查看: 1555|回复: 5
[求助] innovus 启动失败
发表于 2024-5-28 16:56:24 | 显示全部楼层 |阅读模式
悬赏20资产未解决
有没有大佬看看,这是怎么回事啊,终端打不开innovus,打开后就闪退
 楼主| 发表于 2024-5-28 17:35:18 | 显示全部楼层
发表于 2024-5-28 16:59:25 | 显示全部楼层
Which version do you use ?  innovus_21.18 ? ddi_23.10
发表于 2024-5-28 17:06:04 | 显示全部楼层
Please find below command on your intall directory , and it run it.
It will show your OS library status.
The report will be PASS or FAIL  for each Lib install status on your system.
install_path/innovus_21.18.000/tools/bin/checkSysConf
install_path/ddi_23.10/INNOVUS231/bin/checkSysConf
 楼主| 发表于 2024-5-28 17:37:45 | 显示全部楼层
It will show your OS library sta ...
can you look it again,i uploaded pictures!
发表于 2024-5-28 19:04:03 | 显示全部楼层
Are you running version 16.24 on a Red Hat 5 system? Is that correct?
Please run the following command to check the PASS/FAIL status. There must not be any FAILs in any of the items.
INNOVUS_INSTALL_PATH/tools/bin/checkSysConf
GMT+8, 2025-9-16 19:58 , Processed in 0.017928 second(s), 7 queries , Gzip On, Redis On.
