查看: 2519|回复: 6
Error “snpslmd exited with status 255()”
发表于 2024-7-31 15:25:07 | 显示全部楼层 |阅读模式
How Can I Fix the Error “snpslmd exited with status 255()”
发表于 2024-7-31 15:34:51 | 显示全部楼层
update version
 楼主| 发表于 2024-7-31 15:47:02 | 显示全部楼层
I used SCL2023.07 version
07/29/2024 11:50:17 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_2023.09
11:50:43 (snpslmd) zs_module_count_ZS3 zs_module_count_ZS4 zs_PostRunDebug
11:50:43 (snpslmd) zs_Server
11:50:43 (snpslmd)
11:50:43 (snpslmd) Licenses are case sensitive for TE_CATS
11:50:43 (snpslmd)
11:50:43 (snpslmd) EXTERNAL FILTERS are OFF
11:50:43 (lmgrd) snpslmd using TCP-port 59533
11:50:43 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  atrenta  avantd  CADABRA  chrysalisd  cowared  doradod  EPIC  eved  extremed  fishtail  hscd  innologd  ISE-TCADd  knights  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  perflmd  riod  saber_dmn  sandwork  sclmgrd  sftlmd  sigmacd  SIINT  simple  snpsOEM1  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  targetld  TAVEREN  TE_CATS  tmald  vastlmd  vcsd  wlld
07/29/2024 11:50:48 (snpslmd) ------------------------------------------------------------------
07/29/2024 11:50:48 (snpslmd) Checking the integrity of the license file...
07/29/2024 11:50:48 (snpslmd) The SSS features are garbled.
07/29/2024 11:50:48 (snpslmd) All revenue keys ("SN=RK:..." on feature line) have been excluded.
11:50:51 (lmgrd) snpslmd exited with status 255 ()
11:50:51 (lmgrd) Since this is an unknown status, license server
11:50:51 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
11:50:51 (lmgrd) REStarted snpslmd (internet tcp_port 38277 pid 5221)
11:50:51 (snpslmd) FlexNet Licensing version v11.19.4.1 build 291070 x64_lsb
发表于 2024-7-31 16:17:07 | 显示全部楼层
update license
发表于 2024-7-31 16:17:16 | 显示全部楼层
use a lower version
发表于 2025-7-23 12:34:21 | 显示全部楼层
解决了吗
发表于 2025-7-23 13:17:47 | 显示全部楼层
07/29/2024 11:50:17 (snpslmd) Synopsys Corporate Licensing (SCL) Release: ...
conflicting information :
You said you used SCL2023.07 version.
The log shows that was SCL2023.09 version (v11.19.4.1).
In the end all your licenses get rejected and removed
In my opinion your license have a problem and it's not related to the version itself. To solve you would need to get a new license.
GMT+8, 2025-12-29 09:23 , Processed in 0.017436 second(s), 3 queries , Gzip On, Redis On.
