查看: 1344|回复: 1
[求助] cadense仿真错误
发表于 2024-4-11 20:54:47 | 显示全部楼层 |阅读模式
WARNING(ASL-6246):"Internal(bsource)"0:NM5.vccs_grth1:A domain error occurred while calculating pow(x,y) for real numbers because a negative value -5.515574 has been specified for x and the value -1.400000 specified for y is not an exact integer. Therefore, the function has returned the value 0.0.
发表于 2025-8-27 18:17:47 | 显示全部楼层
dc仿真时候是不是开了aps?如果开了aps的话关掉就好,使用spectre mode。在这个点时候电路里应该某个节点存在跳变,开aps的话会导致不收敛。
GMT+8, 2025-10-21 13:50 , Processed in 0.017674 second(s), 3 queries , Gzip On, Redis On.
