查看: 813|回复: 1
[讨论] Successes Criteria for Safe ESD Operation Window
发表于 2024-3-15 10:58:56 | 显示全部楼层 |阅读模式
It2 should be at least 115% of ESD Current Specified Target.
Voltage drop of the ESD protection circuit, at the min ESD specified current target, should be lower by at least 15% below the minimum Breakdown/Rel. voltage of internal circuit devices.
Vt1 of ESD Protection should be at least 15% below the minimum Breakdown/Rel. voltage of internal circuit devices.
In case of Supply PAD, VH should be at least 15% higher than VDD or it1 should be at least 15% higher than injection current of Latch-up spec (usually 100mA)
发表于 2024-3-15 20:51:29 | 显示全部楼层
thanks1
GMT+8, 2025-10-11 03:47 , Processed in 0.039217 second(s), 3 queries , Gzip On, Redis On.
