查看: 2106|回复: 2
[求助] PSS报错:Newton iteration fails to converge
发表于 2024-4-15 16:47:33 | 显示全部楼层 |阅读模式
Newton iteration fails to converge at time = 156.488 fs step = 20e-21 s. Disaster recovery algorithm is enabled to search for a converged solution.
PSS报错:Newton iteration fails to converge ,不知道是什么原因?求解!
发表于 2024-4-15 17:41:08 | 显示全部楼层
newton raphson 迭代方程不收敛,你需要检查一下电路,看看有没有阻抗特点大的点,如开路,或者电容特别大的点,或者短路点,这些都容易导致不收敛
 楼主| 发表于 2024-4-15 17:52:55 | 显示全部楼层
phoenixson 发表于 2024-4-15 17:41
newton raphson 迭代方程不收敛,你需要检查一下电路,看看有没有阻抗特点大的点,如开路,或者电容特别大 ...
谢谢!
GMT+8, 2025-12-20 00:27 , Processed in 0.015685 second(s), 4 queries , Gzip On, Redis On.
