查看: 1518|回复: 2
[求助] DC不收敛
发表于 2024-4-11 21:00:58 | 显示全部楼层 |阅读模式
ERROR(SPECTRE-16385): There were 8 attempts to find the Dc solution.In some of those attempts,a signal exceeded the blowup limit of its quantity,The last signal that failed is V(PM2.d1)=1.21214 GV, for which the quantity is 'V' and the blowup limit is(1GV),It is possible that the circuit has no Dc solution. If you really want signals this large,set the blowup'parameter of this quantity to a larger value
发表于 2024-5-12 03:11:12 | 显示全部楼层
电压太大了。信号太大或太小,有导线断点,这些有可能导致不收敛。
发表于 2024-5-14 11:02:44 | 显示全部楼层
感谢
GMT+8, 2025-12-26 06:34 , Processed in 0.088533 second(s), 4 queries , Gzip On, Redis On.
