查看: 3302|回复: 11
SCL Error- Does any one have a solution.
发表于 2024-9-14 18:00:18 | 显示全部楼层 |阅读模式
When I am invoking any Synopsys tool, i get this error.
[SCL] Error: One possible reason for this error is that FLEXlm version of the application is higher than the license daemon version. If this is the case, please upgrade the license daemon to the latest version (SCL-602)
I use this
scl_v2024.06, from this source "https://pan.baidu.com/s/19oay2_fhxw2wLIRzGMPoGg?pwd=51ny#list/path=%2FEDA%2F01.Synopsys%2Fscl%2Fscl_v2024.06&parentPath=%2FEDA"
发表于 2024-9-14 18:12:22 | 显示全部楼层
please use SynopsysMonoSlayer to patch it.
 楼主| 发表于 2024-9-14 20:31:43 | 显示全部楼层
Could you tell me what is Synopsys MonoSlayer this?
and also where can I find it?
发表于 2024-9-15 20:08:03 来自手机 | 显示全部楼层
正解
发表于 2024-9-17 19:19:51 | 显示全部楼层
You can search "SynopsysMonoSlayer" in github
发表于 2024-9-17 23:11:23 | 显示全部楼层
Use  pubkey_v1.6
% pubkey_verify -y
% synopsys_checksum -y
% pubkey_verify_java -y
 楼主| 发表于 2024-9-21 03:58:04 | 显示全部楼层
joshua2784920 发表于 2024-9-17 23:11
Use  pubkey_v1.6
% pubkey_verify -y
when I do
pubkey_verify -y
Can't open ./linux64/bin/lmgrd for Read&Write
Can't open ./linux64/bin/snpslmd for Read&Write
发表于 2025-4-16 18:06:25 | 显示全部楼层
谁能分享个SynopsysMonoSlayer
发表于 2025-4-16 19:26:02 | 显示全部楼层
thanks
发表于 2025-4-16 19:27:12 | 显示全部楼层
please try searching the forum first
GMT+8, 2025-12-27 13:18 , Processed in 0.018715 second(s), 4 queries , Gzip On, Redis On.
