查看: 1443|回复: 0
[解决] DC仿真无法用average函数计算平均值
发表于 2024-9-1 19:50:54 | 显示全部楼层 |阅读模式
在对带隙基准电路仿真时,用Caculator的average函数计算温漂或Vref平均值时报错:
ERROR (ADE-1057): Could not evaluate expression
        '((ymax(VS("/Vref")) - ymin(VS("/Vref"))) / (average(VS("/Vref")) * 120))'
     because of the following error(s)
        ("times" 0 t nil ("*Error* times: can't handle (nil * 120)"))
     Ensure that the definition of the expression is correct.
最后发现不是表达式有问题。DC仿真取消勾选hysteresis sweep就解决问题了。
GMT+8, 2025-9-14 02:59 , Processed in 0.020657 second(s), 3 queries , Gzip On, Redis On.
