查看: 1485|回复: 5
[求助] 工艺安装问题1
发表于 2024-8-11 10:49:42 | 显示全部楼层 |阅读模式
1、工艺库安装时,只显示 1  LO  选项    没有RF 选项是什么原因?
2、选择金属层数和金属厚度是选择什么样的?   6X1Z1U  还是
3、1P7M   1P8M    1P9M  是啥意思,选择哪个?
发表于 2024-8-11 11:21:12 | 显示全部楼层
1P是1层poly,9M是9层金属,没有RF可能是你这个工艺库没有提供RF器件吧
发表于 2024-8-11 12:43:37 | 显示全部楼层
6X1Z1U 是指定METAL pitch width
The backend process has so much selections .
Two kinds of inter-layer metal:
     [M]x: First Inter-layer Metal, W/S=0.07μm/0.07μm.
     [M]y: Second Inter-layer Metal, W/S=0.14μm/0.14μm.
Four kinds of top-layer metal:
     [M]z (TM): top metal pitch is 0.8μm (W/S=0.4μm/0.4μm).
     [M]y (2XTM): top metal pitch is two times of [M]x pitch (W/S=0.14μm/0.14μm).
     [M]r: top metal pitch is 1.0μm (W/S=0.5μm/0.5μm)
     [M]u: top metal pitch is 3.0μm (W/S=2μm/1μm)
 楼主| 发表于 2024-8-17 22:59:29 | 显示全部楼层
Two kinds of inter-la ...
好的,谢谢
发表于 2024-8-19 16:21:05 | 显示全部楼层
大概率就是你说的这个原因
发表于 2024-9-16 23:26:36 | 显示全部楼层
Kan Kan
GMT+8, 2025-12-20 17:45 , Processed in 0.022548 second(s), 3 queries , Gzip On, Redis On.
