查看: 2500|回复: 5
[求助] monte carlo仿真有一半的数据都是error
发表于 2024-6-21 11:29:33 | 显示全部楼层 |阅读模式
悬赏50资产已解决
用tsmc18rf库的rf的mis模型,进行Monte Carlo仿真时job log中出现如下warning,
[2024-06-20 11:24:58.198 -0400] [WARN] [cadence.virtuoso.ade.simulationMonitor] -     WARNING (CMI-2151): I0.M0.m0: Missing bulk-source diode would be forward biased. {"history": "ExplorerRun.0", "point": 32, "testname": "12Bit_20Ms_SAR_ADC_Comparator_mis_montecarlo_1", "cornername": "tt_27"}
[2024-06-20 11:24:58.198 -0400] [WARN] [cadence.virtuoso.ade.simulationMonitor] -     WARNING (CMI-2151): I0.I1.M13.m0: Missing bulk-source diode would be forward biased. {"history": "ExplorerRun.0", "point": 32, "testname": "12Bit_20Ms_SAR_ADC_Comparator_mis_montecarlo_1", "cornername": "tt_27"}
[2024-06-20 11:24:58.198 -0400] [WARN] [cadence.virtuoso.ade.simulationMonitor] -     WARNING (CMI-2744): I0.M0.dsg: Junction current density(I/Area) exceeds `imelt'. The results computed by Spectre(R) may be inaccurate because the junction current model has been linearized. {"history": "ExplorerRun.0", "point": 32, "testname": "12Bit_20Ms_SAR_ADC_Comparator_mis_montecarlo_1", "cornername": "tt_27"}
[2024-06-20 11:24:58.198 -0400] [WARN] [cadence.virtuoso.ade.simulationMonitor] -     WARNING (CMI-2744): I0.M0.dss: Junction current density(I/Area) exceeds `imelt'. The results computed by Spectre(R) may be inaccurate because the junction current model has been linearized. {"history": "ExplorerRun.0", "point": 32, "testname": "12Bit_20Ms_SAR_ADC_Comparator_mis_montecarlo_1", "cornername": "tt_27"}
warning中提到的器件:
I0.M0
I0.I1.M13:
CIW中出现如下error
ERROR (EXPLORER-2237): Failed to back up the mirror '/tmp/tmp_rdb.14325.83bc636e-c4f4-4819-99c6-e49e0d1180aa' of the /tmp database to the NFS database file '/home/analoglibs/OpenVirtuosoHereReally/12Bit_20Ms_SAR_ADC/Comparator_mis_montecarlo/maestro/results/maestro/ExplorerRun.0.rdb' due to the following error:
Error code: 1032
Error code from the NFS database file: 8
Error message from the NFS database file: attempt to write a readonly database
ConnectionId: 111
The possible reasons for this could be:
* The NFS or the /tmp RDB was deleted unintentionally
* You do not have the permission to write on the NFS location
* Insufficient disk space in NFS
* Multiple sessions are accessing the NFS location in parallel
Identify and resolve the error. If the reasons mentioned above are not causing this error, contact Cadence Customer Support and share details.
跑1500多个点,结果大部分落在一个值上,还有一半的error
以下是我的仿真设置
model setup
corner设置
monte carlo设置
卡在这里好几天了
最佳答案
查看完整内容
variation 分别试试 mismatch ,process ,感觉是model file的问题
发表于 2024-6-21 11:29:34 | 显示全部楼层
 楼主| 发表于 2024-6-21 16:16:23 | 显示全部楼层
好滴,我试试
 楼主| 发表于 2024-6-21 16:58:49 | 显示全部楼层
找到问题了,是mismatch的问题,process正常的,谢谢大佬
发表于 2024-6-21 17:02:08 | 显示全部楼层
可以拿你的50积分吗 哈哈 model file的话你可以再研究一下 先问foundry 或者自己进去看看 include的子scs文件 改改应该能用
 楼主| 发表于 2024-6-22 12:11:35 | 显示全部楼层
spartan313 发表于 2024-6-21 17:02
可以拿你的50积分吗 哈哈 model file的话你可以再研究一下 先问foundry 或者自己进去看看 include的子scs文 ...
好滴,感谢大佬
GMT+8, 2025-12-21 10:58 , Processed in 0.056656 second(s), 4 queries , Gzip On, Redis On.
