查看: 1240|回复: 6
[原创] Help to download TCAS1 chopper OPA
发表于 2024-7-26 10:45:54 | 显示全部楼层 |阅读模式
A 69MHz-Bandwidth 40V/μ s-Slew-Rate 3n V/√Hz-Noise 4.5 μ V-Offset Chopper Operational Amplifier
https://ieeexplore.ieee.org/document/10477024
many thanks
发表于 2024-7-26 12:03:57 | 显示全部楼层
A_69MHz-Bandwidth_40V__s-Slew-Rate_3n_V_Hz-Noise_4.5__V-Offset_Chopper_Operation.pdf
3.59 MB, 下载次数: 65 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2024-7-26 13:37:15 | 显示全部楼层
Good reference about high speed chopper amplifier for IC designers to study that ~~
Thanks~~~
 楼主| 发表于 2024-7-26 21:11:32 | 显示全部楼层
Thank you
发表于 2024-9-17 09:28:02 | 显示全部楼层
谁能帮忙下载兩篇文章,谢谢? 1、Spectral supralinearity of silicon photodiodes with over-filled illumination in the near-infrared region https://opg.optica.org/ao/abstract.cfm?uri=ao-59-26-8038   2、Experimental validation of nonlinearity suppression for an inverse-layer-type silicon photodiode and its prediction based on theoretical modeling    https://opg.optica.org/ao/abstract.cfm?uri=ao-56-21-5804
发表于 2024-9-17 09:28:56 | 显示全部楼层
kan kan
发表于 2025-7-23 16:34:12 | 显示全部楼层
学习了
GMT+8, 2025-9-14 06:40 , Processed in 0.019840 second(s), 4 queries , Gzip On, Redis On.
