查看: 2414|回复: 12
[原创] layout自制工具栏
发表于 2024-8-21 10:32:25 | 显示全部楼层 |阅读模式
procedure(LabelHandleUI()
prog((cv)
        OddEvenField = hiCreateFrameField(
                ?name                        'OddEvenField
                ?labelText                "odo/Even gelect"
        OddButton = hiCreateButton(
                ?name                        'OddButton
                ?callback                "OddEvenSelect(\"odd\")"
                ?buttonText                "Odd"
        EvenButton = hiCreateButton(
                ?name                        'EvenButton
                ?callback                "OddEvenSelect( \"even\")"
                ?buttonText                "Even"
        CaseField = hiCreateFrameField(
                ?name                        'CaseField
                ?labelText                "'a'<->'A'"
        UpCaseButton = hiCreateButton(
                ?name                        'UpCaseButton
                ?callback                "CaseLabel( \"upper\")"
                ?buttonText                "UpCase"
        LowCaseButton = hiCreateButton(
                ?name                        'LowCaseButton
                ?callback                "CaseLabel( \"lower\")"
                ?buttonText                "LowCase"
        ReplaceLabelField = hiCreateFrameField(
                ?name                        'ReplaceLabelField
                ?labelText                "Replace label Text "
        ReplaceLabelInput1 = hiCreateStringField(
                ?name                        'ReplaceLabelInput1
                ?prompt                        "Be Replaced"
        ReplaceLabelInput2 = hiCreateStringField(
                ?name                        'ReplaceLabelInput2
                ?prompt                        "To Replaced"
         ReplaceLabelButton1= hiCreateButton(
                ?name                        'ReplaceLabelButton1
                ?callback                "Replace(ReplaceLabelInput1~>value ReplaceLabelInput2~>value)"
                ?buttonText                "Replace"
        ReplaceLabelButton2 = hiCreateButton(
                ?name                        'ReplaceLabelButton2
                ?callback                "UI->ReplaceLabelInput1~>value = \"\" UI->ReplaceLabelInput1~>value = \"\" "
                ?buttonText                "Clean"
        AlignLabelCenter = hiCreateFrameField(
                ?name                        'AlignLabelCenter
                ?labelText                "Align Label Center"
        AlignLabelInput1 = hiCreateFloatField(
                ?name                        'AlignLabelInput1
                ?prompt                        "X Space"
                ?defValue                nil
        AlignLabelInput2 = hiCreateFloatField(
                ?name                        'AlignLabelInput2
                ?prompt                        "Y Space"
                ?defValue                nil
        AlignLabelButton1 = hiCreateButton(
                ?name                        'AlignLabelButton1
                ?callback                "UI->AlignLabelInput1~>value = 0 UI->AlignLabelInput2~>value = 0"
                ?buttonText                "Clean"
        AlignLabelButton2 = hiCreateButton(
                ?name                        'AlignLabelButton2
                ?callback                "AlignLabel(\"X\" AlignLabelInput1~>value)"
                ?buttonText                "Align X"
        AlignLabelButton3 = hiCreateButton(
                ?name                        'AlignLabelButton3
                ?callback                "AlignLabel(\"Y\" AlignLabelInput2~>value)"
                ?buttonText                "Align Y"
        UI = hiCreateAppForm(
                ?name                        'UI
                ?formTitle                "Labels UI"
                ?fields                        list(        list(OddEvenField                 10:10 220:55 10)
                                                list(OddButton                         20:30 60:25 10 )
                                                list(EvenButton                 90:30 60:25 10 )
                                                list(CaseField                         10:70 220:55 10 )
                                                list(UpCaseButton                 20:90 60:25 10 )
                                                list(LowCaseButton                 90:90 60:25 10 )
                                                list(ReplaceLabelField                 10:130 220:120 10 )
                                                list(ReplaceLabelInput1         20:150 200:25 75 )
                                                list(ReplaceLabelInput2         20:180 200:25 75 )
                                                list(ReplaceLabelButton1         20:215 60:25 10 )
                                                list(ReplaceLabelButton2         90:215 60:25 10 )
                                                list(AlignLabelCenter                 10:255 220:120 10 )
                                                list(AlignLabelInput1                 20:275 130:25 75 )
                                                list(AlignLabelInput2                 20:305 130:25 75 )
                                                list(AlignLabelButton1                 20:340 60:25 10 )
                                                list(AlignLabelButton2                 160:280 60:25 10 )
                                                list(AlignLabelButton3                 160:310 60:25 10 )
                                        );list
                ?buttonLayout        'Close
                ?minSize        list(240 450)
                ?maxSize        list(240 450)
                );UI
        hiDisplayForm(UI)
);prog
);procedure
procedure(OddEvenSelect(mode)
prog((cv)
        labels = geGetSelSet()
        points = list()
        labelsx = list()
        labelsy = list()
        foreach(label labels
                if(label~>objType == "label" then
                        labelsx = cons(car(label~>xy) labelsx)
                        labelsy = cons(cadr(label~>xy) labelsy)
                else
                        geDeselectObject(label)
                        labels = remove(label labels)
                );if
        );foreach
        if(nth(0 labelsx) == nth(1 labelsx) then
                prints = sort(labelsy 'lessp)
        );if
        if(nth(0 labelsy) == nth(1 labelsy) then
                prints = sort(labelsx 'lessp)
        );if
        mark = 0
        mark++
        foreach(point points
                if(mode == "odd" then
                        mark++
                        if(mod(mark  2) == 1 then
                                points =remove(point points)
                        );if
                );if
                if(mode == "even" then
                        mark++
                        );if
                );if
        );foreach
                mark = 0
                                if(cadr(label~>xy) == point then
                                        mark = 1
                                );if
                        );if
                                        mark = 1
                                );if
                        );if
                );foreach
                if(mark == 0 then
                );if
        );foreach
);prog
);procedure
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;ChangeLabelCase;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
procedure(CaseLabel(mode)
prog((cv)
                        case(mode
                        ("upper"
                                label~>theLabel = upperCase(label~>theLabel)
                        ("lower"
                                label~>theLabel = lowerCase(label~>theLabel)
                        );case
                );if
        );foreach
);prog
);procedure
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;ReplaceLabelElement;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
procedure(Replace(BeReplace ToReplace)
prog((cv)
                rexCompile(BeReplace)
                label~>theLabel = rexReplace(label~>theLabel ToReplace 0)
                );of
        );foreach
);prog
);procedure
procedure(AlignLabel(mode space)
prog((cv)
        labelsx = list()
        labelsy = list()
                else
                );if
        );foreach
        if(mode =="X" then
                labelsx= sort(labelsx 'lessp)
                        if(car(label~>xy) == nth(0 labelsx) then
                                org_x = car(label~>xy)
                                org_y = cadr(label~>xy)
                        );if
                );foreach
                foreach(labelx labelsx
                                if(car(label~>xy) == labelx then
                                        print(list(org_x org_y))
                                        label~>xy = list(org_x org_y)
                                        org_x = org_x + space
                                );if
                        );foreach
                );foreach
        );if
        if(mode =="Y" then
                labelsy= sort(labelsy 'lessp)
                        if(cadr(label~>xy) == nth(0 labelsy) then
                        );if
                );foreach
                foreach(labely labelsy
                                if(cadr(label~>xy) == labely then
                                        org_y = org_y + space
                                );if
                        );foreach
                );foreach
        );if
);prog
);procedure
工具栏.docx
12.95 KB, 下载次数: 69 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2024-8-21 11:10:57 | 显示全部楼层
不错。
发表于 2024-8-21 11:28:23 | 显示全部楼层
good information, thanks.
发表于 2024-8-21 16:52:38 | 显示全部楼层
这个是有啥作用?
发表于 2024-8-23 17:06:58 | 显示全部楼层
大佬。希望配个图。不然我这种菜鸟看不懂
发表于 2024-8-26 11:10:40 | 显示全部楼层
谢谢分享!
发表于 2024-8-27 15:47:48 | 显示全部楼层
可以详细说一下功能吗
 楼主| 发表于 2024-8-27 16:05:56 | 显示全部楼层
小眼睛大长腿S 发表于 2024-8-23 17:06
大佬。希望配个图。不然我这种菜鸟看不懂
这样式的
 楼主| 发表于 2024-8-27 16:09:08 | 显示全部楼层
大小写切换  方括号尖括号切换,XY方向快速对齐
发表于 2024-8-29 17:19:24 | 显示全部楼层
怎么打开这个工具栏
GMT+8, 2025-12-18 10:57 , Processed in 0.032078 second(s), 5 queries , Gzip On, Redis On.
