查看: 2296|回复: 9
[求助] 求助:virtuoso菜单栏中place的custom digital功能怎么使用?
发表于 2024-4-12 10:57:03 | 显示全部楼层 |阅读模式
悬赏100资产已解决
如题(在给定一个原理图,有XL关系的情况下)
谢谢大佬,膜拜大佬,向大佬学习
求助内容
求助内容
公司脚本出图
公司脚本出图
公司脚本出图1
公司脚本出图1
最佳答案
查看完整内容
The purpose of this document is to help users get familiar with a standard cell Place and Route (P&R) flow using VCP and new ART. The document shows the functionality of the new ART standard cell router, which seamlessly integrates the NanoRoute router into the Virtuoso design environment. The test case is a GPDK (cds_ff_mpt) standard cell design. It will start with a schematic and generate the ...
发表于 2024-4-12 10:57:04 | 显示全部楼层
cell design.
It will start with a schematic and generate the layout from the source. Then, it will import
IO pins and boundary information from an existing layout as if it were done with the
Design Planner and Analysis tool. It will step through creating an interoperable row
region, which is compatible with Innovus, and then, it will do the power routing, followed
by placement of tap cells and standard cells.
It shows different ways to generate WSPs as well as routes without them, relying on
Innovus-created tracks. At that point, the design will be ready for routing, which is the
focus of the RAK.
It will also introduce GigaPlace integration through a SKILL API.
You may use this as an example to learn about the router and run further tests
(minimum prerequisite is RMSOA PDK and preferably abstracts).
Audience
This document is intended for circuit and layout designers using advanced-node PDKs
for their designs, as well as for CAD teams that support such design flows.
下面是文档中的图:
ART_StdCell_RAK_cds_ff_mpt.pdf (7.48 MB , 下载次数: 62 )
ART_stdcell_RAK_cds_ff_mpt_05_01_2022.tar.gz (5.54 MB , 下载次数: 32 )
发表于 2024-4-12 11:05:11 | 显示全部楼层
求你们公司这个脚本
发表于 2024-4-12 11:08:18 | 显示全部楼层
同求脚本,可有偿
 楼主| 发表于 2024-4-12 11:26:17 | 显示全部楼层
fengrlove 发表于 2024-4-12 11:05
求你们公司这个脚本
啊我没有所有权,所以我想研究手动的方法
 楼主| 发表于 2024-4-12 11:27:49 | 显示全部楼层
wanchengchen 发表于 2024-4-12 11:08
同求脚本,可有偿
抱歉,我没有所有权,所以我在研究手动的方法
 楼主| 发表于 2024-4-12 11:47:06 | 显示全部楼层
有大佬知道吗,这几个功能
发表于 2024-4-12 13:26:01 | 显示全部楼层
Route (P ...
谢谢分享
 楼主| 发表于 2024-4-12 14:30:02 | 显示全部楼层
Route (P ...
非常感谢!
发表于 2024-4-12 16:57:21 | 显示全部楼层
thanks
GMT+8, 2026-1-31 13:02 , Processed in 0.221279 second(s), 6 queries , Gzip On, Redis On.
