查看: 1743|回复: 4
这个SLISERV进程是个啥啊?各位有没有遇到这个进程异常终止的问题?
发表于 2024-6-4 17:57:53 | 显示全部楼层 |阅读模式
[autumn@localhost test_uvm_axi_random__dtR_91]$ cat run.err
ERROR: The application is terminated (Error Code: 501).
Please contact support center at support_center@synopsys.com.
SLI:  SLISERV process has abnormally terminated with exit code 65280, exiting...
SLI:  SLISERV process ended normally due to SIGNAL 255 runtest: Final result in test_uvm_axi_random__dtR_91/test.result - Result is "FAILED"
Result: FAILED Test: test_uvm_axi_random__dtR_91
用coreConsultant跑的是S家umctl2的UVM环境
发表于 2024-6-5 08:36:00 | 显示全部楼层
snpslmd vip license manager
发表于 2024-6-5 11:25:11 | 显示全部楼层
解密这个VP文件,然后注释掉对应的license检查。先解密,然后grep -rn "SLI" *
 楼主| 发表于 2024-6-6 11:35:22 | 显示全部楼层
感谢回复,请教下,这种svp文件是怎样解密的?
发表于 2024-6-23 22:04:47 | 显示全部楼层
您好楼主,请问你的问题解决了吗?
GMT+8, 2025-12-23 13:40 , Processed in 0.015168 second(s), 3 queries , Gzip On, Redis On.
