查看: 4165|回复: 4
[资料] 模数转换器 SIG7799 国产平替 AD7799
发表于 2024-1-23 15:47:22 | 显示全部楼层 |阅读模式
信格勒微电子的芯片产品已通过行业头部大厂导入验证,深受百万终端客户好评。
而且因为 fully compatible. 板子拿来,换个芯片,性能更好MCU不用改 c code。
SIG7798/SIG7799
4.17SPS to 890SPS ADC with PGA and Reference
Compatible Parts
AD7798/AD7799 pin/register fully compatible (10nV/℃ and 3ppm/℃).
Features
  • Programmable Gain: 1/2/4/8/16/32/64/128
  • Data Rates: 4.17SPS to 890SPS
  • RMS Noises: 20nV at 4.17SPS (Gain = 128)
  • 23.2ENOB (21.0 noise-free bits) at 4.17SPS (Gain= 1)
  • Offset Drift: 5nV/℃ (Gain = 128)
  • Gain Drift: 1ppm/℃
  • Integral Non-linearity: 3ppm
  • internal reference: 4ppm/℃
  • Reference input current: 1uA
  • Simultaneous 50Hz/60Hz Rejection
  • 4 Differential Inputs
  • Current: 0.5mA
  • Specified Temperature Range: -40℃ to 125℃
  • Package: 16-ld TSSOP
  • Power Supply
    AVDD:
    2.7V to 5.25V
    DVDD:
    2.7V to 5.25V
Applications
  • Weight Scales and Strain Gauges
  • Flow/Pressure Measurement
  • Temperature Measurement
  • Industrial Process Control
  • Medical Instrumentation
 楼主| 发表于 2024-5-13 10:15:53 | 显示全部楼层
模数转换器 SIG7193 国产平替 AD7193,性能更佳。MCU 不用改 c code。
SIG7193
4.7SPS to 4.8kSPS24-bit ADC with PGA gain 1 to 128
Compatible Parts
AD7193 pin/register fully compatible.
Features
  • Data Rates: 4.7SPS to 4.8kSPS
  • RMS Noises: 15nV at 10SPS (Gain = 128)
  • 24.4ENOB (22.0 noise-free bits) at 10SPS (Gain= 1)
  • Offset Drift: 3nV/℃ (Gain = 128)
  • Gain Drift: 0.5ppm/℃
  • Reference input current: 500nA
  • Internal or External Clock
  • 2 Differential/4 Pseudo Differential Inputs
  • Power Supply
    AVDD:
    2.7V to 5.25V or ±2.5V
    DVDD:
    2.7V to 5.25V
  • Package: 28-ld TSSOP
  • Current: 2.7mA
 楼主| 发表于 2024-5-13 10:17:52 | 显示全部楼层
模数转换器 SIG5530 国产平替 CS5530,性能更佳。MCU 不用改 c code。
SIG5530
1.6SPS to 3840SPS 24-bit ADC with PGA Gain=64
Compatible Parts
CS5530 pin/register fully compatible (10nV/℃ and 2ppm/℃ ).
Features
  • Programmable Gain: 64
  • Data Rates: 1.6SPS to 3840SPS
  • RMS Noises: 16nV at 7.5SPS (Gain = 64)
  • Offset Drift: 5nV/℃ (Gain = 64)
  • Reference input current: 250nA
  • Internal Reference: 5ppm/℃
  • SINC3/SINC1 Filter Option
  • 2 Differential Inputs
  • Current: 4.0mA
  • Package: 20-ld TSSOP
  • Power Supply
AVDD: 4.75V to 5.25V or ±2.5V
DVDD: 2.7V to 5.25V
 楼主| 发表于 2024-1-23 15:48:58 | 显示全部楼层
平替ADI芯片
SIG7190 平替 AD7190
SIG7192 平替 AD7192
SIG7193 平替 AD7193
平替Cirrus Logic芯片
SIG5532B 平替 CS5532BS(32-bit)
SIG5534B 平替 CS5534BS(32-bit)
SIG5532A 平替 CS5532AS(24-bit)
SIG5534A 平替 CS5534AS(24-bit)
SIG5530 平替 CS5530 (24-bit)
SIG5530B 平替 CS5530(32-bit)
平替ADI芯片
SIG7792 平替 AD7792
SIG7793 平替 AD7793
SIG7794 平替 AD7794
SIG7795 平替 AD7795
SIG7796 平替 AD7796
SIG7797 平替 AD7797
SIG7798 平替 AD7798
SIG7799 平替 AD7799
平替TI芯片
SIG1230A 平替 ADS1230 (20-bit)
SIG1232A 平替 ADS1232 (24-bit)
发表于 2024-9-5 01:23:42 | 显示全部楼层
感谢分享
GMT+8, 2025-10-4 11:32 , Processed in 0.016299 second(s), 5 queries , Gzip On, Redis On.
