查看: 1256|回复: 2
[求助] 华大九天aether版图drc报错
发表于 2024-5-9 17:20:57 | 显示全部楼层 |阅读模式
求助大佬这个怎么解决:Minimum dimension of an NW region not connected to the most
positive power supply is 2.10um.
Need to be changed depending on your power supply name
In this case the most positive voltage
新人上路,是完全不懂
发表于 2024-11-9 09:48:53 | 显示全部楼层
问题解决了吗,大哥
发表于 2025-3-22 10:43:07 | 显示全部楼层
用NW图层再画一个大一点的范围试试
GMT+8, 2025-11-4 01:53 , Processed in 0.015631 second(s), 6 queries , Gzip On, Redis On.
