查看: 3522|回复: 3
[原创] vcs这2个错误,用什么开关?
发表于 2024-9-2 21:06:55 | 显示全部楼层 |阅读模式
Error-[IRIPS] Illegal range in part select
/rft/ed_ful_regd_slice_n2.v, 99
  The range of the part select is illegal:
  Unknown range in part select.payload_reg_b[base+:REM_SEL_LINE]
Error-[NMCM] Negative multiconcat multiplier
/rft/ed_fifo_n2.v, 105
  Multiconcat multiplier cannot be negative value.
  Source info: {(FIFO_DEPTH - 1) {1'b0}}
  Instance stack trace:
      _fifo_n2#(FIFO_WIDTH, FIFO_DEPTH, )
verilog/gic_fifo_bypass_n2.v,
发表于 2024-9-3 09:25:06 | 显示全部楼层
错误提示的英文看不懂?
发表于 2024-9-3 09:43:01 | 显示全部楼层
英文提示没有歧义吧
发表于 2024-9-3 13:46:36 | 显示全部楼层
按提示改不就好了
GMT+8, 2025-9-15 08:47 , Processed in 0.030283 second(s), 4 queries , Gzip On, Redis On.
