查看: 1400|回复: 5
[求助] 急求!!DC打不开
发表于 2024-3-31 14:47:34 | 显示全部楼层 |阅读模式
安装DC虚拟机的时候,无法打开design compiler和design vision,报错如下,想问问各位大神怎么解决啊?(试了论坛里面的一些方法,好像不好使?)
[   @localhost Desktop]$ lmli2
[   @localhost Desktop]$ dc_shell
Fatal: Design Compiler is not enabled. (DCSH-1)
[   @localhost Desktop]$ design_vision
Unable to obtain feature 'Design-Vision ' because:
Error: Cannot open key file '/eda/synopsys/dc2013/admin/license/key' or a licensing environment parameter has not been set correctly. (SEC-2)
Unable to obtain feature 'Design-Analyzer ' because:
Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer. (DCSH-10)
发表于 2024-3-31 16:32:07 | 显示全部楼层
没启动license
发表于 2024-3-31 18:45:22 | 显示全部楼层
dc2013太老了,换新版本吧。
 楼主| 发表于 2024-3-31 19:03:36 | 显示全部楼层
FrozenlipX 发表于 2024-3-31 16:32
没启动license
怎么启动license呀?lmgrd命令吗
发表于 2024-4-1 09:46:41 | 显示全部楼层
有一个正确的license file, 然后用lmgrd启动
 楼主| 发表于 2024-4-4 10:04:10 | 显示全部楼层
谢谢楼上!最后没尝试用lmgrd,很奇怪,换了台电脑重装虚拟机反而好了
GMT+8, 2025-12-26 08:17 , Processed in 0.014207 second(s), 3 queries , Gzip On, Redis On.
