查看: 15507|回复: 53
Low-Voltage Class AB Buffers with Quiescent Current Control
发表于 2008-2-15 19:53:50 | 显示全部楼层 |阅读模式
一个不错的 AB类buffer
1998_4.pdf
140.11 KB, 下载次数: 635 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-2-27 16:28:26 | 显示全部楼层
不错.
发表于 2008-2-27 19:43:56 | 显示全部楼层
XieXie!!
发表于 2008-3-9 15:32:12 | 显示全部楼层
感谢楼主,谢谢分享
发表于 2008-3-9 15:38:34 | 显示全部楼层
IEEE JOURNAL OF SOLID-STATE CIRCUITS, VOL. 33, NO. 6, JUNE 1998
Fan You, S. H. K. Embabi, and Edgar S´anchez-Sinencio
发表于 2008-3-9 15:39:58 | 显示全部楼层
Abstract—This paper presents a simple class AB buffer which
is suitable for low-voltage (1.5 V) applications. The proposed
buffer uses an adaptive load to reduce the sensitivity of the
quiescent current to the process variation. The main feature of
this scheme is its simplicity. The circuit was fabricated in a 2.0
m digital CMOS process. Experimental results demonstrate that
the buffer can operate with a supply voltage below 2 V, and it
has the capability to drive small resistive loads.
发表于 2008-3-9 15:49:07 | 显示全部楼层
thanks!
发表于 2008-8-17 16:29:17 | 显示全部楼层
hao  hao  ,ding
发表于 2008-9-28 12:48:39 | 显示全部楼层
发表于 2008-10-16 15:24:26 | 显示全部楼层
good enouf
GMT+8, 2025-12-23 11:13 , Processed in 0.019442 second(s), 4 queries , Gzip On, Redis On.
