查看: 1837|回复: 1
[求助] ISSCC中电荷泵电路
发表于 2024-4-26 17:23:40 | 显示全部楼层 |阅读模式
原文
To keep a large dynamic range, 18 CP unitslices are used in parallel to deliver large current required to keep noise low. Areplica bias is used to ensure that up and down currents are matched within <1%over the CP dynamic range. It is sized 4× of the CP unit cell to ensure bettermatching and lower noise.
这里不是很懂为什么前面×4后面×18就实现了低噪声,这里和直接最普通的有什么区别吗?
原文电路
原文电路
 楼主| 发表于 2024-4-26 17:24:48 | 显示全部楼层
A_7.4-to-14GHz_PLL_with_54fsrms_jitter_in_16nm_FinFET_for_integrated_RF-data-con.pdf (589.42 KB , 下载次数: 37 )
附上原文
GMT+8, 2025-12-26 09:12 , Processed in 0.013577 second(s), 5 queries , Gzip On, Redis On.
