查看: 1797|回复: 0
[讨论] smic40nm voltus用到的gds_layermap file 帮忙看下是否ok
发表于 2024-6-3 19:38:21 | 显示全部楼层 |阅读模式
Hi,哪位大佬在s家40nms SMIC 40nm LOGIC0040LL LVT 1.10 Volt SC12 High Performance MC
用voltus做过IR drop分析, 生成一个sram macro pgv lib:
最近generate_pg_library -output ../output/macro_pgv
需要set_pg_library_mode \
    -celltype       macros \
    -ground_pins     VSSE  \
    -power_pins     {VDD 1.1 VDDPE 1.1 VDDCE 1.1} \
    -cell_list_file ../data/macro.list \
    -spice_subckts  $macro_cdl_file \
    -gds_files      $macro_gds_file   \
    -gds_layermap      ../data/gds_qrc.map \
    -current_distribution propagation \
    -spice_models   $spice_model_file \
    -spice_corners {tt bjt_tt dio_tt res_tt var_tt mom_tt ldmos_tt} \
    -stop@via     pdfCont \
    -extraction_tech_file     ${QRC_TECH_FIL}
官方pdk里面没找到qrc和gds都mapfile.根据经验看virtuos下gds map文件写了一个gds_qrc.map:
diff       pdiff            gds               43
diff       ndiff            gds               40
poly       poly             gds               30
via        pdfCont          gds               50
#via        ndfCont          gds               50
#via        polyCont         gds               50
metal      metal1           gds               61
via        via1             gds               70
metal      metal2           gds               62
via        via2             gds               71
metal      metal3           gds               63
via        via3             gds               72
metal      metal4           gds               64
via        via4             gds               73
metal      metal5           gds               65
via        via5             gds               74
metal      metal6           gds               66
via        via6             gds               75
metal      metal7           gds               67
via        via7             gds               121
metal      metal8           gds               120
via        via8             gds               123
metal      metal9           gds               122
via        PA               gds               80
metal      alpa_inter       gds               83
有哪位大佬能帮忙看下这个map是否ok?
另外个人有一个疑问, qrc的tech file中有3个contact 层:polyCont pdfCont ndfCont,但是在virtuoso那边的stream文件中只有layer 50(CT)对应.
这个时候没法ndfCont  和 polyCont 也map 到50,这会不会有问题?
GMT+8, 2025-12-26 00:54 , Processed in 0.011121 second(s), 4 queries , Gzip On, Redis On.
