查看: 2277|回复: 5
[原创] help download a paper about zoom adc, thanks a lot
发表于 2024-4-22 21:12:06 | 显示全部楼层 |阅读模式
https://ieeexplore.ieee.org/document/10143977
A Sub-1μW 16-Bit Fully Dynamic Zoom ADC Compatible With Free-Running and Incremental Modes Using Residue Feedforward and Extended Counting TechniquesPublisher: IEEE
[url=]PDF[/url]
Yuyan Liu; Xinjie Wu; Xiaopeng Yu; Junjie Hung; Ling Lin; Pengpeng Chen; Nianxiong Nick Tan
School of Micro-Nano Electronics, Zhejiang University, Hangzhou, China,Department of Analog Circuit Design, Vango Technologies, Inc., Hangzhou, China
[url=]A[/url]
Abstract:This brief proposes a fully dynamic zoom ADC, which uses the residue feedforward technique to reduce the “fuzz” caused by the coarse SAR ADC’s quantization noise leakage in free running mode, and uses the extended counting technique to obtain the quantization error in incremental mode. The zoom ADC achieves high resolution in both modes. An improved cascoded floating-inverter-amplifier based integrator is used for low power and fully dynamic conversion. Fabricated in a standard 180nm CMOS process, the zoom ADC occupies an active area of 0.204mm2, and consumes less than  1μW  while achieving 102.1dB and 97.6dB SNDR in 95Hz bandwidth (BW) in free-running and incremental modes, respectively, corresponding to 182.2dB and 177.5dB FoMSNDR.
Published in: IEEE Transactions on Circuits and Systems II: Express Briefs ( Volume: 71, Issue: 2, February 2024)
Page(s): 522 - 526
Date of Publication: 05 June 2023
ISSN Information:
DOI: 10.1109/TCSII.2023.3282650
Publisher: IEEE
发表于 2024-7-15 10:46:21 | 显示全部楼层
希望能帮到您
A_Sub-1W_16-Bit_Fully_Dynamic_Zoom_ADC_Compatible_With_Free-Running_and_Incremen.pdf
4.6 MB, 下载次数: 15 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2024-7-15 16:27:13 | 显示全部楼层
rym 发表于 2024-7-15 10:46
希望能帮到您
Thanks a lot.
发表于 2024-9-20 09:07:42 | 显示全部楼层
kan kan
发表于 2025-8-13 19:57:21 | 显示全部楼层
Thanks for sharing
发表于 2025-8-13 20:25:37 | 显示全部楼层
Thanks for sharing
GMT+8, 2025-12-21 10:36 , Processed in 0.016312 second(s), 4 queries , Gzip On, Redis On.
