查看: 1967|回复: 5
[求助] 小白仿真smic18mmrf的版图,lvs通过,xrc出现问题
发表于 2024-4-15 18:50:44 | 显示全部楼层 |阅读模式
"clean cellmap files"
NOTE: Creating CalibreView for cell inv ...
WARNING: Schematic instance D0_noxref not found.
INFO (SCH-1170): Extracting "inv calibre_gate_3"
Warning: Pin "MINUS" on instance "D0_noxref": floating input/output.
Warning: Pin "PLUS" on instance "D0_noxref": floating input/output.
Warning: Pin "B" on instance "MNM0@2": floating input/output.
Warning: Pin "S" on instance "MNM0@2": floating input/output.
Warning: Pin "G" on instance "MNM0@2": floating input/output.
Warning: Pin "S" on instance "MNM0": floating input/output.
Warning: Pin "B" on instance "MPM0@2": floating input/output.
Warning: Pin "S" on instance "MPM0@2": floating input/output.
Warning: Pin "G" on instance "MPM0@2": floating input/output.
Warning: Pin "D" on instance "MPM0@2": floating input/output.
Warning: Pin "PLUS" on instance "ciVOUT_34": floating input/output.
Warning: Pin "PLUS" on instance "ciVOUT_33": floating input/output.
Warning: Pin "PLUS" on instance "ciVDD_11": floating input/output.
Warning: Pin "PLUS" on instance "ciVDD_8": floating input/output.
Warning: Pin "PLUS" on instance "ciGND_12": floating input/output.
Warning: Pin "PLUS" on instance "ciGND_9": floating input/output.
Warning: Pin "VDD": floating input/output.
Warning: Floating net "D0_noxref_neg" at (-6.0000, 4.7500).
Warning: Floating net "D0_noxref_pos" at (-6.0000, 5.1250).
Warning: Floating net "VOUT_8" at (-5.9375, -24.8125).
Warning: Floating net "GND_44" at (-5.9375, -10.9375).
Warning: Floating net "VOUT_5" at (-4.1250, -25.7500).
Warning: Floating net "MNM0_s" at (-3.4375, 1.1250).
Warning: Floating net "MNM0@2_g" at (-2.9375, 1.3125).
Warning: Floating net "MPM0@2_g" at (-2.9375, 7.0000).
Warning: Floating net "MNM0@2_s" at (-2.6875, 1.1250).
Warning: Floating net "MNM0@2_b" at (-2.6875, 1.3125).
Warning: Floating net "MPM0@2_d" at (-2.6875, 6.8125).
Warning: Floating net "MPM0@2_b" at (-2.6875, 7.0000).
Warning: Floating net "MPM0@2_s" at (-2.6875, 7.1875).
Warning: Floating net "GND_33" at (-0.3750, -13.7500).
Warning: Floating net "VDD_60" at (3.3125, -15.5625).
Warning: Floating net "VDD_46" at (8.8750, -18.3750).
Calibre View generation completed with 1 WARNINGs and 0 ERRORs.
Please consult the CIW transcript for messages.
只有xrc爆一堆警告,这个工艺库里面没有lvs_xrc文件.
pex仿真设置中rule用的.lvs文件,include了.R 和.C的规则文件
xrc仿真设置如图
发表于 2024-4-15 18:54:50 | 显示全部楼层
hcell和xcell加了吗?
 楼主| 发表于 2024-4-21 15:35:48 | 显示全部楼层
加了h-cells和x-cells
发表于 2024-9-28 14:00:04 | 显示全部楼层
楼主,解决了吗?
发表于 2024-10-17 15:44:57 | 显示全部楼层
lvs文件里面有开关,调一下,跑xrc
发表于 2025-11-10 21:25:20 | 显示全部楼层
楼主解决了吗,我又碰到了
GMT+8, 2025-12-18 16:45 , Processed in 0.017276 second(s), 4 queries , Gzip On, Redis On.
