^-1
          a2=          1               delta=       0.01 V
        rdsw=          0 ohm-um         prwg=          0 V^-1
        prwb=          0 V^-1/2           wr=          1
        pclm=        1.3             pdiblc1=       0.39
     pdiblc2=     0.0086             pdiblcb=          0 V^-1
      pscbe1=   4.24e+08 V/m          pscbe2=      1e-05 V/m
       drout=       0.56                pvag=          0
     nfactor=          1                cdsc=    0.00024 f/m^2
       cdscb=          0 f/V/m^2       cdscd=          0 f/V/m^2
         cit=          0 f/m^2        alpha0=          0 m/V
       beta0=         30 V               dlc=          0 meter
         dwc=          0 meter           clc=      1e-07 meter
         cle=        0.6                cgso=2.07188e-10 f/m
        cgdo=2.07188e-10 f/m            cgbo=          0 f/m
        cgsl=          0 f/m            cgdl=          0 f/m
      ckappa=        0.6                  cf=7.29897e-11 f/m
        acde=          1 m/V            moin=         15 V^1/2
        toxm=    1.5e-08 m            dtoxcv=          0 m
         vfb (not used)                alpha1=          0 1/V
        ijth=          0 A              noff=          1
      voffcv=          0                 tcj=          0 1/K
       tcjsw=          0 1/K          tcjswg=          0 1/K
         tpb=          0 V/K           tpbsw=          0 V/K
      tpbswg=          0 V/K             llc=          0
         lwc=          0                lwlc=          0
         wlc=          0                 wwc=          0
        wwlc=          0                tnom=     298.15 K
         kt1=      -0.11 V              kt1l=          0
         kt2=      0.022                 ute=       -1.5
         ua1=   4.31e-09 m/V             ub1=  -7.61e-18 (m/V)^2
         uc1=   -5.6e-11 m/V^2            at=      33000 m/s
         prt=          0
         using Berkeley noise model       noiMod=          1
        noia=      1e+20                noib=      50000
        noic=   -1.4e-12                  em=    4.1e+07
          ef=          1                  af=      0.826
          kf=      4e-29              gdsnoi=-1.23457e-29
         using Hspice diodes            using ACM
         acm=         0                 hdif=         0 meter
        ldif=         0 meter             js=         0 amp/m^2
         jsw=         0 amp/m            xti=         0
           n=         1                   cj=0.000101851 f/m^2
          mj=       0.5                   pb=       0.8 V
        cjsw=         0 f/m             mjsw=      0.33
         php=       0.8 V               pbsw (not used)
      cjgate=         0 f/m            cjswg (not used)
       mjswg (not used)                 pbswg (not used)
**** List of Port Elements
Port Number     Mode        Zo       DC bias
     1         single    ( 50.0    ,0.0)    2.10
     2         single    (0.200E+05,0.0)    0.00
Warning: Pd = 0 is less than Weff = 4e-05 in BSIM3 model 0:n_tran element m1 with W = 4e-05, L = 1.5e-06
****** circuit element summary tnom=  25.000 temp=  25.000 ******
**** resistors
element name        0:rs
node1               0:in
node2               0:g1
model
res eff            50.0000
tc1                 0.
tc2                 0.
scale               1.0000
m                   1.0000
ac                 50.0000
temp               25.0000
l                   0.
w                   0.
cap                 0.
noise            1.000e+00
**** independent sources
     name         node1        node2      dc volt    ac mag    ac phase    type
  vdd  vdd               0                    5.0000     0.         0.      dc
**** port elements
        0:p1             0:in             0:0           2.1000   100.0000m    0.
                      z0       rdc         rac      rtran
                   50.0000    50.0000    50.0000    50.0000
        0:p2             0 shocked.gif ut            0:vdd         0.         0.         0.
                      z0       rdc         rac      rtran
                   20.0000k   20.0000k   20.0000k   20.0000k
**** mosfets
**** BSIM3v3 Model (Level49 or Level53)
element name        0:m1
drain               0 shocked.gif ut
gate                0:g1
source              0:0
bulk                0:0
model               0:n_tran
w eff              40.0000u
l eff               1.5000u
rd eff              0.
rs eff              0.
cdsat               0.
cssat               0.
capbd               0.
capbs               0.
temp               25.0000
aic
nf                  1.0000
sa                  0.
sb                  0.
sd                  0.
saeff               0.
sbeff               0.
mulu0               1.0000
mulua               1.0000
mulub               1.0000
m                   1.0000
w drawn            40.0000u
l drawn             1.5000u
******  option summary
runlvl  = 3         bypass  = 2.0000
**info** dc convergence successful at Newton-Raphson method
****** operating point information tnom=  25.000 temp=  25.000 ******
****** operating point status is all       simulation time is     0.
    node    =voltage      node    =voltage      node    =voltage
+0:g1      =   2.1000  0:in      =   2.1000  0 shocked.gif ut     =   2.6787
+0:vdd     =   5.0000
**** voltage sources
subckt
element  0:vdd
  volts      5.0000
  current -116.0653u
  power    580.3266u
     total voltage source power dissipation=  580.3266u       watts
****  port elements
subckt
element  0:p1       0:p2
  volts      2.1000    -2.3213
  current    0.      -116.0653u
  power      0.      -269.4232u
     total port element power dissipation= -269.4232u       watts
**** resistors
subckt
element  0:rs
  r value   50.0000
  v drop     0.
  current    0.
  power      0.
**** mosfets
subckt
element  0:m1
model    0:n_tran
region   Saturation
  id       116.0653u
  ibs        0.
  ibd        0.
  vgs        2.1000
  vds        2.6787
  vbs        0.
  vth        1.7221
  vdsat    215.8463m
  vod      377.8907m
  beta       2.5529m
  gam eff    2.5175
  gm       551.7267u
  gds        3.6716u
  gmb      367.7191u
  cdtot     11.2095f
  cgtot    134.3648f
  cstot    160.1349f
  cbtot     92.1421f
  cgs       92.6331f
  cgd       11.2044f
Frequency = 10.0000x Hz
NF (mag) = 1.0+44.3778
NF (dB) = 16.5684
Element Contribution to NF (mag)    (dB)
m1      TOT                43.3497  16.3699
rs      TOT                1.02810  120.368m
Frequency = 12.5893x Hz
NF (mag) = 1.0+44.0118
NF (dB) = 16.5333
m1      TOT                42.9837  16.3330
Frequency = 15.8489x Hz
NF (mag) = 1.0+43.7211
NF (dB) = 16.5051
m1      TOT                42.6930  16.3036
Frequency = 19.9526x Hz
NF (mag) = 1.0+43.4901
NF (dB) = 16.4826
m1      TOT                42.4620  16.2800
Frequency = 25.1189x Hz
NF (mag) = 1.0+43.3066
NF (dB) = 16.4647
m1      TOT                42.2785  16.2612
Frequency = 31.6228x Hz
NF (mag) = 1.0+43.1608
NF (dB) = 16.4504
m1      TOT                42.1327  16.2462
Frequency = 39.8107x Hz
NF (mag) = 1.0+43.0449
NF (dB) = 16.4390
m1      TOT                42.0168  16.2342
Frequency = 50.1187x Hz
NF (mag) = 1.0+42.9526
NF (dB) = 16.4298
m1      TOT                41.9245  16.2247
Frequency = 63.0957x Hz
NF (mag) = 1.0+42.8790
NF (dB) = 16.4226
m1      TOT                41.8509  16.2170
Frequency = 79.4328x Hz
NF (mag) = 1.0+42.8201
NF (dB) = 16.4167
m1      TOT                41.7920  16.2109
Frequency = 100.000x Hz
NF (mag) = 1.0+42.7726
NF (dB) = 16.4120
m1      TOT                41.7445  16.2060
Frequency = 125.893x Hz
NF (mag) = 1.0+42.7338
NF (dB) = 16.4082
m1      TOT                41.7057  16.2020
Frequency = 158.489x Hz
NF (mag) = 1.0+42.7012
NF (dB) = 16.4049
m1      TOT                41.6731  16.1986
Frequency = 199.526x Hz
NF (mag) = 1.0+42.6725
NF (dB) = 16.4021
m1      TOT                41.6444  16.1956
Frequency = 251.189x Hz
NF (mag) = 1.0+42.6453
NF (dB) = 16.3994
m1      TOT                41.6172  16.1927
Frequency = 316.228x Hz
NF (mag) = 1.0+42.6166
NF (dB) = 16.3965
m1      TOT                41.5885  16.1897
Frequency = 398.107x Hz
NF (mag) = 1.0+42.5828
NF (dB) = 16.3931
m1      TOT                41.5547  16.1862
Frequency = 501.187x Hz
NF (mag) = 1.0+42.5384
NF (dB) = 16.3887
m1      TOT                41.5103  16.1816
Frequency = 630.957x Hz
NF (mag) = 1.0+42.4756
NF (dB) = 16.3825
m1      TOT                41.4475  16.1750
Frequency = 794.328x Hz
NF (mag) = 1.0+42.3823
NF (dB) = 16.3731
m1      TOT                41.3542  16.1652
Frequency = 1.00000g Hz
NF (mag) = 1.0+42.2403
NF (dB) = 16.3589
m1      TOT                41.2122  16.1503
Frequency = 1.25893g Hz
NF (mag) = 1.0+42.0224
NF (dB) = 16.3369
m1      TOT                40.9943  16.1272
Frequency = 1.58489g Hz
NF (mag) = 1.0+41.6879
NF (dB) = 16.3030
m1      TOT                40.6598  16.0916
Frequency = 1.99526g Hz
NF (mag) = 1.0+41.1793
NF (dB) = 16.2510
m1      TOT                40.1512  16.0370
Frequency = 2.51189g Hz
NF (mag) = 1.0+40.4202
NF (dB) = 16.1721
m1      TOT                39.3921  15.9541
Frequency = 3.16228g Hz
NF (mag) = 1.0+39.3200
NF (dB) = 16.0552
m1      TOT                38.2919  15.8311
Frequency = 3.98107g Hz
NF (mag) = 1.0+37.7927
NF (dB) = 15.8875
m1      TOT                36.7646  15.6543
Frequency = 5.01187g Hz
NF (mag) = 1.0+35.7963
NF (dB) = 15.6580
m1      TOT                34.7682  15.4118
Frequency = 6.30957g Hz
NF (mag) = 1.0+33.3825
NF (dB) = 15.3634
m1      TOT                32.3544  15.0993
Frequency = 7.94328g Hz
NF (mag) = 1.0+30.7252
NF (dB) = 15.0140
m1      TOT                29.6971  14.7271
Frequency = 10.0000g Hz
NF (mag) = 1.0+28.0854
NF (dB) = 14.6367
m1      TOT                27.0573  14.3228
****** ac analysis tnom=  25.000 temp=  25.000 ******
freq         voltage    onoise
             out        mag
   10.00000x    1.0279     0.
   12.58925x    1.0278     0.
   15.84893x    1.0277     0.
   19.95262x    1.0276     0.
   25.11886x    1.0273     0.
   31.62278x    1.0270     0.
   39.81072x    1.0264     0.
   50.11872x    1.0255     0.
   63.09573x    1.0240     0.
   79.43282x    1.0217     0.
  100.00000x    1.0181     0.
  125.89254x    1.0125     0.
  158.48932x    1.0038     0.
  199.52623x  990.4704m    0.
  251.18864x  970.3677m    0.
  316.22777x  940.8906m    0.
  398.10717x  899.2616m    0.
  501.18723x  843.3774m    0.
  630.95734x  773.0041m    0.
  794.32823x  690.7289m    0.
    1.00000g  601.8057m    0.
    1.25893g  512.6748m    0.
    1.58489g  429.0427m    0.
    1.99526g  354.6641m    0.
    2.51189g  291.1854m    0.
    3.16228g  238.6483m    0.
    3.98107g  196.1275m    0.
    5.01187g  162.2186m    0.
    6.30957g  135.3328m    0.
    7.94328g  113.8665m    0.
   10.00000g   96.3397m    0.
y
          ***** job concluded
****** job statistics summary tnom=  25.000 temp=  25.000 ******
******  Machine Information  ******
CPU:
model name        : 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
cpu MHz        : 2400.000
CPU(s)                : 8
OS:
Linux version 4.18.0-553.16.1.el8_10.x86_64 (gcc version 8.5.0 20210514 (Red Hat 8.5.0-22) (GCC)) #1 SMP Thu Aug 8 17:47:08 UTC 2024
System loadavg : 0.74 1.01 0.91 5/629 562070
  ******  PrimeSim HSPICE Threads Information  ******
  Command Line Threads Count :     1
  Available CPU Count        :     8
  Actual Threads Count       :     1
  ******  Circuit Statistics  ******
  # nodes       =       5 # elements   =       5
  # resistors   =       1 # capacitors =       0 # inductors   =       0
  # mutual_inds =       0 # vccs       =       0 # vcvs        =       0
  # cccs        =       0 # ccvs       =       0 # volt_srcs   =       1
  # curr_srcs   =       0 # diodes     =       0 # bjts        =       0
  # jfets       =       0 # mosfets    =       1 # U elements  =       0
  # T elements  =       0 # W elements =       0 # B elements  =       0
  # S elements  =       0 # P elements =       2 # va device   =       0
  # vector_srcs =       0 # N elements =       0
  ******  Runtime Statistics (seconds)  ******
  analysis           time    # points   tot. iter  conv.iter
  op point           0.00           1           5
  ac analysis        0.00          31          31
  readin             0.00
  errchk             0.00
  setup              0.00
  output             0.00
           peak memory used        535.74 megabytes
           total cpu time            0.00 seconds
           total elapsed time        0.03 seconds
           job started at     02:50:36 09/25/2024
           job ended   at     02:50:36 09/25/2024
>info:         ***** hspice job concluded
           job total runtime         0.03 seconds
lic: Release hspice token(s)
lic: total license checkout elapse time:        0.02(s)
GMT+8, 2025-12-20 17:41 , Processed in 0.022833 second(s), 4 queries , Gzip On, Redis On.
