查看: 49050|回复: 301
Analog Circuit Design and Signal Processing (Papers of Sansen Group)
发表于 2008-2-16 00:33:54 | 显示全部楼层 |阅读模式
All the papers are Sansen-related, most authors from KU Leuven Univ.
List of Papers about ADC/DAC:
“The CMOS Inverter” as a Comparator in ADC Designs
1V All-MOS ΣΔ A/D Converters in the Log-domain
1.1V Low-Power ΣΔ Modulator for 14-bit, 16 KHz A/D Conversion Using a New Low-Voltage Class-AB Op-amp
A 1V Second Order Sigma-Delta Modulator
A 1.5V 12-bit 16 MSPS CMOS Pipelined ADC with 68 dB Dynamic Range
A 1.8V 15-bit 1 mW 2nd-Order Sigma-Delta Modulator
A 1.8V tri-mode ΣΔ modulator for GSM WCDMA WLAN wireless receiver
A 1.8-V 91-dB DR second-order ΣΔ modulator in 0.18-μm CMOS technology
A 10-bit 200-MHz CMOS video DAC for HDTV applications
A 12-b, 150 MHz Sample/s CMOS Current Steering D/A Converter with Gradient Error Compensation
A 14-bit Current-Steering DAC with Current-Mode Deglitcher
A Fast Settling HBT Reference Amplifier for High Speed Digital-to-Analog Converters
A Fully Integrated Current-Steering 10-b CMOS D/A Converter with a Self-Calibrated Current Bias Circuit
A Low Voltage 14-Bit Self-Calibrated CMOS DAC with Enhanced Dynamic Linearity
A low-power sigma-delta modulator for wireless communication receivers using adaptive biasing circuitry and cascaded comparator scheme
A Reduced Delay Method for Improving the Performance of Sigma-Delta Analog-to-Digital Converters (ADC)
A Sub-1V Fourth-Order Bandpass Delta-Sigma Modulator
An 8-Bit 50-MS/s CMOS Digital-Analog Converter
An Accurate Statistical Yield Model for CMOS Current-Steering D/A Converters
Analysis of Manufacturability Factors for Analog CMOS ADC Building Blocks
Design of Semi-Uniform Quantizers and Their Application in Sigma Delta A/D Converters
Digital Window Comparator DfT Scheme for Mixed-Signal ICs
Nonlinear Quantization in Low Oversampling Ratio Sigma-Delta Noise Shapers for RF Applications
Overcoming Test Setup Limitations by Applying Model-Based Testing to High-Precision ADCs
Platform-based mixed signal design: Optimizing a high-performance pipelined ADC
Polynomial Behavioural Modelling of Switched Capacitor Amplifiers
Quantization Error Analysis of Second Order Bandpass Delta-Sigma Modulator with Sinusoidal Inputs
Stability Analysis of ΔΣ Modulators Using Wavelets
The Impact of Statistical Design on the Area of High Performance CMOS Current-Steering D/A Converters
[ 本帖最后由 eBookMania 于 2008-2-16 00:37 编辑 ]
ADC DAC.part1.rar
3.81 MB, 下载次数: 559 , 下载积分: 资产 -2 信元, 下载支出 2 信元
ADC DAC.part2.rar
3.81 MB, 下载次数: 513 , 下载积分: 资产 -2 信元, 下载支出 2 信元
ADC DAC.part3.rar
3.09 MB, 下载次数: 498 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-2-16 00:40:53 | 显示全部楼层
List of Papers about Filters & Conveyers & Amplifiers:
A Current Conveyor based Field Programmable Analog Array
A low-distortion CMOS IF VGA with linear-in-dB control and temperature compensation
A New CMOS Programmable Balanced Output Transconductor and Application to a Mixed Mode Universal Filter Suitable for VLSI
An 8.25-MHz 7th-Order Bessel Filter Built with Single-Amplifier Biquadratic MOSFET–C Filters
CMOS Power-Efficient Buffers and Amplifiers
Continuous-Time 4th Order Butterworth Low-Pass Filter for Video Frequency Applications
Design of Current-Mode Square-Root Domain Band-Pass Filter with Reduced Voltage
Design of low noise charge amplifier in sub-micron technology for fast shaping time
Noise Determination in Differential Pair-Based Second Generation Current Conveyors
Filters & Conveyers & Amplifiers.rar
3.23 MB, 下载次数: 502 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-2-16 00:43:30 | 显示全部楼层
List of Papers about Op Amps:
A Common Mode Feedback Structure for Differential OpAmps Using NMOS Depletion Transistors
A Low Distortion Wide Tuning Range CMOS Fully-Differential Fourth-Order Bessel Filter
A low-power, second-order ΔΣ modulator using a single class-AB op-amp for voice-band applications
A Low-Voltage Fully Differential Constant-Gm Rail-to-Rail CMOS Operational Amplifier
A novel feed-forward compensation technique for single-stage fully-differential CMOS folded cascode rail-to-rail amplifier
A Novel Method for Bandwidth and Phase Margin Enhancement of Folded-Cascode Amplifier
A Switched Opamp-Based Bandpass Filter - Design and Implementation in a 0.35 μm CMOS Technology
A Very High-Speed BiCMOS Replicating Current Comparator for Use in Viterbi Decoders
An Adaptive Biased Single-Stage CMOS Operational Amplifier with a Novel Rail-to-Rail Constant-gm Input Stage
Analysis of the Effect of Radio Frequency Interference on the DC Performance of CMOS Operational Amplifiers
Class AB Output Stages for Low Voltage CMOS Opamps with Accurate Quiescent Current Control by Means of Dynamic Biasing
Common-Mode Response Overlapping vs. Shaping in Rail-to-Rail Op-Amp Input Stages
Design Procedure for Two-Stage CMOS Transconductance Operational Amplifiers: A Tutorial
Domino Free 4-Path Time-Interleaved Second Order Sigma-Delta Modulator
High-Gain Class-AB OTA with Low Quiescent Current
Input/Output Rail-to-Rail CMOS Operational Amplifier with Shaped Common-Mode Response
Low Distortion and Swing Suppression Sigma-Delta Modulator with Extended Dynamic Range Scheme
Low Voltage CMOS Power Amplifier with Rail-to-Rail Input and Output
Low-Power Adaptive Biased Integrated Amplifiers
Opamp gain insensitive MASH sigma delta modulator for wide bandwidth applications
Optimizing Drain Current, Inversion Level, and Channel Length in Analog CMOS Design
Some Design Aspects of a Two-Stage Rail-to-Rail CMOS Op Amp
Techniques for evaluating harmonic distortion in class-AB output stages: A tutorial
[ 本帖最后由 eBookMania 于 2008-2-16 00:47 编辑 ]
Op Amp.part1.rar
3.81 MB, 下载次数: 608 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Op Amp.part2.rar
3.81 MB, 下载次数: 2611 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Op Amp.part3.rar
2.9 MB, 下载次数: 2542 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-2-16 00:50:16 | 显示全部楼层
List of Papers about Radio Frequency:
2.45-GHz-CMOS temperature compensated multi-controlled oscillator for IEEE 802.15 wireless PAN
A 2.5 V, 10 GHz Fully Integrated LC-VCO with Integrated High-Q Inductor and 30% Tuning Range
A 100 MHz to 1 GHz Variable Gain Amplifier in a 8 GHz 1.2 μm BiCMOS Process
Juha Hakkinen, Timo Rahkonen, Juha Kostamovaara
A Broadband Double-Conversion RF Tuner
A CMOS VCO Architecture Suitable for Sub-1 Volt High-Frequency (8.7–10 GHz) RF Applications
A New Low Voltage CMOS Transconductor for VHF Filtering Applications
A Single-Chip CMOS Transceiver Front-End for DCS-1800 Wireless Communications
Low-noise monolithic amplifier design: Bipolar versus CMOS
Low-Voltage BiCMOS Four-Quadrant Multiplier and Squarer
Optimizing the Dimensions of Driver and Power Transistor in Switching CMOS RF Amplifiers
Theory of PLL fractional-N frequency synthesizers
[ 本帖最后由 eBookMania 于 2008-2-16 01:01 编辑 ]
RF.part1.rar
3.81 MB, 下载次数: 352 , 下载积分: 资产 -2 信元, 下载支出 2 信元
RF.part2.rar
952.73 KB, 下载次数: 298 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-2-16 00:53:39 | 显示全部楼层
List of Papers on other subjects like simulation, modeling, sensors and design techniques etc.:
A digital calibration algorithm for implementing accurate on-chip resistors
A Fully Integrated, Low Noise and Low Power BiCMOS Front-end Readout System for Capacitive Detectors
A high precision temperature control system for CMOS integrated wide range resistive gas sensors
A High Voltage Line Driver for Subscriber Loop Interfaces in a Low Voltage Submicron BiCMOS Technology
A Simulator Independent Semiconductor Model Implementation Based on SPICE Model Equations
Adaptable Interface Circuits for Flexible Monitoring of Temperature and Movement
Aladin: A Layout Synthesys Tool for Analog Integrated Circuits
An Integrated CAD Methodology for Yield Enhancement of VLSI CMOS Circuits Including Statistical Device Variations
Analog VLSI Design Constraints of Programmable Cellular Neural Networks
ARIADNE: A constraint-based approach to computer-aided synthesis and modeling of Analog integrated circuits
Current Mode, Voltage Mode, or Free Mode? A Few Sage Suggestions
Design optimisation of planar electrolytic conductivity sensors
di/dt Noise in CMOS Integrated Circuits
Generalized Simulation-Based Posynomial Model Generation for Analog Integrated Circuits
Integrated Global System Model for Climate Policy Assessment - Feedbacks and Sensitivity Studies
Low-Voltage CMOS Log-Companding Techniques for Audio Applications
Low-Voltage Low-Power Integrated Phase-Shifter as Resistive Sensor Transducer
Mismatch Characterization of Submicron MOS Transistors
MOST-Based Design and Scaling of Synaptic Interconnections in VLSI Analog Array Processing CNN Chips
Regression Criteria and Their Application in Different Modeling Cases
Reliable Circuit Techniques for Low-Voltage Analog Design in Deep Submicron Standard CMOS: A Tutorial
Robust Design of Basic Low Voltage CMOS Transconductors
Synthesis of a Wireless Communication Analog Back-End Based on a Mismatch-Aware Symbolic Approach
Using top-down CAD tools for mixed analog digital ASICs: a practical design case
[ 本帖最后由 eBookMania 于 2008-2-16 00:59 编辑 ]
Other Subjects.part1.rar
3.81 MB, 下载次数: 1757 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Other Subjects.part2.rar
3.81 MB, 下载次数: 2210 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Other Subjects.part3.rar
3.81 MB, 下载次数: 2225 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Other Subjects.part4.rar
2.03 MB, 下载次数: 332 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-2-16 04:22:03 | 显示全部楼层
Really good stuff for researcher or industry people.
发表于 2008-2-16 13:42:33 | 显示全部楼层
不错不错,谢谢分享
发表于 2008-2-17 21:34:22 | 显示全部楼层
挺好的,可惜全是paper要是合成一本书就好了
发表于 2008-2-17 21:37:04 | 显示全部楼层
路过路过路过
发表于 2008-2-18 19:27:05 | 显示全部楼层
xiexie
GMT+8, 2025-12-30 02:23 , Processed in 0.029068 second(s), 7 queries , Gzip On, Redis On.
