ISSCC2024 session10 频率综合器 论文集
供学习交流
10.1: An 8.75GHz Fractional-N Digital PLL with a Reverse-Concavity Variable-Slope DTC Achieving 57.3fsrms Integrated Jitter and -252.4dB FoM
10.2: A 5.5μs-Calibration-Time, Low-Jitter, and Compact-Area Fractional-N Digital PLL Using the Recursive-Least-Squares (RLS) Algorithm
10.3: A 7GHz Digital PLL with Cascaded Fractional Divider and Pseudo-Differential DTC Achieving -62.1dBc Fractional Spurand 143.7fs Integrated Jitter
10.4: A 45.5fs-Integrated-Random-Jitter and -75dBc-Integer-Boundary-Spur BiCMOS Fractional-N PLL with Suppression of Fractional, Horn, and Wandering Spurs
10.5: A 76fsrms-Jitter and −65dBc-Fractional-Spur Fractional-N Sampling PLL Using a Nonlinearity-Replication Technique
10.6: A 10GHz FMCW Modulator Achieving 680MHz/μs Chirp Slope and 150kHz rms Frequency Error Based on a Digital-PLL with a Non-Uniform Piecewise-Parabolic Digital Predistortion
10.7: An 11GHz 2nd-order DPD FMCW Chirp Generator with 0.051% rms Frequency Error under a 2.3GHz Chirp Bandwidth, 2.3GHz/μs Slope, and 50ns Idle Time in 65nm CMOS
10.8: A 281GHz, −1.5dBm Output-Power CMOS Signal Source Adopting a 46fsrms Jitter D-Band Cascaded Subharmonically Injection-Locked Sub-Sampling PLL with a 274MHz Reference
10.9: A 23.2-to-26GHz Sub-Sampling PLL Achieving 48.3fsrms Jitter, −253.5dB FoMJ, and 0.55μs Locking Time Based on a Function-Reused VCO-Buffer and a Type-I FLL with Rapid Phase Alignment
ISSCC2024-频率综合器.pdf
2.88 MB, 下载次数: 17
, 下载积分:
资产 -2 信元, 下载支出 2 信元
ISSCC2024 session10 Frequency Synthesis
