查看: 4895|回复: 10
Synopsys license Cannot connect to license server system问题
发表于 2024-8-15 11:36:23 | 显示全部楼层 |阅读模式
license检验通过了,运行lmg貌似也没问题但是就是用不了,输入lmstat报错,直接打开软件也是这个报错,不知道为什么折腾了好久求大佬解决一下,谢谢
lmstat - Copyright (c) 1989-2017 Flexera Software LLC. All Rights Reserved.
Flexible License Manager status on Thu 8/15/2024 11:18
Error getting status: Cannot connect to license server system. (-15,570:101 "Network is unreachable")
以下是运行lmg结果
11:32:28 (lmgrd) FlexNet Licensing (v11.14.1.3 build 212549 x64_lsb) started on 001 (linux) (8/15/2024)
11:32:28 (lmgrd) Copyright (c) 1988-2017 Flexera Software LLC. All Rights Reserved.
11:32:28 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
11:32:28 (lmgrd) License file(s): /opt/eda/Synopsys/scl/2018.06/admin/license/Synopsys.dat
11:32:28 (lmgrd) lmgrd tcp-port 27050
11:32:28 (lmgrd) (@lmgrd-SLOG@) ===============================================
11:32:28 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
11:32:28 (lmgrd) (@lmgrd-SLOG@) Start-Date: Thu Aug 15 2024 11:32:28 CST
11:32:28 (lmgrd) (@lmgrd-SLOG@) PID: 497737
11:32:28 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.14.1.3 build 212549 x64_lsb ( build 212549 (ipv6))
11:32:28 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
11:32:28 (lmgrd) (@lmgrd-SLOG@) Listening port: 27050
11:32:28 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
11:32:28 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
11:32:28 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c /opt/eda/Synopsys/scl/2018.06/admin/license/Synopsys.dat
11:32:28 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  /opt/eda/Synopsys/scl/2018.06/admin/license/Synopsys.dat
11:32:28 (lmgrd) Starting vendor daemons ...
11:32:28 (lmgrd) Started snpslmd (internet tcp_port 54703 pid 497738)
11:32:28 (snpslmd) FlexNet Licensing version v11.14.1.3 build 212549 x64_lsb
08/15/2024 11:32:29 (snpslmd) INFO: Pooling on VENDOR_STRING is Disabled (to enable, set SCL_POOL_VS=1)
08/15/2024 11:32:29 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_2018.06
08/15/2024 11:32:29 (snpslmd) [SCL] File descriptor limit (soft, hard) for snpslmd: 4096, 4096
08/15/2024 11:32:29 (snpslmd) INFO: [SCL] TCP - tcp_keepalive_time - 7200 | tcp_keepalive_intvl - 75 | tcp_keepalive_probes - 9 | tcp_fin_timeout - 60
11:32:29 (snpslmd) SLOG: Summary LOG statistics is enabled.
11:32:29 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
11:32:29 (snpslmd) SLOG: VM Status: 0
11:32:29 (snpslmd) Using options file: "USE"
11:32:30 (snpslmd) Server started on 001 for:        SSS
11:32:30 (snpslmd) xp                xsim                vcd2e
11:32:30 (snpslmd) vcsace                vera_comp        vera_ip
11:32:30 (snpslmd) verilog_writer        vertue                vhdl_compiler
11:32:30 (snpslmd) viewlogic        viewlogic_epic        vlog_epic_pif
11:32:30 (snpslmd) vlog2e                vlsi2000        vlsi500
11:32:30 (snpslmd) vsea-calib        vsea-calib_all        vsea-calib_ise
11:32:30 (snpslmd) vsea-calib_ise_all vsecP_OEM_VCS_FUJITSU_GEN_NL vsecP_OEM_VCS_FUJITSU_GEN_NW
11:32:30 (snpslmd) vsecP_OEM_VCS_FUJITSU_RUN_NL vsecP_OEM_VCS_FUJITSU_USE_NL vsecP_OEM_VCS_FUJITSU_USE_NW
11:32:30 (snpslmd) vtran                usb_device_vmt        techviewer
11:32:30 (snpslmd) testing                tfm                timemill
11:32:30 (snpslmd) timemill/ace        timemill/av        timemill/bcx
11:32:30 (snpslmd) timemill/bdc        timemill/beta_status timemill/btm
11:32:30 (snpslmd) timemill/csx        timemill/internal_use timemill/msx
11:32:30 (snpslmd) timemill/nsaddon tSchema                turboSchema
11:32:30 (snpslmd) turboState        turboTracer        turboWave
11:32:30 (snpslmd) turbowave_epic        sprocess-an-imp3d sprocess-an-imp3d_all
11:32:30 (snpslmd) sprocess-an-imp3d_ise sprocess-an-imp3d_ise_all sprocesskmc_all
11:32:30 (snpslmd) sprocessmc        sprocessmc_all        sprocessmc_ise
11:32:30 (snpslmd) sprocessmc_ise_all sprocessmpp_all sprocess-parallel_all
11:32:30 (snpslmd) sprocess-parallel4_all sptopography2d_all stars_analog
11:32:30 (snpslmd) stars_aryred        stars_cmi        stars_csdf
11:32:30 (snpslmd) stars_hsplnk        stars_ish        stars_linred
11:32:30 (snpslmd) stars_mr        stars_wsf        starsim
11:32:30 (snpslmd) starsimxt        start_aed        start_analysis
11:32:30 (snpslmd) start_bin        startime        sup2lig
11:32:30 (snpslmd) sup2lig_all        sup2lig_ise        sup2lig_ise_all
11:32:30 (snpslmd) svisual_all        swb                swb_all
11:32:30 (snpslmd) swb_ise                swb_ise_all        swb-advanced
11:32:30 (snpslmd) swb-advanced_all swb-advanced_ise swb-advanced_ise_all
11:32:30 (snpslmd) sx_cdslink        sx_chip                sx_daiclink
11:32:30 (snpslmd) sx_drc                sx_wva                synplify
11:32:30 (snpslmd) synplifyasic        synplifydspoption synplifydspsl
11:32:30 (snpslmd) synplifypremier synplifypremierdp synplifypro
11:32:30 (snpslmd) synplifypro_asix systemc_ide        sinterconnect_all
11:32:30 (snpslmd) sinterconnect2d_all sinterconnect3d_all sdevice-parallel_ise
11:32:30 (snpslmd) sdevice-parallel_ise_all sdevice-parallel4 sdevice-parallel4_all
11:32:30 (snpslmd) sdevice-parallel4_ise sdevice-parallel4_ise_all sdevice-pmi
11:32:30 (snpslmd) sdevice-pmi_all sdevice-pmi_ise sdevice-pmi_ise_all
11:32:30 (snpslmd) sdevice-radiation sdevice-radiation_all sdevice-radiation_ise
11:32:30 (snpslmd) sdevice-radiation_ise_all sdevice-reliability sdevice-reliability_all
11:32:30 (snpslmd) sdevice-reliability_ise sdevice-reliability_ise_all sdevice-schroedinger
11:32:30 (snpslmd) sdevice-schroedinger_all sdevice-schroedinger_ise sdevice-schroedinger_ise_all
11:32:30 (snpslmd) sdevice-sige        sdevice-sige_all sdevice-sige_ise
11:32:30 (snpslmd) sdevice-sige_ise_all sdevice-thermo        sdevice-thermo_all
11:32:30 (snpslmd) sdevice-thermo_ise sdevice-thermo_ise_all sdevice-traps
11:32:30 (snpslmd) sdevice-traps_all sdevice-traps_ise sdevice-traps_ise_all
11:32:30 (snpslmd) sdevice-vectoroptic sdevice-vectoroptic_all sdevice-vectoroptic_ise
11:32:30 (snpslmd) sdevice-vectoroptic_ise_all sharp                simif
11:32:30 (snpslmd) simwave                simwave_epic        snps_fs_nwave
11:32:30 (snpslmd) sparallel        sparallel_all        sparallel_ise
11:32:30 (snpslmd) sparallel_ise_all spcmcalib_all        spcmlib
11:32:30 (snpslmd) spcmlib_all        spcmlib_ise        spcmlib_ise_all
11:32:30 (snpslmd) spcmstd                spcmstd_all        spcmstd_ise
11:32:30 (snpslmd) spcmstd_ise_all spcmtcl                spcmtcl_all
11:32:30 (snpslmd) spcmtcl_ise        spcmtcl_ise_all spice_explorer
11:32:30 (snpslmd) spice_parser        sprocess        sprocess_all
11:32:30 (snpslmd) sprocess_ise        sprocess_ise_all sprocess2d
11:32:30 (snpslmd) sprocess2d_all        sprocess2d_ise        sprocess2d_ise_all
11:32:30 (snpslmd) sprocess2dmc        sprocess2dmc_all sprocess2dmc_ise
11:32:30 (snpslmd) sprocess2dmc_ise_all sprocess3d        sprocess3d_all
11:32:30 (snpslmd) sprocess3d_ise        sprocess3d_ise_all sprocess3dmc
11:32:30 (snpslmd) sprocess3dmc_all sprocess3dmc_ise sprocess3dmc_ise_all
11:32:30 (snpslmd) scratch                sda                sde
11:32:30 (snpslmd) sde_all                sde_ise                sde_ise_all
11:32:30 (snpslmd) sde3d                sde3d_all        sde3d_ise
11:32:30 (snpslmd) sde3d_ise_all        sdevcie-laser_all sdevice
11:32:30 (snpslmd) sdevice_all        sdevice_ise        sdevice_ise_all
11:32:30 (snpslmd) sdevice-3d        sdevice-3d_all        sdevice-3d_ise
11:32:30 (snpslmd) sdevice-3d_ise_all sdevice-densitygrad sdevice-densitygrad_all
11:32:30 (snpslmd) sdevice-densitygrad_ise sdevice-densitygrad_ise_all sdevice-ferro
11:32:30 (snpslmd) sdevice-ferro_all sdevice-ferro_ise sdevice-ferro_ise_all
11:32:30 (snpslmd) sdevice-floatinggate sdevice-floatinggate_all sdevice-floatinggate_ise
11:32:30 (snpslmd) sdevice-floatinggate_ise_all sdevice-gateleakage sdevice-gateleakage_all
11:32:30 (snpslmd) sdevice-gateleakage_ise sdevice-gateleakage_ise_all sdevice-hetero
11:32:30 (snpslmd) sdevice-hetero_all sdevice-hetero_ise sdevice-hetero_ise_all
11:32:30 (snpslmd) sdevice-hydro        sdevice-hydro_all sdevice-hydro_ise
11:32:30 (snpslmd) sdevice-hydro_ise_all sdevice-kpgain        sdevice-kpgain_all
11:32:30 (snpslmd) sdevice-kpgain_ise sdevice-kpgain_ise_all sdevice-laser
11:32:30 (snpslmd) sdevice-laser_all sdevice-laser_ise sdevice-laser_ise_all
11:32:30 (snpslmd) sdevice-led        sdevice-led_all sdevice-led_ise
11:32:30 (snpslmd) sdevice-led_ise_all sdevice-mixedmode sdevice-mixedmode_all
11:32:30 (snpslmd) sdevice-mixedmode_ise sdevice-mixedmode_ise_all sdevicemonosemicond
11:32:30 (snpslmd) sdevicemonosemicond_all sdevicemonosemicond_ise sdevicemonosemicond_ise_all
11:32:30 (snpslmd) sdevice-montecarlo sdevice-montecarlo_all sdevice-montecarlo_ise
11:32:30 (snpslmd) sdevice-montecarlo_ise_all sdevice-noise        sdevice-noise_all
11:32:30 (snpslmd) sdevice-noise_ise sdevice-noise_ise_all sdevice-optic
11:32:30 (snpslmd) sdevice-optic_all sdevice-optic_ise sdevice-optic_ise_all
11:32:30 (snpslmd) sdevice-parallel sdevice-parallel_all rad
11:32:30 (snpslmd) railmill        railmill/ace        railmill/av
11:32:30 (snpslmd) railmill/bcx        railmill/beta_status railmill/gbx
11:32:30 (snpslmd) railmill/internal_use railmill/msx        railmill/power
11:32:30 (snpslmd) railmill/rvfp        railmill/snx        railmill/spnx
11:32:30 (snpslmd) railmill/ssnx        rm_eee                route66
11:32:30 (snpslmd) rslv3d                rslv3dviewer        pathfinder
11:32:30 (snpslmd) pathmill        pathmill/cso        pathmill/ctx
11:32:30 (snpslmd) pathmill/dsx        pathmill/pfx        pathmill/sfx
11:32:30 (snpslmd) pathmill_plus        planet_migrate        platform_creator_sysc
11:32:30 (snpslmd) pmga                polaris-cbs        polaris-com
11:32:30 (snpslmd) polaris-int        polaris-mt        polaris-signalscan
11:32:30 (snpslmd) powerarc        powergate        powrmill
11:32:30 (snpslmd) powrmill/ace        powrmill/av        powrmill/bcx
11:32:30 (snpslmd) powrmill/beta_status powrmill/btm        powrmill/csx
11:32:30 (snpslmd) powrmill/internal_use powrmill/msx        powrmill/nsaddon
11:32:30 (snpslmd) powrmill/power        powrmill/svcz        powrmill/vlog_a
11:32:30 (snpslmd) primepower_beta primepower_vcd        primerail_hsim
11:32:30 (snpslmd) prmspx_visual_all provhdl_checker psf
11:32:30 (snpslmd) pwga                nAnalyzer        nanochar
11:32:30 (snpslmd) nanosim                nanosim/ace        nanosim/ace_cosim
11:32:30 (snpslmd) nanosim/av        nanosim/bcx        nanosim/bdc
11:32:30 (snpslmd) nanosim/beta_status nanosim/btm        nanosim/gui
11:32:30 (snpslmd) nanosim/internal_use nanosim/msx        nanosim/postlayout_har
11:32:30 (snpslmd) nanosim/power        nanosim/vlog_a        nanosim_starsimxt
11:32:30 (snpslmd) nBench                nClock                nCompare
11:32:30 (snpslmd) nECO                nESL                nlcc
11:32:30 (snpslmd) nLint                nLint_either        nLint_mixed
11:32:30 (snpslmd) nLint_sv        nLint_verilog        nLint_vhdl
11:32:30 (snpslmd) nMonitor        npi                nProp
11:32:30 (snpslmd) nSC                nSchema                nSchemaOnly
11:32:30 (snpslmd) nState                nTE                nTiming
11:32:30 (snpslmd) nTrace                nTree                nTX
11:32:30 (snpslmd) nWave                mentorf                metaencrypt3des
11:32:30 (snpslmd) metawaves        metawaveswin        mg_falcon_epic
11:32:30 (snpslmd) milltools        misc                mti_epic
11:32:30 (snpslmd) mentor/f        leda_checker        leda_mx
11:32:30 (snpslmd) leda-mx                libarc                lsim_parser
11:32:30 (snpslmd) identdebugger        identdebugger_encrypt identdebugger_xilinx
11:32:30 (snpslmd) identify_tps        identifydebugger identifydebugger_encrypt
11:32:30 (snpslmd) identifydebugger_xilinx identifyinstrumentor identifyinstrumentor_encrypt
11:32:30 (snpslmd) identifyinstrumentor_xilinx identinstrumentor identinstrumentor_encrypt
11:32:30 (snpslmd) identinstrumentor_xilinx identprodebugger identprodebugger_encrypt
11:32:30 (snpslmd) identprodebugger_xilinx identproinstrumentor identproinstrumentor_encrypt
11:32:30 (snpslmd) identproinstrumentor_xilinx ispLSI1K        ispLSI2K
11:32:30 (snpslmd) ispLSI2KE        ispLSI3K        ispLSI5000S
11:32:30 (snpslmd) ispLSI5000SE        ispLSI5K        ispLSI6K
11:32:30 (snpslmd) ispLSI8K        ispMACH4000        hd_foundation
11:32:30 (snpslmd) hd_pna                hd_special1        hd_special2
11:32:30 (snpslmd) hd_special3        hd_utils        hdlin
11:32:30 (snpslmd) hdlin_mixed        hdlin_verilog        hdlin_vhdl
11:32:30 (snpslmd) hicdr_test        hicdr_test/test1 hicdr_test/test2
11:32:30 (snpslmd) hicdr_test/test3 hicdr_test/test4 hicdr_test/test5
11:32:30 (snpslmd) hicdr_test/test6 hicdr_test/test7 hicdr_test/test8
11:32:30 (snpslmd) him_mb                him_mb_dsml        him_mm_pi
11:32:30 (snpslmd) him_mod                him_sml                hsim
11:32:30 (snpslmd) hsim-cosim        hsim-xl                hspice
11:32:30 (snpslmd) hspice_adv        hspice_cosim        hspice_gui
11:32:30 (snpslmd) hspice_mt        hspice_pack        hspice_rf
11:32:30 (snpslmd) hspice_rf_char        hspice3des        hspicecmidev
11:32:30 (snpslmd) hspicecmirt        hspicemt        hspicerf
11:32:30 (snpslmd) hspiceva        hspicewin        hspice-XO
11:32:30 (snpslmd) hspicext        hsptest                hspui
11:32:30 (snpslmd) gemini_hspice        gentech                fastspice_xa
11:32:30 (snpslmd) ficdr_test        ficdr_test/gds        ficdr_test/goa
11:32:30 (snpslmd) ficdr_test/io        ficdr_test/nc        ficdr_test/poly
11:32:30 (snpslmd) ficdr_test/size ficdr_test/sizeOr ficdr_test/stmp
11:32:30 (snpslmd) ficdr_test/tio        fpc_foundation        fpc_pna
11:32:30 (snpslmd) fpc_special1        fpc_special2        fpc_special3
11:32:30 (snpslmd) fpc_utils        features        fullhspice
11:32:30 (snpslmd) edif2e                electromigration_drc emw
11:32:30 (snpslmd) emw_all                emw_ise                emw_ise_all
11:32:30 (snpslmd) emw-farfield        emw-farfield_all emw-farfield_ise
11:32:30 (snpslmd) emw-farfield_ise_all emw-nonuniform-2d_all emw-nonuniform-3d
11:32:30 (snpslmd) emw-nonuniform-3d_all emw-nonuniform-3d_ise emw-nonuniform-3d_ise_all
11:32:30 (snpslmd) emw-sdevice        emw-sdevice_all emw-sdevice_ise
11:32:30 (snpslmd) emw-sdevice_ise_all emw-static        emw-static_all
11:32:30 (snpslmd) emw-static_ise        emw-static_ise_all emw-thermal
11:32:30 (snpslmd) emw-thermal_all emw-thermal_ise emw-thermal_ise_all
11:32:30 (snpslmd) emw-uniform-2d_all emw-uniform-3d        emw-uniform-3d_all
11:32:30 (snpslmd) emw-uniform-3d_ise emw-uniform-3d_ise_all encore
11:32:30 (snpslmd) encrypt                etran                eX
11:32:30 (snpslmd) example_INCREMENT example_feature express
11:32:30 (snpslmd) express_fpga        express_fpga_all_vendor express_fpga_altera
11:32:30 (snpslmd) express_fpga_xilinx express_sim_verify express_ui
11:32:30 (snpslmd) express_ui_fpga express_ui_fpga_all_vendor express_ui_fpga_altera
11:32:30 (snpslmd) express_ui_fpga_xilinx express_ui_verify extreme
11:32:30 (snpslmd) extreme_fpga        extreme_fpga_all_vendor extreme_fpga_altera
11:32:30 (snpslmd) extreme_ui_fpga_xilinx extreme_power        extreme_power_ui
11:32:30 (snpslmd) extreme_sharing extreme_ui_fpga extreme_ui_fpga_all_vendor
11:32:30 (snpslmd) extreme_ui_fpga_altera extreme_ui        delaymill
11:32:30 (snpslmd) c_exe_ax        c_exe_cbx        c_exe_drc
11:32:30 (snpslmd) c_exe_gx        c_exe_ipc        c_exe_lvs
11:32:30 (snpslmd) cadence                cadence_epic        cdsaavmx
11:32:30 (snpslmd) cdsaawaves        cdsmetalib        cdsnet
11:32:30 (snpslmd) certify                certifysc        chiparch_migrate
11:32:30 (snpslmd) chipviewer        cmod                cmod/ax
11:32:30 (snpslmd) cmod/cbx        cmod/drc        cmod/gx
11:32:30 (snpslmd) cmod/gxadv        cmod/hdrc        cmod/hlvs
11:32:30 (snpslmd) cmod/ipc        cmod/lvs        cmod/viewer
11:32:30 (snpslmd) coreAssembler        coreBuilder        coreConsultant
11:32:30 (snpslmd) coremill        coreSynthesis        cosmos_other
11:32:30 (snpslmd) cxp                cmpro_main        ace_core
11:32:30 (snpslmd) acega                acehdl                acehdl/beta_status
11:32:30 (snpslmd) acehdl/internal_use acehdl_beta        acehdl_gui
11:32:30 (snpslmd) aiu_foundation        alien2lig        alien2lig_all
11:32:30 (snpslmd) alien2lig_ise        alien2lig_ise_all amat-calib
11:32:30 (snpslmd) amat-calib_all        amat-calib_ise        amat-calib_ise_all
11:32:30 (snpslmd) amga                amplify                amplifyasic
11:32:30 (snpslmd) amplifyissp        amplifyrapidchip amps
11:32:30 (snpslmd) amps/cso        amps/pfx        amps/tr
11:32:30 (snpslmd) any_technology        arc                arc/bcx
11:32:30 (snpslmd) arc/c2x                arc/c3x                arc/cns
11:32:30 (snpslmd) arc/dnx                arc/dpx                arc/gds2
11:32:30 (snpslmd) arc/giper        arc/lefdef        arc/ppx
11:32:30 (snpslmd) arc/pro                arc/r3x                arc1
11:32:30 (snpslmd) arc2                arcexpert        arcfc
11:32:30 (snpslmd) arcviewer        arcviewer/raph        arcxl
11:32:30 (snpslmd) avanwaves        avanwaveswin        awe_rcr
11:32:30 (snpslmd) ace_cosim        XC3000                XC4000
11:32:30 (snpslmd) XC4000E                XC4000EX        XC4000L
11:32:30 (snpslmd) XC4000XL        XC4000XLA        XC4000XV
11:32:30 (snpslmd) XC5200                XC9500                XC9500XL
11:32:30 (snpslmd) XC9500XV        XVCSDebugger        XVCSiDebugger
11:32:30 (snpslmd) XVVCDebugger        WF_API_HSPICE        WF_API_HSPICE_MEMSSE
11:32:30 (snpslmd) WF_API_MEMSSE        WF_API_STARSIM        WF_API_STARSIM_MEMSSE
11:32:30 (snpslmd) WhatIfAnalysis        WRITE                VT_AssertionIP
11:32:30 (snpslmd) VT_Assertions        VT_AssertionsRuntime VT_CBUG
11:32:30 (snpslmd) VT_Coverage        VT_CoverageRuntime VT_CoverageURG
11:32:30 (snpslmd) VT_DVE                VT_DVE_COV        VT_DVENTB
11:32:30 (snpslmd) VT_LCA_Assertions VT_LCA_Coverage VT_LCA_DEBUG
11:32:30 (snpslmd) VT_LCA_Language VT_LCA_MixedSignal VT_LCA_Testbench
11:32:30 (snpslmd) VT_NativeTBDebuggerGui VT_NativeTestbench VT_NTB
11:32:30 (snpslmd) VT_OtherTechnology VT_Pioneer        VT_PVCSCompiler_Net
11:32:30 (snpslmd) VT_SDebug        VT_SVAssertionCompiler VT_SVAssertions
11:32:30 (snpslmd) VT_SVDesign        VT_SVTestbench        VT_SYSTEMC21
11:32:30 (snpslmd) VT_SystemVerilog VT_Testbench        VT_TestbenchRuntime
11:32:30 (snpslmd) VT_UCLI                VT_UnifiedCoverage VT_VCS_Advanced_INCREMENTs
11:32:30 (snpslmd) VT_VCS_BETA_INCREMENTs VT_VCS_BETA_Program VT_VCS_Checker
11:32:30 (snpslmd) VT_VCS_Echo        VT_VCS_LCA_INCREMENTs VT_VCS_NTBE
11:32:30 (snpslmd) VT_VCS_Power_Management VT_Visual        Verdi_HwSwDebug
11:32:30 (snpslmd) VT_VCS_BETA_Features VT_VCS_LCA_Features VT_VCS_Advanced_Features
11:32:30 (snpslmd) VC-STATIC-COMPILE VC-STATIC-RUNTIME VC-STATIC-LP
11:32:30 (snpslmd) VC-STATIC-FV        VC-STATIC-CDC        VC-STATIC-LINT
11:32:30 (snpslmd) VC-STATIC-COV        VERDISIGNOFF        VERIDIGNOFF_LP
11:32:30 (snpslmd) VERIDIGNOFF_FV        VERIDIGNOFF_CDC VERIDIGNOFF_LINT
11:32:30 (snpslmd) VERIDIGNOFF_COV VERDISIGNOFF_CDC Verification-Token
11:32:30 (snpslmd) Verilog                Verilog-Netlist-Writer Verilog-Parser
11:32:30 (snpslmd) Verilog-To-BE        Verilog-VirSim        VF
11:32:30 (snpslmd) VHDLAMS_TAURI        VHDLAMS_TAURILI VHDL-Analyzer
11:32:30 (snpslmd) VHDL-Compiler        VHDL-Compiler-Old VHDL-Compiler-Presto
11:32:30 (snpslmd) VHDL-Cycle-Sim        VHDL-Elaborator VHDL-Event-Sim
11:32:30 (snpslmd) VHDLi-Elaborator VHDLi-Event-Sim VHDL-Netlist-Writer
11:32:30 (snpslmd) VHDL-ScSim        VHDL-To-BE        VHDL-Tools
11:32:30 (snpslmd) VHDL-VirSim        VHMC-Eval        VHMC-GenUnlocked
11:32:30 (snpslmd) VHMC-Runtime        VIEWLOGIC_FRAMEWAY VIEWLOGIC_FRAMEWAY_MEMSSE
11:32:30 (snpslmd) VIEWLOGIC_NET        VIEWLOGIC_NET_MEMSSE VIP-AMBA-SVT
11:32:30 (snpslmd) VIP-LIBRARY-SVT VirSim                VIRTEX
11:32:30 (snpslmd) VIRTEX2                VIRTEX2P        VIRTEXE
11:32:30 (snpslmd) VIRTEXEA        Vivace-Code-Generator Vivace-Core
11:32:30 (snpslmd) Vivace-Debug        Vivace-Elaborator Vivace-Expert
11:32:30 (snpslmd) Vivace-Express        Vivace-GUI        Vivace-HDL-Analyzer
11:32:30 (snpslmd) Vivace-Model-Compiler Vivace-Pro        Vivace-Simulator
11:32:30 (snpslmd) Vivace-VHDL-Analyzer VMCCompiler        VMCCompiler_Net
11:32:30 (snpslmd) VMCCompiler_Node VMCCore                VMCEvaluation
11:32:30 (snpslmd) VMCEvaluation_Net VMCEvaluation_Node VMCExpress_Compiler
11:32:30 (snpslmd) VMCExpress_Compiler_Net VMCExpress_Compiler_Node VMCGeneratorUnlocked
11:32:30 (snpslmd) VMCGeneratorUnlocked_Net VMCGeneratorUnlocked_Node VMCRuntime
11:32:30 (snpslmd) VMCRuntime_Net        VMCRuntime_Node VPC
11:32:30 (snpslmd) VSP_DRIVER        VSS-Analyzer        VSS-Backplane
11:32:30 (snpslmd) VSS-Cadence-Interface VSS-CLI                VSS-CompiledSim
11:32:30 (snpslmd) VSS-Debugger        VSS-Falcon-Interface VSS-GateSim
11:32:30 (snpslmd) VSS-LAI-Models        VSS-Lib-Tools        VSS-LMSI
11:32:30 (snpslmd) VSS-Model-Developer VSS-NEC-Tran        VSS-SDF-Interface
11:32:30 (snpslmd) VSS-SGE-Tool        VSS-Simulator        VSS-SmartModels
11:32:30 (snpslmd) VSS-SPC                VSS-Tran        VSS-Utilities
11:32:30 (snpslmd) VSS-Verilog-PLI VSS-VIP-Interface VSS-Wave-Display
11:32:30 (snpslmd) VSS-XP-Accelerator VT_64Bit        VANTIS
11:32:30 (snpslmd) VCSAMSCompiler        VCSAMSCompiler_Net VCSAMSRuntime
11:32:30 (snpslmd) VCSAMSRuntime_Net VCSCompile        VCSCompile_Net
11:32:30 (snpslmd) VCSCompile_Node VCSCompiler        VCSCompiler_Net
11:32:30 (snpslmd) VCSCompiler_Node VCSDebugger        VCSDebugger_Net
11:32:30 (snpslmd) VCSDebugger_Node VCS-Express-Compile VCS-Express-Runtime
11:32:30 (snpslmd) VCSiCompile        VCSiCompile_Net VCSiCompile_Node
11:32:30 (snpslmd) VCSiCompiler        VCSiCompiler_Net VCSiCompiler_Node
11:32:30 (snpslmd) VCSiDebugger        VCSiDebugger_Net VCSiDebugger_Node
11:32:30 (snpslmd) VCSiRuntime        VCSiRuntime_Net VCSiRuntime_Net(3)
11:32:30 (snpslmd) VCSiRuntime_Node VCSiRuntimeLimited VCSiRuntimeLimited_Net
11:32:30 (snpslmd) VCSiRuntimeLimited_Node VCSlm_Hm        VCSlm_Hm_Net
11:32:30 (snpslmd) VCSlm_Hm_Node        VCSMXiRunTime_Net VCSMXRunTime_Net
11:32:30 (snpslmd) VCSNativeCode        VCSNativeCode_Net VCSNativeCode_Node
11:32:30 (snpslmd) VCSOldPostProcDebugger_Net VCSOldPostProcDebugger_Node VCSParallelCompiler
11:32:30 (snpslmd) VCSParallelCompiler_Net VCSParallelCompiler_Node VCSParallelRuntime
11:32:30 (snpslmd) VCSParallelRuntime_Net VCSParallelRuntime_Node VCSParallelThread
11:32:30 (snpslmd) VCSParallelThread_Net VCSParallelThread_Node VCSPostProcDebugger
11:32:30 (snpslmd) VCSPostProcDebugger_Net VCSPostProcDebugger_Node VCSRuntime
11:32:30 (snpslmd) VCSRuntime_Net        VCSRuntime_Node VCSRuntimeLimited
11:32:30 (snpslmd) VCSRuntimeLimited_Net VCSRuntimeLimited_Node VCSStd
11:32:30 (snpslmd) VCSStd_Net        VCSStd_Node        VCSTools
11:32:30 (snpslmd) VCSTools_Net        VCSTools_Node        VCS-VERIFICATION-LIBRARY
11:32:30 (snpslmd) VDesktop-Debug        VDesktop-GUI        VDesktop-VCDTrans
11:32:30 (snpslmd) VDesktop-Verilog VDesktop-VHDL        VEHICLE_ELECTRIC_LIB
11:32:30 (snpslmd) VEHICLE_ELECTRIC_LIB_MEMSSE VENDOR_LIBRARY        VENDOR_LIBRARY_MEMSSE
11:32:30 (snpslmd) Vera                Vera_debug        Vera_rtime
11:32:30 (snpslmd) Verdi                VERIAS_HSPICE_COMPILER VERIAS_SIMULATOR
11:32:30 (snpslmd) Ultra37000        Test-Physical        Test-Power
11:32:30 (snpslmd) Test-PR-1        Test-PR-2        Test-PR-3
11:32:30 (snpslmd) Test-PR-4        Test-RTL-Check        Test-RTL-Tristate
11:32:30 (snpslmd) Test-ScanRoute        Test-SDD-Timing TestSim
11:32:30 (snpslmd) Test-STDVR        Test-Validate        TestVE
11:32:30 (snpslmd) THERM_TOOL        THERM_TOOL_MEMSSE TimingAnalysis
11:32:30 (snpslmd) TLM_Synthesis        TLU_TOOL        TLU_TOOL_MEMSSE
11:32:30 (snpslmd) TP                TR                TR_ANALYSIS
11:32:30 (snpslmd) TR_ANALYSIS_MEMSSE TV                True
11:32:30 (snpslmd) T3                TA                TBM-Manager-UI
11:32:30 (snpslmd) TBM-VSS-Check        TBS                TC-Beta
11:32:30 (snpslmd) TD                TDL-Interface        TDL-Reader
11:32:30 (snpslmd) TDL-Writer        Tdx                Tdx_all
11:32:30 (snpslmd) Tdx_ise                Tdx_ise_all        Tecplot
11:32:30 (snpslmd) Tecplot_all        Tecplot_ise        Tecplot_ise_all
11:32:30 (snpslmd) TecplotSmall_all Ted                Ted_all
11:32:30 (snpslmd) Ted_ise                Ted_ise_all        TedSmall_all
11:32:30 (snpslmd) Test-Accelerate-Max Test-Accelerator Test-Analysis
11:32:30 (snpslmd) Test-Analysis-GUI Test-Analysis-RTL Test-ATPG
11:32:30 (snpslmd) Test-ATPG-30        Test-ATPG-Limited Test-ATPG-Max
11:32:30 (snpslmd) Test-ATPG-PRO        Test-ATPG-Ultra Test-ATPG-XP
11:32:30 (snpslmd) Test-Beta        Test-Beta-2        Test-Beta-3
11:32:30 (snpslmd) Test-Beta-4        Test-Beta-5        Test-Beta-6
11:32:30 (snpslmd) Test-Beta-7        Test-Beta-8        Test-Beta-9
11:32:30 (snpslmd) Test-BIST        Test-BSDL        Test-CA
11:32:30 (snpslmd) Test-CA-2        Test-CA-3        Test-CA-4
11:32:30 (snpslmd) Test-Compile        Test-Compile-Max Test-Compiler
11:32:30 (snpslmd) Test-Compile-Remodel Test-Compiler-Plus Test-Compiler-Remodel
11:32:30 (snpslmd) Test-Compile-Share Test-Compression-ATPG Test-CompressionPlus-ATPG
11:32:30 (snpslmd) Test-CompressionPlus-Syn Test-Compression-Synthesis Test-Core-Integration
11:32:30 (snpslmd) Test-Core-Wrapper Test-CTL-Model        Test-Custom-Protocols
11:32:30 (snpslmd) Test-Delay        TestDesignCorrelation Test-DFTC-TMAX
11:32:30 (snpslmd) Test-DFT-Top        Test-Diagnosis        Test-Eval
11:32:30 (snpslmd) Test-Fault-Max        Test-Faultsim        Test-Faultsim-8L
11:32:30 (snpslmd) Test-Format        Test-IDDQ        Test-IEEE-Std-1149-1
11:32:30 (snpslmd) TESTIFY                TESTIFY_MEMSSE        TESTIFY_NETLISTER
11:32:30 (snpslmd) TESTIFY_NETLISTER_MEMSSE Test-LBIST-ATPG Test-LBIST-Integration
11:32:30 (snpslmd) Test-LBIST-Synthesis Test-Library        TestManager
11:32:30 (snpslmd) Test-Map        Test-Mbist        Test-Mbist-Algorithm
11:32:30 (snpslmd) Test-Mbist-Bitstream Test-Mbist-CAM        Test-Mbist-Diagnosis
11:32:30 (snpslmd) Test-Mbist-DRAM Test-Mbist-FLASH Test-MBIST-Integration
11:32:30 (snpslmd) Test-Mbist-Multiport Test-Mbist-Program STAR-DC
11:32:30 (snpslmd) STAR-EX                STAR-EX_ERC        STAR-FILTER
11:32:30 (snpslmd) STAR-GAZER        STAR-LD2LTL        STAR-R
11:32:30 (snpslmd) STAR-RC                STAR-RC2        STAR-RC2_MANAGER
11:32:30 (snpslmd) STAR-RC2-AEO        STAR-RC2-ANAL        STAR-RC2-ASCII
11:32:30 (snpslmd) STAR-RC2-CLOCK        STAR-RC2-DB        STAR-RC2-DEBUG
11:32:30 (snpslmd) STAR-RC2-DISTRIB10 STAR-RC2-GUI        STAR-RC2-NETLIST
11:32:30 (snpslmd) STAR-RC2-PROBER STAR-RC2-TCAD        STAR-RC2-VIEWER
11:32:30 (snpslmd) STAR-RC2-XSTOR1 STAR-RC2-XSTOR2 STAR-RC2-XTRACT
11:32:30 (snpslmd) STAR-RC2-XTR-AEO STAR-RC-GUI        STAR-R-GUI
11:32:30 (snpslmd) STAR-SYN2STAR        STAR-TCAD        STAR-XREF
11:32:30 (snpslmd) StarXtract        STATEBENCH        STRESS
11:32:30 (snpslmd) STRESS_MEMSSE        Sxtract_all        SYMLIB
11:32:30 (snpslmd) SYMLIB_JAPANESE SYMLIB_JAPANESE_MEMSSE SYMLIB_MEMSSE
11:32:30 (snpslmd) SYMLIB_PLUS        SYMLIB_PLUS_MEMSSE SYMLIB_POWER
11:32:30 (snpslmd) SYMLIB_POWER_MEMSSE SYNARIO                SynLib-AdvMath
11:32:30 (snpslmd) SynLib-ALU        SynLib-Control        SynLib-DSPFIR
11:32:30 (snpslmd) SynLib-Eval        SynLib-FltTol        SynLib-PCIbasic
11:32:30 (snpslmd) Syn-Library-Compiler SynLib-Seq        SynLib-VerilogSimMdl
11:32:30 (snpslmd) SynLib-VHDLSimMdl Synopsys        Synopsys_VCS_cmv
11:32:30 (snpslmd) Synopsys-Queue        Synopsys-Release SABER_MODELSIM_MM
11:32:30 (snpslmd) SynopsysCustomICCLink SynopsysCustomLayout SynopsysCustomSAE
11:32:30 (snpslmd) SynopsysCustomSAEBatch SynopsysCustomSDL SynopsysCustomSchematic
11:32:30 (snpslmd) SK_sinterconnect_all SK_sinterconnect2d_all SK_sdevice-led_all
11:32:30 (snpslmd) SK_sdevice-mixedmode SK_sdevice-mixedmode_all SK_sdevicemonosemicond
11:32:30 (snpslmd) SK_sdevicemonosemicond_all SK_sdevice-montecarlo SK_sdevice-montecarlo_all
11:32:30 (snpslmd) SK_sdevice-noise SK_sdevice-noise_all SK_sdevice-optic
11:32:30 (snpslmd) SK_sdevice-optic_all SK_sdevice-parallel SK_sdevice-parallel_all
11:32:30 (snpslmd) SK_sdevice-parallel4 SK_sdevice-parallel4_all SK_sdevice-pmi
11:32:30 (snpslmd) SK_sdevice-pmi_all SK_sdevice-radiation SK_sdevice-radiation_all
11:32:30 (snpslmd) SK_sdevice-reliability SK_sdevice-reliability_all SK_sdevice-schroedinger
11:32:30 (snpslmd) SK_sdevice-schroedinger_all SK_sdevice-sige SK_sdevice-sige_all
11:32:30 (snpslmd) SK_sdevice-thermo SK_sdevice-thermo_all SK_sdevice-traps
11:32:30 (snpslmd) SK_sdevice-traps_all SK_sdevice-vectoroptic SK_sdevice-vectoroptic_all
11:32:30 (snpslmd) SK_sparallel        SK_sparallel_all SK_spcmlib
11:32:30 (snpslmd) SK_spcmlib_all        SK_spcmstd        SK_spcmstd_all
11:32:30 (snpslmd) SK_spcmtcl        SK_spcmtcl_all        SK_sprocess
11:32:30 (snpslmd) SK_sprocess_all SK_sprocess2d        SK_sprocess2d_all
11:32:30 (snpslmd) SK_sprocess2dmc SK_sprocess2dmc_all SK_sprocess3d
11:32:30 (snpslmd) SK_sprocess3d_all SK_sprocess3dmc SK_sprocess3dmc_all
11:32:30 (snpslmd) SK_sprocess-an-imp3d SK_sprocess-an-imp3d_all SK_sprocessmc
11:32:30 (snpslmd) SK_sprocessmc_all SK_sup2lig        SK_sup2lig_all
11:32:30 (snpslmd) SK_svisual_all        SK_swb                SK_swb_all
11:32:30 (snpslmd) SK_swb-advanced SK_swb-advanced_all SK_Tdx
11:32:30 (snpslmd) SK_Tdx_all        SK_Tecplot        SK_Tecplot_all
11:32:30 (snpslmd) SK_Ted                SK_Ted_all        SK_vsea-calib
11:32:30 (snpslmd) SK_vsea-calib_all SKDB_Import        SNPS-Assertions
11:32:30 (snpslmd) SNPS-CSL        SNPS-Keygen        SNPS-MOTIVE
11:32:30 (snpslmd) SolarGAII        SolarII                SPARTAN
11:32:30 (snpslmd) SPARTAN2        SPARTAN2E        SPARTANXL
11:32:30 (snpslmd) SPECTRAL        SPECTRAL_MEMSSE ST_LIBRARY
11:32:30 (snpslmd) Stamp-Compiler        STAR-ASCII        STAR-CR
11:32:30 (snpslmd) SK_emw_all        SK_emw-farfield SK_emw-farfield_all
11:32:30 (snpslmd) SK_emw-nonuniform-3d SK_emw-nonuniform-3d_all SK_emw-sdevice
11:32:30 (snpslmd) SK_emw-sdevice_all SK_emw-static        SK_emw-static_all
11:32:30 (snpslmd) SK_emw-thermal        SK_emw-thermal_all SK_emw-uniform-3d
11:32:30 (snpslmd) SK_emw-uniform-3d_all SK_Floops-1D        SK_Floops-1D_all
11:32:30 (snpslmd) SK_Floops-1D-MC SK_Floops-1D-MC_all SK_Floops-2D
11:32:30 (snpslmd) SK_Floops-2D_all SK_Floops-2D-MC SK_Floops-2D-MC_all
11:32:30 (snpslmd) SK_Floops-3D        SK_Floops-3D_all SK_Floops-3D-MC
11:32:30 (snpslmd) SK_Floops-3D-MC_all SK_GENESISe        SK_GENESISe_all
11:32:30 (snpslmd) SK_Inspect        SK_Inspect_all        SK_Ligament
11:32:30 (snpslmd) SK_Ligament_all SK_LigamentFE        SK_LigamentFE_all
11:32:30 (snpslmd) SK_Mesh1D        SK_Mesh1D_all        SK_Mesh2D
11:32:30 (snpslmd) SK_Mesh2D_all        SK_Mesh3D        SK_Mesh3D_all
11:32:30 (snpslmd) SK_Noffset-2D        SK_Noffset-2D_all SK_Noffset-3D
11:32:30 (snpslmd) SK_Noffset-3D_all SK_OptimISE-DOE SK_OptimISE-DOE_all
11:32:30 (snpslmd) SK_OptimISE-Iterative SK_OptimISE-Iterative_all SK_OptimISE-RSMOpt
11:32:30 (snpslmd) SK_OptimISE-RSMOpt_all SK_OptimISE-Statistical SK_OptimISE-Statistical_all
11:32:30 (snpslmd) SK_ProcessExplorer SK_ProcessExplorer_all SK_Prolyt
11:32:30 (snpslmd) SK_Prolyt_all        SK_sde                SK_sde_all
11:32:30 (snpslmd) SK_sde3d        SK_sde3d_all        SK_sdevice
11:32:30 (snpslmd) SK_sdevice_all        SK_sdevice-3d        SK_sdevice-3d_all
11:32:30 (snpslmd) SK_sdevice-densitygrad SK_sdevice-densitygrad_all SK_sdevice-ferro
11:32:30 (snpslmd) SK_sdevice-ferro_all SK_sdevice-floatinggate SK_sdevice-floatinggate_all
11:32:30 (snpslmd) SK_sdevice-gateleakage SK_sdevice-gateleakage_all SK_sdevice-hetero
11:32:30 (snpslmd) SK_sdevice-hetero_all SK_sdevice-hydro SK_sdevice-hydro_all
11:32:30 (snpslmd) SK_sdevice-kpgain SK_sdevice-kpgain_all SK_sdevice-laser
11:32:30 (snpslmd) SK_sdevice-laser_all SK_sdevice-led        SK_Dessis-Ferro_all
11:32:30 (snpslmd) SK_Dessis-FloatingGate SK_Dessis-FloatingGate_all SK_Dessis-GateLeakage
11:32:30 (snpslmd) SK_Dessis-GateLeakage_all SK_Dessis-Hetero SK_Dessis-Hetero_all
11:32:30 (snpslmd) SK_Dessis-Hydro SK_Dessis-Hydro_all SK_Dessis-kpGain
11:32:30 (snpslmd) SK_Dessis-kpGain_all SK_Dessis-Laser SK_Dessis-Laser_all
11:32:30 (snpslmd) SK_Dessis-LED        SK_Dessis-LED_all SK_Dessis-MixedMode
11:32:30 (snpslmd) SK_Dessis-MixedMode_all SK_Dessis-Mono-Semicond SK_Dessis-Mono-Semicond_all
11:32:30 (snpslmd) SK_Dessis-MonteCarlo SK_Dessis-MonteCarlo_all SK_Dessis-Noise
11:32:30 (snpslmd) SK_Dessis-Noise_all SK_Dessis-Optic SK_Dessis-Optic_all
11:32:30 (snpslmd) SK_Dessis-Parallel SK_Dessis-Parallel_all SK_Dessis-Parallel4
11:32:30 (snpslmd) SK_Dessis-Parallel4_all SK_Dessis-PMI        SK_Dessis-PMI_all
11:32:30 (snpslmd) SK_Dessis-Radiation SK_Dessis-Radiation_all SK_Dessis-Reliability
11:32:30 (snpslmd) SK_Dessis-Reliability_all SK_Dessis-Schroedinger SK_Dessis-Schroedinger_all
11:32:30 (snpslmd) SK_Dessis-SiGe        SK_Dessis-SiGe_all SK_Dessis-Thermo
11:32:30 (snpslmd) SK_Dessis-Thermo_all SK_Dessis-Traps SK_Dessis-Traps_all
11:32:30 (snpslmd) SK_Dessis-VectorOptic SK_Dessis-VectorOptic_all SK_Devise
11:32:30 (snpslmd) SK_Devise_all        SK_Devise-3D        SK_Devise-3D_all
11:32:30 (snpslmd) SK_Dfisetools        SK_Dfisetools_all SK_Dip
11:32:30 (snpslmd) SK_Dip_all        SK_Emlab        SK_Emlab_all
11:32:30 (snpslmd) SK_Emlab-Dessis SK_Emlab-Dessis_all SK_Emlab-Farfield
11:32:30 (snpslmd) SK_Emlab-Farfield_all SK_Emlab-Nonuniform-2D SK_Emlab-Nonuniform-2D_all
11:32:30 (snpslmd) SK_Emlab-Nonuniform-3D SK_Emlab-Nonuniform-3D_all SK_Emlab-Static
11:32:30 (snpslmd) SK_Emlab-Static_all SK_Emlab-Thermal SK_Emlab-Thermal_all
11:32:30 (snpslmd) SK_Emlab-Uniform-2D SK_Emlab-Uniform-2D_all SK_Emlab-Uniform-3D
11:32:30 (snpslmd) SK_Emlab-Uniform-3D_all SK_emw                S4
11:32:30 (snpslmd) S4ED                S4EI                SABER_BUNDLE
11:32:30 (snpslmd) SABER_DEV_MM        SABER_DEV_MMP        SABER_GUIDE
11:32:30 (snpslmd) SABER_GUIDE_MEMSSE SABER_HARNESS        SABER_HARNESS_NETLISTER
11:32:30 (snpslmd) SABER_IF        SABER_INTERFACE SABER_INTERFACE_MEMSSE
11:32:30 (snpslmd) SABER_LEAPFROG_MM SABER_MODELSIM_MM_MEMSSE SABER_MODELSIM_PLUS_MM
11:32:30 (snpslmd) SABER_MODELSIM_PLUS_MM_MEMSSE SABER_MODELSIM_VHDL_MM SABER_MODELSIM_VHDL_MM_MEMSSE
11:32:30 (snpslmd) SABER_MODELSIM_VLOG_MM SABER_PLUGNSIM_MM SABER_QSIM_MM
11:32:30 (snpslmd) SABER_QVSPRO_MM SABER_RT_MM        SABER_RT_MM_MEMSSE
11:32:30 (snpslmd) SABER_RUNTIME        SABER_SCOPE        SABER_SCOPE_MEMSSE
11:32:30 (snpslmd) SABER_SCOPE_NETLIST SABER_SIMMATRIX_MM SABER_SIMULATOR
11:32:30 (snpslmd) SABER_SIMULATOR_MEMSSE SABER_SKETCH        SABER_SKETCH_MEMSSE
11:32:30 (snpslmd) SABER_SKETCH_NETLIST SABER_SKETCH_NETLISTER SABER_SKETCH_NETLISTER_MEMSSE
11:32:30 (snpslmd) SABER_TSP        SABER_VERILOG_MM SABER_VERILOG_MM_MEMSSE
11:32:30 (snpslmd) SABER_VHDLAMS        SABER_VHDLAMS_MEMSSE SABER_VIEWSIM_MM
11:32:30 (snpslmd) SABER_VIEWSIM_MM_MEMSSE SABERRT_ADI        SABERRT_ADI_MEMSSE
11:32:30 (snpslmd) SABERRT_AP2633        SABERRT_FE        SABERRT_FE_MEMSSE
11:32:30 (snpslmd) SABERRT_HIL        SABERRT_HIL_MEMSSE SCAN_TOOL
11:32:30 (snpslmd) SCAN_TOOL_MEMSSE SC-BC                SC-COSIM
11:32:30 (snpslmd) SC-FPGA                SC-HLS                SC-KAZAM
11:32:30 (snpslmd) SC-RTL                SENSITIVITY        SENSITIVITY_MEMSSE
11:32:30 (snpslmd) SEU                SGE-DC-Interface SGE-EDIF-Interface
11:32:30 (snpslmd) SGE-Tool        SGE-Verilog-Interface SGE-VHDL-Interface
11:32:30 (snpslmd) ShortCut-DC-Expert ShortCut-DC-Pro Shortcut-FPGA
11:32:30 (snpslmd) Siloti                Siloti_fe        Siloti_o2
11:32:30 (snpslmd) SilVE                SimVE                SJCL_LIBRARY
11:32:30 (snpslmd) SK_alien2lig        SK_alien2lig_all SK_amat-calib
11:32:30 (snpslmd) SK_amat-calib_all SK_AN-Impl3D        SK_AN-Impl3D_all
11:32:30 (snpslmd) SK_Dessis        SK_Dessis_all        SK_Dessis-3D
11:32:30 (snpslmd) SK_Dessis-3D_all SK_Dessis-DensityGrad SK_Dessis-DensityGrad_all
11:32:30 (snpslmd) SK_Dessis-Ferro RA                RailMacro
11:32:30 (snpslmd) RCXTEO                Reusner                RMAN_RUN
11:32:30 (snpslmd) RouteCompiler        RT54SXS                RTL-Analyzer
11:32:30 (snpslmd) RTL-Analyzer-DAP RTL-Analyzer-Shell RTL-Analyzer-Shell-DAP
11:32:30 (snpslmd) RtlGateCorrelation RTL-Power-Analysis QLOGIC
11:32:30 (snpslmd) QT                Quantum38k        ParDiSo_all
11:32:30 (snpslmd) Parse-Tree-Translator Pathmill-migrate Pathmill-plus-migrate
11:32:30 (snpslmd) PAW                PC-Expert        PhysOpt
11:32:30 (snpslmd) PhysOpt-Beta        PhysOpt-Beta-CTS PhysOpt-Beta-Milkyway
11:32:30 (snpslmd) PhysOpt-Beta-Route PhysOpt-Beta-SI PhysOpt-ClockTree
11:32:30 (snpslmd) PhysOpt-Extraction PhysOpt-GUI        PhysOpt-Hierarchy
11:32:30 (snpslmd) PhysOpt-Integration PhysOpt-MV        PhysOpt-Onroute
11:32:30 (snpslmd) PhysOpt-Parallel PhysOpt-Route        PhysOpt-Route-TD
11:32:30 (snpslmd) PhysOpt-Routing PhysOpt-SI        PhysOpt-Ultra
11:32:30 (snpslmd) PhysOpt-VH        PhysOpt-XG        PLACEHOLDER
11:32:30 (snpslmd) PlanetPL        PlanetRTL        PM
11:32:30 (snpslmd) PNET_LIBRARY        PNEU_HYD_LIBRARY PNEUM_HYD_PRG1
11:32:30 (snpslmd) POLARIS_SCOPE        POLARIS_X        POWER_EXPRESS
11:32:30 (snpslmd) Power-Analysis        Power-Optimization Power-Optimization-Beta1
11:32:30 (snpslmd) Power-Optimization-Beta2 Power-Optimization-Upgrade PPPRT
11:32:30 (snpslmd) Primepower        Primepower_gui        PrimeRail
11:32:30 (snpslmd) PrimeRail-adv        PrimeRail-New-Technology PrimeRail-static
11:32:30 (snpslmd) PrimeTime        PrimeTime_gui        PrimeTime-New-Technology
11:32:30 (snpslmd) PrimeTime-Plus        PrimeTime-PX        PrimeTime-PX-New-Technology
11:32:30 (snpslmd) PrimeTime-PX-Statistical PrimeTime-SI        PrimeTime-VX
11:32:30 (snpslmd) ProcessExplorer ProcessExplorer_all ProcessExplorer_ise
11:32:30 (snpslmd) ProcessExplorer_ise_all Prolyt                Prolyt_all
11:32:30 (snpslmd) Prolyt_ise        Prolyt_ise_all        ProMA-L1
11:32:30 (snpslmd) ProMA-L2        ProMA-LD        ProMA-P1
11:32:30 (snpslmd) ProMA-P2        ProMA-PD        Protocol-Compiler-Analysis
11:32:30 (snpslmd) Protocol-Compiler-COutput Protocol-Compiler-FML Protocol-Compiler-Synth
11:32:30 (snpslmd) Protocol-Compiler-UI PS_CTS                PS_Extraction
11:32:30 (snpslmd) PS_Noise_Optimization PSG-SDE                PsynGui-AARender
11:32:30 (snpslmd) PsynGui-ChipMap PVCSCompiler_Net PVCSRuntime_Net
11:32:30 (snpslmd) OPT_TEMPLATE_LIB OPT_TEMPLATE_LIB_MEMSSE OptimISE-DOE
11:32:30 (snpslmd) OptimISE-DOE_all OptimISE-DOE_ise OptimISE-DOE_ise_all
11:32:30 (snpslmd) OptimISE-Iterative OptimISE-Iterative_all OptimISE-Iterative_ise
11:32:30 (snpslmd) OptimISE-Iterative_ise_all OptimISE-RSMOpt OptimISE-RSMOpt_all
11:32:30 (snpslmd) OptimISE-RSMOpt_ise OptimISE-RSMOpt_ise_all OptimISE-Statistical
11:32:30 (snpslmd) OptimISE-Statistical_all OptimISE-Statistical_ise OptimISE-Statistical_ise_all
11:32:30 (snpslmd) ORCA2A                ORCA2TB                ORCA3C
11:32:30 (snpslmd) ORCA3FPSC        ORCA3L                ORCA4E
11:32:30 (snpslmd) NanoTime        NanoTime-PathMill-Shared NanoTime-ultra
11:32:30 (snpslmd) NCX                NCX-addon        NET-TRAN
11:32:30 (snpslmd) Noffset-2D        Noffset-2D_all        Noffset-2D_ise
11:32:30 (snpslmd) Noffset-2D_ise_all Noffset-3D        Noffset-3D_all
11:32:30 (snpslmd) Noffset-3D_ise        Noffset-3D_ise_all Nova-ExploreRTL-Verilog
11:32:30 (snpslmd) NP                MOS_TOOL        MOS_TOOL_MEMSSE
11:32:30 (snpslmd) MOTIVE-PrimeTime MOTOR_DCPM_TOOL MOTOR_DCPM_TOOL_MEMSSE
11:32:30 (snpslmd) MV-Astro-Opt        MVerilog        MV-Opt
11:32:30 (snpslmd) MWAPIaccess        MWAPIdev        MVRC
11:32:30 (snpslmd) MVSIM                MACH1                MACH2
11:32:30 (snpslmd) MACH3                MACH4                MACH5
11:32:30 (snpslmd) MAdv                Magellan        Magellan-Shell
11:32:30 (snpslmd) Magellan-Sim        Magellan-TB        Mars
11:32:30 (snpslmd) MAST_COMPILER        MAX3000A        MAX7000
11:32:30 (snpslmd) MAX7000A        MAX7000AE        MAX7000B
11:32:30 (snpslmd) MAX7000E        MAX7000S        MAX9000
11:32:30 (snpslmd) MCD                MCE                MCE-Base
11:32:30 (snpslmd) MCE-Eval        MCE-Lib-ALU        MCE-Lib-Arith1
11:32:30 (snpslmd) MCE-Lib-Arith2        MCE-Lib-Arith3        MCE-Lib-Logic
11:32:30 (snpslmd) MC-Pro                MC-Pro-RP        MC-Retime
11:32:30 (snpslmd) MD                MDAM                MDataCheck
11:32:30 (snpslmd) MDataPrep        MDCA                MDHJ
11:32:30 (snpslmd) MDLT                MDOD                MDPD
11:32:30 (snpslmd) MDTC                MDynLink        MEASURE
11:32:30 (snpslmd) MEASURE_MEMSSE        MEMPRO                MEMPRO-LIB
11:32:30 (snpslmd) MEMS                MENTOR_FRAMEWAY MENTOR_FRAMEWAY_MEMSSE
11:32:30 (snpslmd) MENTOR_NETLISTER MENTOR_NETLISTER_MEMSSE Mentor-Interface
11:32:30 (snpslmd) MERCURY                Mesh1D                Mesh1D_all
11:32:30 (snpslmd) Mesh1D_ise        Mesh1D_ise_all        Mesh2D
11:32:30 (snpslmd) Mesh2D_all        Mesh2D_ise        Mesh2D_ise_all
11:32:30 (snpslmd) Mesh3D                Mesh3D_all        Mesh3D_ise
11:32:30 (snpslmd) Mesh3D_ise_all        MG                MI
11:32:30 (snpslmd) MICROCOSM_LIB        MICROCOSM_LIB_MEMSSE MICROCOSM_LIB2
11:32:30 (snpslmd) MICROCOSM_LIB2_MEMSSE MICROCOSM_LIB3        MICROCOSM_LIB3_MEMSSE
11:32:30 (snpslmd) MICROCOSM_LIB4        MICROCOSM_LIB4_MEMSSE MICROCOSM_LIB5
11:32:30 (snpslmd) MICROCOSM_LIB5_MEMSSE MICROCOSM_LIB6        MICROCOSM_LIB6_MEMSSE
11:32:30 (snpslmd) MICROCOSM_LIB7        MICROCOSM_LIB7_MEMSSE MIF-Reader
11:32:30 (snpslmd) MIF-Writer        Milkyway        Milkyway-Interface
11:32:30 (snpslmd) Milkyway-MDE        Millennium-ATPG-EE Millennium-ATPG-STD
11:32:30 (snpslmd) Millennium-Beta Millennium-DRC        Millennium-Eval
11:32:30 (snpslmd) Millennium-FS        Mixed-Language        Mixed-Paradigm
11:32:30 (snpslmd) MODEL_ARCHITECT MODEL_ENCRYPTION MODEL_ENCRYPTION_MEMSSE
11:32:30 (snpslmd) MODEL_SYNTHESIS MODEL_SYNTHESIS_MEMSSE MODPEX
11:32:30 (snpslmd) MODPEX_AQUEDUCT MODPEX_ASIM        MODPEX_ATFT
11:32:30 (snpslmd) MODPEX_AWB        MODPEX_CTC        MODPEX_ELDO
11:32:30 (snpslmd) MODPEX_MARELLI        MODPEX_NOPOWER        MODPEX_PTFT
11:32:30 (snpslmd) MODPEX_SABER        MODPEX_STATIS        MODPEX_TVS
11:32:30 (snpslmd) MONTE_CARLO        MONTE_CARLO_MEMSSE Laker_AMS
11:32:30 (snpslmd) Laker_iDRC        Laker_iLVS        Laker_L1
11:32:30 (snpslmd) Laker_L2        Laker_L3        Laker_T1
11:32:30 (snpslmd) Laker_T1_LE        Laker_Viewer        Leakage-Power
11:32:30 (snpslmd) Library-Compiler Ligament        Ligament_all
11:32:30 (snpslmd) Ligament_ise        Ligament_ise_all LigamentFE
11:32:30 (snpslmd) LigamentFE_all        LigamentFE_ise        LigamentFE_ise_all
11:32:30 (snpslmd) LINK_MATLAB        LINK_MATLAB_MEMSSE LINK_XMATH
11:32:30 (snpslmd) LINYE                LMCSwift        LMCSwift_Net
11:32:30 (snpslmd) LMCSwift_Node        LO                LOAD_TOOL
11:32:30 (snpslmd) LOAD_TOOL_MEMSSE LP                LSA
11:32:30 (snpslmd) LSA_MEMSSE        LSI-Interface        LSS4E
11:32:30 (snpslmd) LTL-100                LTL-100_CIF        LTL-100_GDS
11:32:30 (snpslmd) LTL-100_NDW        LTX_LIBRARY        LYNX-DS
11:32:30 (snpslmd) LYNX-FRS        LYNX-TSL        Key-Generator
11:32:30 (snpslmd) JUAdvOptA        JUAdvOptB        JUAOPAS
11:32:30 (snpslmd) JUAPlan                JUATime                JUAUD
11:32:30 (snpslmd) JUClock                JUDP                JUOPAS
11:32:30 (snpslmd) Jupiter                JupiterXT        JupiterXT_VF
11:32:30 (snpslmd) JUPlan                JUTime                JUUD
11:32:30 (snpslmd) JUVS                IC_DESIGN_LIB        ICInteractive
11:32:30 (snpslmd) IMECH_LIBRARY        INCREMENTs        Inspect
11:32:30 (snpslmd) Inspect_all        Inspect_ise        Inspect_ise_all
11:32:30 (snpslmd) Interface-Shell Interfise_all        IQBUS_AUTHOR
11:32:30 (snpslmd) IQBUS_AUTHOR_MEMSSE IQBUS_DESIGNER        IQBUS_LIB
11:32:30 (snpslmd) IQBUS_LIB_MEMSSE IROI                ISExtract_all
11:32:30 (snpslmd) HARNESS_CATIA        HARNESS_MCADREAD HARNESS_PROCABLE
11:32:30 (snpslmd) HARNESS_UNIGRAPHICS HDL                HDL2SC_mixed
11:32:30 (snpslmd) HDL2SC_verilog        HDL2SC_vhdl        HDL-Advisor
11:32:30 (snpslmd) HDL-Advisor-Estimator HDL-Advisor-Estimator-Package HDL-Advisor-Package
11:32:30 (snpslmd) HDL-Advisor-Shell HDL-Advisor-Shell-Estimator HDL-Advisor-Shell-Estm-Package
11:32:30 (snpslmd) HDL-Advisor-Shell-Package HDL-Compiler        HDL-Compiler-Old
11:32:30 (snpslmd) HDL-Compiler-SystemVerilog HERCULES_DEBUGGER HERCULES_DEVICE
11:32:30 (snpslmd) HERCULES_DRC        HERCULES_ERC        HERCULES_HDRC
11:32:30 (snpslmd) HERCULES_HDRC-HTML HERCULES_HERC-ADV HERCULES_HERC-BASIC
11:32:30 (snpslmd) HERCULES_HLPE        HERCULES_HLVS        HERCULES_HLVS-DEBUG
11:32:30 (snpslmd) HERCULES_HLVS-HTML HERCULES_LVS        HERCULES_MANAGER
11:32:30 (snpslmd) HERCULES_MASK        HERCULES_RCE        HERCULES_VUE
11:32:30 (snpslmd) HERCULES-CRYPT_XREF_DATA HERCULES-DISTRIBUTED HERCULES-DISTRIBUTED-2
11:32:30 (snpslmd) HERCULES-DISTRIBUTED-24 HERCULES-DISTRIBUTED-24/2000.4 HERCULES-DISTRIBUTED-4
11:32:30 (snpslmd) HERCULES-DP_MT        HERCULES-EXPLORER_DRC HERCULES-EXPLORER_FILTERS
11:32:30 (snpslmd) HERCULES-EXPLORER_LVS HERCULES-FINDSHORT HERCULES-NETLIST
11:32:30 (snpslmd) HERCULES-RUN_TRAN HighLevel-Power-Analysis HighLevel-Power-Optimization
11:32:30 (snpslmd) HLS-FPGA-SystemC HLS-SystemC        HSPICE_MODEL_LIBRARY
11:32:30 (snpslmd) HSPICE_MODEL_LIBRARY_MEMSSE Hsp-vacomp        Gaia
11:32:30 (snpslmd) Galaxy_FP_Beta        Galaxy_MultiRoute4 Galaxy_MultiRoute8
11:32:30 (snpslmd) Galaxy-AdvCTS        Galaxy-AdvOpt        Galaxy-AdvRules
11:32:30 (snpslmd) Galaxy-AdvTech        Galaxy-Beta        Galaxy-CCS
11:32:30 (snpslmd) Galaxy-Common        Galaxy-CTMesh        Galaxy-DFT
11:32:30 (snpslmd) Galaxy-DFY        Galaxy-FlipChip Galaxy-FP
11:32:30 (snpslmd) Galaxy-FP-AdvCTS Galaxy-FP-AdvTech Galaxy-FP-Hier
11:32:30 (snpslmd) Galaxy-FP-MV        Galaxy-GUI-PNR        Galaxy-GUI-PSYN
11:32:30 (snpslmd) Galaxy-ICC        Galaxy-Internal-Only Galaxy-IU
11:32:30 (snpslmd) Galaxy-MCMM        Galaxy-MV        Galaxy-PNR
11:32:30 (snpslmd) Galaxy-Power        Galaxy-Prototype Galaxy-PSYN
11:32:30 (snpslmd) Galaxy-SPG        Galaxy-Zroute        Galileo
11:32:30 (snpslmd) Galileo-GUI        Galileo-Internal-Only Galileo-PnR
11:32:30 (snpslmd) Galileo-PSYN        Gate2LayoutCorrelation Gate2RTLCorrelation
11:32:30 (snpslmd) GENERICVSP        GENESISe        GENESISe_all
11:32:30 (snpslmd) GENESISe_ise        GENESISe_ise_all GRAPHICS_INTERFACE
11:32:30 (snpslmd) Gsim_dump_advance Gsim_dump_basic Gsim_framework_advance
11:32:30 (snpslmd) Gsim_framework_basic Gsim_snapshot        Gsim_wave
11:32:30 (snpslmd) GuidedTraceAnalysis FPGA-Express-ISP4000-Optimizer FPGA-Express-isp4K-Optimizer
11:32:30 (snpslmd) FPGA-Express-ISP5000-Optimizer FPGA-Express-isp5K-Optimizer FPGA-Express-isp6K-Optimizer
11:32:30 (snpslmd) FPGA-Express-isp7K-Optimizer FPGA-Express-isp8K-Optimizer FPGA-Express-MERCURY-Optimizer
11:32:30 (snpslmd) FPGA-Express-Open-Optimizer FPGA-Express-ORCA2-Optimizer FPGA-Express-ORCA3-Optimizer
11:32:30 (snpslmd) FPGA-Express-Synario-Optimizer FPGA-Express-VHDL-Base FPGA-Express-VHDL-Training
11:32:30 (snpslmd) FPGA-Express-VIRTEX-Optimizer FPGA-Express-VLOG-Base FPGA-Express-XC3k-Optimizer
11:32:30 (snpslmd) FPGA-Express-XC4k-Optimizer FPGA-Express-XC5k-Optimizer FPGA-Express-XC9k-Optimizer
11:32:30 (snpslmd) FPGA-HDL-Bundle FPGA-Library-Compiler FPGA-Option
11:32:30 (snpslmd) FPGA-VHDL-Bundle FPPRT                FPTA
11:32:30 (snpslmd) FPTime                Fridge-GUI        Fridge-Interpolator
11:32:30 (snpslmd) Fridge-Simulation FSM-Reader        FSM-Writer
11:32:30 (snpslmd) FUSE_CHAR        FUSE_CHAR_MEMSSE FusionVantageLmcInterface
11:32:30 (snpslmd) FAILURE_MODE        FAILURE_MODE_MEMSSE FASTPARTS
11:32:30 (snpslmd) FCII-Altera-Edition FCO                FL_cosim_run
11:32:30 (snpslmd) FL_ice_run        FL_multichip_partition FL_recalc
11:32:30 (snpslmd) Flash370i        FLE_main        FLEX10K
11:32:30 (snpslmd) FLEX10KA        FLEX10KB        FLEX10KE
11:32:30 (snpslmd) FLEX6000        FLEX8000        Floops-1D
11:32:30 (snpslmd) Floops-1D_all        Floops-1D_ise        Floops-1D_ise_all
11:32:30 (snpslmd) Floops-1D-MC        Floops-1D-MC_all Floops-1D-MC_ise
11:32:30 (snpslmd) Floops-1D-MC_ise_all Floops-2D        Floops-2D_all
11:32:30 (snpslmd) Floops-2D_ise        Floops-2D_ise_all Floops-2D-MC
11:32:30 (snpslmd) Floops-2D-MC_all Floops-2D-MC_ise Floops-2D-MC_ise_all
11:32:30 (snpslmd) Floops-3D        Floops-3D_all        Floops-3D_ise
11:32:30 (snpslmd) Floops-3D_ise_all Floops-3D-MC        Floops-3D-MC_all
11:32:30 (snpslmd) Floops-3D-MC_ise Floops-3D-MC_ise_all Floops-Parallel_all
11:32:30 (snpslmd) Floops-Parallel4_all Floorplan-Management Formality
11:32:30 (snpslmd) Formality-Beta1 Formality-Beta2 Formality-Distributed
11:32:30 (snpslmd) Formality-DV        Formality-E1        Formality-ESP
11:32:30 (snpslmd) Formality-TransForm Formality-Transit Formality-TX
11:32:30 (snpslmd) FPABP                FPDP                FPGA_Express-APROA-Optimizer
11:32:30 (snpslmd) FPGA-Compiler        FPGA-Express        FPGA-Express-32OODx-Optimizer
11:32:30 (snpslmd) FPGA-Express-A1200XL-Optimizer FPGA-Express-A1400-Optimizer FPGA-Express-A3200DX-Optimizer
11:32:30 (snpslmd) FPGA-Express-A42MX-Optimizer FPGA-Express-A54SX-Optimizer FPGA-Express-APEX2-Optimizer
11:32:30 (snpslmd) FPGA-Express-APROA-Optimizer FPGA-Express-Constraint-Mgr FPGA-Express-EP20k-Optimizer
11:32:30 (snpslmd) FPGA-Express-EPF10k-Optimizer FPGA-Express-EPF6k-Optimizer FPGA-Express-EPF8k-Optimizer
11:32:30 (snpslmd) FPGA-Express-EPM7k-Optimizer FPGA-Express-EPM9k-Optimizer FPGA-Express-GAT
11:32:30 (snpslmd) FPGA-Express-isp1K-Optimizer FPGA-Express-isp2K-Optimizer FPGA-Express-isp3K-Optimizer
11:32:30 (snpslmd) E3                E5                E502
11:32:30 (snpslmd) E505                E520                Early-Access-Technology
11:32:30 (snpslmd) ECL-Compiler        ECO-Compiler        EDIF_NETLISTER
11:32:30 (snpslmd) EDIF_NETLISTER_MEMSSE EDIF-Netlist-Read-DC EDIF-Netlist-Write-DC
11:32:30 (snpslmd) EDIF-Netlist-Writer EDIF-Reader        EDIF-Schematic-Writer
11:32:30 (snpslmd) ELGRECO_Davis        ELGRECO_DesignCenter ELGRECO_Simulator
11:32:30 (snpslmd) Emlab                Emlab_all        Emlab_ise
11:32:30 (snpslmd) Emlab_ise_all        Emlab-Dessis        Emlab-Dessis_all
11:32:30 (snpslmd) Emlab-Dessis_ise Emlab-Dessis_ise_all Emlab-Farfield
11:32:30 (snpslmd) Emlab-Farfield_all Emlab-Farfield_ise Emlab-Farfield_ise_all
11:32:30 (snpslmd) Emlab-Nonuniform-2D Emlab-Nonuniform-2D_all Emlab-Nonuniform-2D_ise
11:32:30 (snpslmd) Emlab-Nonuniform-2D_ise_all Emlab-Nonuniform-3D Emlab-Nonuniform-3D_all
11:32:30 (snpslmd) Emlab-Nonuniform-3D_ise Emlab-Nonuniform-3D_ise_all Emlab-Static
11:32:30 (snpslmd) Emlab-Static_all Emlab-Static_ise Emlab-Static_ise_all
11:32:30 (snpslmd) Emlab-Thermal        Emlab-Thermal_all Emlab-Thermal_ise
11:32:30 (snpslmd) Emlab-Thermal_ise_all Emlab-Uniform-2D Emlab-Uniform-2D_all
11:32:30 (snpslmd) Emlab-Uniform-2D_ise Emlab-Uniform-2D_ise_all Emlab-Uniform-3D
11:32:30 (snpslmd) Emlab-Uniform-3D_all Emlab-Uniform-3D_ise Emlab-Uniform-3D_ise_all
11:32:30 (snpslmd) ENACE                ENACS                Enterprise
11:32:30 (snpslmd) Enterprise_VO        Equation-Reader Equation-Writer
11:32:30 (snpslmd) Espresso-Reader Espresso-Writer EssentialSignalAnalysis
11:32:30 (snpslmd) Estm-HDL-Advisor Estm-HDL-Advisor-Package EV-ACCESS
11:32:30 (snpslmd) EV-ACCESS_UTIL        Eview                EXCALIBUR_ARM
11:32:30 (snpslmd) EXCALIBUR_MIPS        EXPT_EDITOR        EXPT_EDITOR_MEMSSE
11:32:30 (snpslmd) EXPT_EDITOR_PLUS EXPT_EDITOR_PLUS_MEMSSE Extraction
11:32:30 (snpslmd) Dios-MC_all        Dios-PDEF_all        Dios-SDO_all
11:32:30 (snpslmd) DiosSmall_all        Dip                Dip_all
11:32:30 (snpslmd) Dip_ise                Dip_ise_all        DIRECTMEM
11:32:30 (snpslmd) DRCYCLE_TOOL        DRCYCLE_TOOL_MEMSSE DS-Schem-Gen
11:32:30 (snpslmd) DS-Schem-Gen-Estimator-Pa DS-Schem-Gen-Estimator-Package DS-Schem-Gen-Package
11:32:30 (snpslmd) DS-Verinet        DS-Verinet-Estimator-Pack DS-Verinet-Estimator-Package
11:32:30 (snpslmd) DS-Verinet-Package DS-Vhdlnet        DS-Vhdlnet-Estimator-Pack
11:32:30 (snpslmd) DS-Vhdlnet-Estimator-Package DS-Vhdlnet-Package DV
11:32:30 (snpslmd) DVAM                DVCA                DVHJ
11:32:30 (snpslmd) DVLT                DVOD                DVPD
11:32:30 (snpslmd) DVTC                DW-Developer        DW-IP-Consultant
11:32:30 (snpslmd) DW-IP-DEBUG        DW-IP-Developer DC-FPGA-Features
11:32:30 (snpslmd) Dessis-MixedMode_ise Dessis-MixedMode_ise_all Dessis-Mono-Semicond
11:32:30 (snpslmd) Dessis-Mono-Semicond_all Dessis-Mono-Semicond_ise Dessis-Mono-Semicond_ise_all
11:32:30 (snpslmd) Dessis-MonteCarlo Dessis-MonteCarlo_all Dessis-MonteCarlo_ise
11:32:30 (snpslmd) Dessis-MonteCarlo_ise_all Dessis-Noise        Dessis-Noise_all
11:32:30 (snpslmd) Dessis-Noise_ise Dessis-Noise_ise_all Dessis-Optic
11:32:30 (snpslmd) Dessis-Optic_all Dessis-Optic_ise Dessis-Optic_ise_all
11:32:30 (snpslmd) Dessis-Parallel Dessis-Parallel_all Dessis-Parallel_ise
11:32:30 (snpslmd) Dessis-Parallel_ise_all Dessis-Parallel4 Dessis-Parallel4_all
11:32:30 (snpslmd) Dessis-Parallel4_ise Dessis-Parallel4_ise_all Dessis-PMI
11:32:30 (snpslmd) Dessis-PMI_all        Dessis-PMI_ise        Dessis-PMI_ise_all
11:32:30 (snpslmd) Dessis-Radiation Dessis-Radiation_all Dessis-Radiation_ise
11:32:30 (snpslmd) Dessis-Radiation_ise_all Dessis-Reliability Dessis-Reliability_all
11:32:30 (snpslmd) Dessis-Reliability_ise Dessis-Reliability_ise_all Dessis-Schroedinger
11:32:30 (snpslmd) Dessis-Schroedinger_all Dessis-Schroedinger_ise Dessis-Schroedinger_ise_all
11:32:30 (snpslmd) Dessis-SiGe        Dessis-SiGe_all Dessis-SiGe_ise
11:32:30 (snpslmd) Dessis-SiGe_ise_all Dessis-Thermo        Dessis-Thermo_all
11:32:30 (snpslmd) Dessis-Thermo_ise Dessis-Thermo_ise_all Dessis-Traps
11:32:30 (snpslmd) Dessis-Traps_all Dessis-Traps_ise Dessis-Traps_ise_all
11:32:30 (snpslmd) Dessis-VectorOptic Dessis-VectorOptic_all Dessis-VectorOptic_ise
11:32:30 (snpslmd) Dessis-VectorOptic_ise_all Devise                Devise_all
11:32:30 (snpslmd) Devise_ise        Devise_ise_all        Devise-3D
11:32:30 (snpslmd) Devise-3D_all        Devise-3D_ise        Devise-3D_ise_all
11:32:30 (snpslmd) DF                Dfisetools        Dfisetools_all
11:32:30 (snpslmd) Dfisetools_ise        Dfisetools_ise_all Dfisetools-Topo_all
11:32:30 (snpslmd) DIODE_TOOL        DIODE_TOOL_MEMSSE Dios_all
11:32:30 (snpslmd) Dios-3D_all        DesignWare-MemoryBist-Source DesignWare-MGI
11:32:30 (snpslmd) DesignWare-MPEG DesignWare-MPEG2 DesignWare-MPEG2-Source
11:32:30 (snpslmd) DesignWare-MPEG2-VDEC DesignWare-MPEG2-VDEC-Source DesignWare-MPEG-Source
11:32:30 (snpslmd) DesignWare-Package DesignWare-PCI        DesignWare-PCIbasic
11:32:30 (snpslmd) DesignWare-PCI-Source DesignWare-PCI-X DesignWare-PCI-X-Source
11:32:30 (snpslmd) DESIGNWARE-REGRESSION DESIGNWARE-SIO-VIP DesignWare-SystemIO
11:32:30 (snpslmd) DesignWare-SystemIO-Source DesignWare-TCA        DesignWare-TCA-Source
11:32:30 (snpslmd) DesignWare-USB        DesignWare-USB2 DesignWare-USB2-Source
11:32:30 (snpslmd) DesignWare-USB-Source DESIGNWARE-USB-VIP DesignWare-VERA
11:32:30 (snpslmd) DESIGNWARE-VERIFICATION Dessis                Dessis_all
11:32:30 (snpslmd) Dessis_ise        Dessis_ise_all        Dessis-3D
11:32:30 (snpslmd) Dessis-3D_all        Dessis-3D_ise        Dessis-3D_ise_all
11:32:30 (snpslmd) Dessis-BONSIM_all Dessis-DensityGrad Dessis-DensityGrad_all
11:32:30 (snpslmd) Dessis-DensityGrad_ise Dessis-DensityGrad_ise_all Dessis-Ferro
11:32:30 (snpslmd) Dessis-Ferro_all Dessis-Ferro_ise Dessis-Ferro_ise_all
11:32:30 (snpslmd) Dessis-FloatingGate Dessis-FloatingGate_all Dessis-FloatingGate_ise
11:32:30 (snpslmd) Dessis-FloatingGate_ise_all Dessis-GateLeakage Dessis-GateLeakage_all
11:32:30 (snpslmd) Dessis-GateLeakage_ise Dessis-GateLeakage_ise_all Dessis-Hetero
11:32:30 (snpslmd) Dessis-Hetero_all Dessis-Hetero_ise Dessis-Hetero_ise_all
11:32:30 (snpslmd) Dessis-Hydro        Dessis-Hydro_all Dessis-Hydro_ise
11:32:30 (snpslmd) Dessis-Hydro_ise_all Dessis-kpGain        Dessis-kpGain_all
11:32:30 (snpslmd) Dessis-kpGain_ise Dessis-kpGain_ise_all Dessis-Laser
11:32:30 (snpslmd) Dessis-Laser_all Dessis-Laser_ise Dessis-Laser_ise_all
11:32:30 (snpslmd) Dessis-LED        Dessis-LED_all        Dessis-LED_ise
11:32:30 (snpslmd) Dessis-LED_ise_all Dessis-MixedMode Dessis-MixedMode_all
11:32:30 (snpslmd) D3                DataExpansion        DataExpansionCoverage
11:32:30 (snpslmd) DataExpansionSim DATAIO                DataReplay
11:32:30 (snpslmd) DataReplaySim        DB-Mode                DC64
11:32:30 (snpslmd) DC-Beta                DC-Cadence-Interface DC-Expert
11:32:30 (snpslmd) DCExpert-PrimeTime DC-Extension        DC-Falcon-Interface
11:32:30 (snpslmd) DC-FPGA-Accelerator DC-FPGA-Add-On        DC-FPGA-Add-On-to-DC
11:32:30 (snpslmd) DC-FPGA-INCREMENTs DC-Layout-Interface DCM-Delay-Calculation
11:32:30 (snpslmd) DC-Min-Area-Retime DC-SDF-Interface DCT-Congestion
11:32:30 (snpslmd) DCT-GUI                DC-Topographical DC-Ultra
11:32:30 (snpslmd) DC-Ultra-Features DC-Ultra-INCREMENTs DC-Ultra-Opt
11:32:30 (snpslmd) DC-XG                DE                Debussy
11:32:30 (snpslmd) Debussy_shared        Delta39k        DEMO
11:32:30 (snpslmd) Design-Analyzer Design-Analyzer-DAP Design-Budgeting
11:32:30 (snpslmd) Design-Compiler Design-Estimator Design-Estimator-FPI
11:32:30 (snpslmd) Design-Expert        DesignSource        DesignSource-Estimator-Package
11:32:30 (snpslmd) DesignSource-Package DESIGNSTAR        DESIGNSTAR_NET
11:32:30 (snpslmd) DesignTime        Design-Vision        DesignWare
11:32:30 (snpslmd) DesignWare-1394 DesignWare-1394-Source DesignWare-6811-Source
11:32:30 (snpslmd) DesignWare-8051 DesignWare-8051MCU DesignWare-8051-Source
11:32:30 (snpslmd) DesignWare-AMBA-tlm DESIGNWARE-AMBA-VIP DesignWare-ARMCORES-tlm
11:32:30 (snpslmd) Designware-Basic DesignWare-BIST DesignWare-BIST-Source
11:32:30 (snpslmd) DesignWare-Cardbus Designware-Developer DesignWare-Developer-MGI
11:32:30 (snpslmd) DesignWare-ETHERNET DesignWare-ETHERNET-Source DESIGNWARE-ETHERNET-VIP
11:32:30 (snpslmd) DesignWare-FloatingPoint DesignWare-Foundation DesignWare-Foundation-Exp
11:32:30 (snpslmd) DesignWare-Foundation-Expert DesignWare-Foundation-Power DesignWare-Foundation-Ultra
11:32:30 (snpslmd) Designware-FPGA-Basic DESIGNWARE-I2C-VIP DesignWare-ISA-PnP
11:32:30 (snpslmd) DesignWare-MEMCTL-Source DesignWare-MemoryBist Cyclone-Simulator
11:32:30 (snpslmd) Cyclone-VHDL-Analyzer CYPRESS                COSSAP_gsmfrsc
11:32:30 (snpslmd) COSSAP_gsmhrcc        COSSAP_dcg_ariel32c COSSAP_dcg_fe
11:32:30 (snpslmd) COSSAP_dcg_gc        COSSAP_dcg_krc        COSSAP_dcg_lsic30s
11:32:30 (snpslmd) COSSAP_dcg_m96000 COSSAP_dcg_mp        COSSAP_ddk_arm
11:32:30 (snpslmd) COSSAP_ddk_devlp COSSAP_ddk_dsp16000 COSSAP_ddk_dsp1610
11:32:30 (snpslmd) COSSAP_ddk_hawk COSSAP_ddk_nec        COSSAP_ddk_oak
11:32:30 (snpslmd) COSSAP_ddk_pine COSSAP_ddk_ssp16xx COSSAP_ddk_tic5x
11:32:30 (snpslmd) COSSAP_ddk_tic5xx COSSAP_dect        COSSAP_dvb
11:32:30 (snpslmd) COSSAP_ecc        COSSAP_gsmdve        COSSAP_gsmdve_utils
11:32:30 (snpslmd) COSSAP_gsmefrsc COSSAP_gsmeq        COSSAP_gsmfrcc
11:32:30 (snpslmd) COSSAP_gsmhrsc        COSSAP_gsmphy        COSSAP_is136
11:32:30 (snpslmd) COSSAP_is95        COSSAP_matlab        COSSAP_mfd
11:32:30 (snpslmd) COSSAP_mpeg2        COSSAP_pdc        COSSAP_qed
11:32:30 (snpslmd) COSSAP_sds        COSSAP_srcfd        COSSAP_vcg_generic
11:32:30 (snpslmd) COSSAP_vcg_synopsys COSSAP_vcg_vantage COSSAP_vdefcg
11:32:30 (snpslmd) COSSAP_vdefcg_vlgxl COSSAP_vsiccg        COSSAP_vsiccg_cyc
11:32:30 (snpslmd) COSSAP_vsiccg_mti COSSAP_vsiccg_mtivlg COSSAP_vsiccg_vcs
11:32:30 (snpslmd) COSSAP_vsiccg_vlgxl COSSAP_vsivcg        COSSAP_vsivcg_vlgxl
11:32:30 (snpslmd) COSSAP_xdcg        COSSAP_xvcg        COSSAP_xvsi
11:32:30 (snpslmd) COVENTOR_LIB10        COVENTOR_LIB10_MEMSSE COVENTOR_LIB11
11:32:30 (snpslmd) COVENTOR_LIB11_MEMSSE COVENTOR_LIB12        COVENTOR_LIB12_MEMSSE
11:32:30 (snpslmd) COVENTOR_LIB13        COVENTOR_LIB13_MEMSSE COVENTOR_LIB14
11:32:30 (snpslmd) COVENTOR_LIB14_MEMSSE COVENTOR_LIB15        COVENTOR_LIB15_MEMSSE
11:32:30 (snpslmd) COVENTOR_LIB8        COVENTOR_LIB8_MEMSSE COVENTOR_LIB9
11:32:30 (snpslmd) COVENTOR_LIB9_MEMSSE CoverMeter        CoverMeterOBC
11:32:30 (snpslmd) CoverMeterOBCVCSAMSCompiler CPI-100                CRS_COVERMETER
11:32:30 (snpslmd) CRS_VCM                CRS_VCS                CRS_VCSi
11:32:30 (snpslmd) CTV-Interface        CUSTOM_LIB        CXp_Analysis
11:32:30 (snpslmd) CXp_CircuitEnvironment CXp_GUI                Cyclone-Code-Generator
11:32:30 (snpslmd) Cyclone-Core        Cyclone-cosim        Cyclone-Elaborator
11:32:30 (snpslmd) Cyclone-GUI        Cyclone-HDL-Analyzer CA-Chip-Edit
11:32:30 (snpslmd) CA-CP-Advanced        CA-CP-Basic        CA-CP-Standard
11:32:30 (snpslmd) CADENCE_DIVA_NETLISTER CADENCE_FRAMEWAY CADENCE_FRAMEWAY_MEMSSE
11:32:30 (snpslmd) CADENCE_NETLISTER CADENCE_NETLISTER_MEMSSE CA-Foundation
11:32:30 (snpslmd) CA-Frame        CA-Hier-Timer        CA-Optimization
11:32:30 (snpslmd) CA-Timer        CA-Utils        CBA-ApolloGA-Interface
11:32:30 (snpslmd) CBA-Blk-Export        CBA-Blk-Import        CBA-CadenceSE-Interface
11:32:30 (snpslmd) CBA-DS-Beta        CBA-Frame        CBA-Logical-DS
11:32:30 (snpslmd) CBA-Logical-MA        CBA-Physical-DS CBA-Physical-MA
11:32:30 (snpslmd) CBA-Transport        CD-Compiled-Lib-Gen CD-Compiled-Sys-Gen
11:32:30 (snpslmd) CD-GDI                CD-GDII-Link        CD-Model-Developer
11:32:30 (snpslmd) CD-MSSC-Cross-Probe CD-MSSC-Netlist CD-Present-Builder
11:32:30 (snpslmd) CD-Present-Layer-Gen CD-REX                CD-Vhdlgen-Gen
11:32:30 (snpslmd) CD-Vhdlgen-GUI        CmMonitor        CmView
11:32:30 (snpslmd) CoCentric-FXD-GUI CoCentric-FXD-Interpolator CoCentric-FXD-Simulation
11:32:30 (snpslmd) CoCentric-SYS-Davis CoCentric-SYS-DesignCenter CoCentric-SYS-HWflow
11:32:30 (snpslmd) CoCentric-SYS-HWSimIF CoCentric-SYS-RDK-adsl CoCentric-SYS-RDK-cdma2000
11:32:30 (snpslmd) CoCentric-SYS-RDK-docsis CoCentric-SYS-Simulator Columbia
11:32:30 (snpslmd) ColumbiaTE        COMPONENT_LIBRARY COMPONENT_LIBRARY_MEMSSE
11:32:30 (snpslmd) CONCEPT_FRAMEWAY CONCEPT_NETLISTER Constraint_Translation
11:32:30 (snpslmd) Converter        COOLRUNNER        COOLRUNNER2
11:32:30 (snpslmd) CORENL_CHAR        CORENL_CHAR_MEMSSE COSIM-LFG
11:32:30 (snpslmd) COSIM-MTI        COSIM-NCV        COSIM-SRO
11:32:30 (snpslmd) COSIM-VCS        COSIM-VXL        COSMOS
11:32:30 (snpslmd) COSMOS_GUIDE        COSMOS_SCOPE        COSMOS_SKETCH
11:32:30 (snpslmd) COSMOS_SKETCH_BACK_ANN COSMOS_SKETCH_NETLISTER COSMOS_VO
11:32:30 (snpslmd) COSSAP_adpcm        COSSAP_adsl        COSSAP_amr
11:32:30 (snpslmd) COSSAP_arm        COSSAP_bde        COSSAP_celp
11:32:30 (snpslmd) COSSAP_chart        COSSAP_cw_filter_hdl COSSAP_cw_filter_sds
11:32:30 (snpslmd) COSSAP_dab        COSSAP_dcg_ad21020 COSSAP_dcg_ansic
11:32:30 (snpslmd) BASIC_ANALYSES        BASIC_ANALYSES_MEMSSE BATCH_MEASURE
11:32:30 (snpslmd) BATCH_MEASURE_MEMSSE BATT_TOOL        BATT_TOOL_MEMSSE
11:32:30 (snpslmd) BC-FPGA                BC-FPGA-HDL        BC-FPGA-VHDL
11:32:30 (snpslmd) BC-HDL                BC-Schedule        BC-VHDL
11:32:30 (snpslmd) Behavioral-Analyzer Behavioral-Compiler BETA_LIBRARY
11:32:30 (snpslmd) BOA-BRT                BUILD_DATE        BUILD_NUMBER
11:32:30 (snpslmd) BUNDLE_MCAD_PROJECTION A3200DX                A42MX
11:32:30 (snpslmd) A500K                A54SX                A54SXA
11:32:30 (snpslmd) A7                AARKOS-A        ABB_CHCRC_LIBRARY
11:32:30 (snpslmd) ACEX1K                ACS                ACT2-1200XL
11:32:30 (snpslmd) ACT3                AdvanceCalibration_all AdvancedCalibration_all
11:32:30 (snpslmd) AI                AIM_DEBUG        AIM_DEBUG_MEMSSE
11:32:30 (snpslmd) AIM_DECRYPT        AIM_DEVELOPER        AIM_DEVELOPER_MEMSSE
11:32:30 (snpslmd) AIM_ENCRYPT        ALTGEN1                ALTGEN2
11:32:30 (snpslmd) AN-Impl3D        AN-Impl3D_all        AN-Impl3D_ise
11:32:30 (snpslmd) AN-Impl3D_ise_all APACM                APATD
11:32:30 (snpslmd) APCS                APDP                APEX20K
11:32:30 (snpslmd) APEX20KC        APEX20KE        APEXII
11:32:30 (snpslmd) APGA4AP                APGACS                APGADP
11:32:30 (snpslmd) APGAHPO                APGApwr                APGASolar
11:32:30 (snpslmd) APGASolarII        APGATime        APHPO
11:32:30 (snpslmd) Apollo                ApolloGA        APPower
11:32:30 (snpslmd) APpwr                APRV                APSolar
11:32:30 (snpslmd) APSolarII        APTime                APXtalk
11:32:30 (snpslmd) ARKOS-A                ARKOS-B                ARKOS-C
11:32:30 (snpslmd) ARKOS-D                ARKOS-E                ARKOS-Ice
11:32:30 (snpslmd) ARKOS-Mcomp        ARKOS-Rtlcomp        ARKOS-Scomp
11:32:30 (snpslmd) ARKOS-Simul        ARM7TDMI        Astro
11:32:30 (snpslmd) AstroBeta        AstroExp        Astro-Express
11:32:30 (snpslmd) AstroGA                Astro-MV        AstroRail
11:32:30 (snpslmd) Astro-Rail        AstroRailSA        AstroSpecialBeta
11:32:30 (snpslmd) AstroXtalk        Astro-Xtalk        ATMEL
11:32:30 (snpslmd) ATMWB_ATMLAYER        ATMWB_UTOPIA        AU
11:32:30 (snpslmd) AUSP                AUT_NUMBER_MAJOR_PACKAGES 3D
11:32:30 (snpslmd) 3P
11:32:30 (snpslmd)
11:32:30 (snpslmd) Licenses are case sensitive for TE_CATS
11:32:30 (snpslmd)
11:32:30 (snpslmd) EXTERNAL FILTERS are OFF
11:32:30 (snpslmd) CANNOT OPEN options file "USE"
11:32:30 (lmgrd) snpslmd using TCP-port 54703
11:32:30 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  atrenta  avantd  CADABRA  chrysalisd  cowared  EPIC  eved  extremed  hscd  innologd  ISE-TCADd  knights  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  perflmd  riod  saber_dmn  sandwork  sclmgrd  sigmacd  SIINT  simple  snpsOEM1  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  targetld  TAVEREN  TE_CATS  tmald  vastlmd  vcsd  wlld
08/15/2024 11:32:30 (snpslmd) ------------------------------------------------------------------
08/15/2024 11:32:30 (snpslmd) Checking the integrity of the license file...
08/15/2024 11:32:30 (snpslmd) Valid SSS feature found.
08/15/2024 11:32:30 (snpslmd) The feature is needed to enable the other keys in your license file.
08/15/2024 11:32:30 (snpslmd) Licensed to student@eetop
08/15/2024 11:32:30 (snpslmd) Siteid: 26356, Server Hostid: 74563cecb190, Issued on: 1/8/2014
11:32:31 (snpslmd) SLOG: Statistics Log Frequency is 240 minute(s).
11:32:32 (snpslmd) SLOG: TS update poll interval is 0. TS update is detected by midnight reread only.
11:32:32 (snpslmd) SLOG: Activation borrow reclaim percentage is 0.
11:32:32 (snpslmd) (@snpslmd-SLOG@) ===============================================
11:32:32 (snpslmd) (@snpslmd-SLOG@) === Vendor Daemon ===
11:32:32 (snpslmd) (@snpslmd-SLOG@) Vendor daemon: snpslmd
11:32:32 (snpslmd) (@snpslmd-SLOG@) Start-Date: Thu Aug 15 2024 11:32:32 CST
11:32:32 (snpslmd) (@snpslmd-SLOG@) PID: 497738
11:32:32 (snpslmd) (@snpslmd-SLOG@) VD Version: v11.14.1.3 build 212549 x64_lsb ( build 212549 (ipv6))
11:32:32 (snpslmd) (@snpslmd-SLOG@) === Startup/Restart Info ===
11:32:32 (snpslmd) (@snpslmd-SLOG@) Options file used: USE
11:32:32 (snpslmd) (@snpslmd-SLOG@) Is vendor daemon a CVD: Yes
11:32:32 (snpslmd) (@snpslmd-SLOG@) Is TS accessed: No
11:32:32 (snpslmd) (@snpslmd-SLOG@) TS accessed for feature load: -NA-
11:32:32 (snpslmd) (@snpslmd-SLOG@) Number of VD restarts since LS startup: 0
11:32:32 (snpslmd) (@snpslmd-SLOG@) === Network Info ===
11:32:32 (snpslmd) (@snpslmd-SLOG@) Listening port: 54703
11:32:32 (snpslmd) (@snpslmd-SLOG@) Daemon select timeout (in seconds): 1
11:32:32 (snpslmd) (@snpslmd-SLOG@) === Host Info ===
11:32:32 (snpslmd) (@snpslmd-SLOG@) Host used in license file: 001
11:32:32 (snpslmd) (@snpslmd-SLOG@) Running on Hypervisor: Not determined - treat as Physical
 楼主| 发表于 2024-8-15 12:12:34 | 显示全部楼层
sssverify /opt/eda/Synopsys/scl/2018.06/admin/license/Synopsys.dat
Integrity check report for license file "/opt/eda/Synopsys/scl/2018.06/admin/license/Synopsys.dat".
Report generated on 15-Aug-2024 (SCL_2018.06)
License file integrity check PASSED!
You may now USE this license file to start your license server.
Please don't edit or manipulate the contents of this license file.
SSSVERIFY也可以通过
发表于 2024-8-15 13:46:54 | 显示全部楼层
mark, guanzhu
发表于 2024-8-15 14:01:44 | 显示全部楼层
check the compatibility between your tools and scl
发表于 2024-8-15 14:03:13 | 显示全部楼层
You can find below line on your log file.
This mean that license server name is "001".
Is your linux server name that run snpslmd "001" ?
If not,  it seems that you license file server line has an issue...  it has worong server line.
Could you try ping test with below command?
% ping 001
It shuld be next.
PING 001 (192.168.1.nn) 56(84) bytes of data.
64 bytes from 001 (192.168.1.nn): icmp_seq=1 ttl=64 time=0.034 ms
64 bytes from 001 (192.168.1.nn): icmp_seq=2 ttl=64 time=0.015 ms
64 bytes from 001 (192.168.1.nn): icmp_seq=3 ttl=64 time=0.015 ms
64 bytes from 001 (192.168.1.nn): icmp_seq=4 ttl=64 time=0.014 ms
nn : your server IP address.
If no respone for the ping test, then "Network is unreachable" is resonable.
please compare your license file below three line.
SERVER ServerName  nnmmxxyyhhdd 27050
DAEMON snpslmd snpslmd
USE_SERVER
nnmmxxyyhhdd  : 48bit mac address of your linux server.
ServerName on license file 1st line  should be linux system name.
The /etc/hosts file should same as below.
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
192.168.1.nn    ServerName loghost
192.168.1.nn : your linux server IP address
发表于 2024-8-15 14:06:07 | 显示全部楼层
You can find below message log file.
11:32:30 (snpslmd) Server started on 001 for:        SSS
This mean that your linux server name is "001".
Is it correct ?
 楼主| 发表于 2024-8-15 17:49:15 来自手机 | 显示全部楼层
right
 楼主| 发表于 2024-8-15 17:50:59 来自手机 | 显示全部楼层
找到原因了,原来不可以使用001作为hostname,可能不支持纯数字,会报错,改成英文的hostname问题解决
发表于 2024-8-16 05:02:52 | 显示全部楼层
thanks, good to know
发表于 2024-8-16 16:36:22 | 显示全部楼层
Yayaor 发表于 2024-8-15 17:50
找到原因了,原来不可以使用001作为hostname,可能不支持纯数字,会报错,改成英文的hostname问题解决 ...
Thx for share.
GMT+8, 2025-12-15 11:18 , Processed in 0.021718 second(s), 3 queries , Gzip On, Redis On.
