查看: 1623|回复: 4
[讨论] CALIBRE PEX Compilation Error
发表于 2024-8-1 15:51:03 | 显示全部楼层 |阅读模式
I have designed the post layout using SMIC18mmrf library file and passed the Caliber DRC and Caliber LVS. After I tried to Extract the layout. I received the compilation error.
I attached the image of compilation error.
These files are included in pex folder of SMIC18mmrf.
I checked the technical file and changed the layer name give name as technical file. but the compilation error is not resolved. Then I deleted the poly related code and executed the calibre pex. Again compilation error is generated with "Undefined layer parameter name parameter: metal1".
Could you please anyone provide the suggestions to resolve this error?
发表于 2024-8-1 15:59:15 | 显示全部楼层
rule file是填这个文件
发表于 2024-8-1 17:44:37 | 显示全部楼层
楼上对
发表于 2024-11-25 11:38:02 | 显示全部楼层
我也是想要的
发表于 2025-5-16 16:54:37 | 显示全部楼层
你好 可以求一份pex rule file嘛
GMT+8, 2025-10-14 03:42 , Processed in 0.015201 second(s), 4 queries , Gzip On, Redis On.
