查看: 2754|回复: 5
[资料] 国产平替 16/20/24/32-bit 高精度 Σ-Δ 模数转换器芯片
发表于 2024-1-18 15:46:15 | 显示全部楼层 |阅读模式
信格勒微电子的芯片产品已通过行业头部大厂导入验证,深受百万终端客户好评。
而且因为 fully compatible. 板子拿来,换个芯片,性能更佳。MCU不用改 c code。
平替ADI芯片
SIG7190 平替 AD7190
SIG7192 平替 AD7192
SIG7193 平替 AD7193
平替Cirrus Logic芯片
SIG5532B 平替 CS5532BS(32-bit)
SIG5534B 平替 CS5534BS(32-bit)
SIG5532A 平替 CS5532AS(24-bit)
SIG5534A 平替 CS5534AS(24-bit)
SIG5530 平替 CS5530 (24-bit)
SIG5530B 平替 CS5530(32-bit)
平替ADI芯片
SIG7792 平替 AD7792
SIG7793 平替 AD7793
SIG7794 平替 AD7794
SIG7795 平替 AD7795
SIG7796 平替 AD7796
SIG7797 平替 AD7797
SIG7798 平替 AD7798
SIG7799 平替 AD7799
平替TI芯片
SIG1230A 平替 ADS1230 (20-bit)
SIG1232A 平替 ADS1232 (24-bit)
 楼主| 发表于 2024-3-21 11:25:27 | 显示全部楼层
模数转换器 SIG7190 国产平替 AD7190,性能更佳。MCU 不用改 c code。
SIG7190/SIG7192
4.7SPS to 4.8kSPS 24-bit ADC with PGA gain 1 to 128
Compatible Parts
AD7190/AD7192 pin/register fully compatible.
Features
  • Programmable Gain: 1/2/4/8/16/32/64/128
  • Data Rates: 4.7SPS to 4.8kSPS
  • RMS Noises: 15nV at 10SPS (Gain = 128)
  • 24.4ENOB (22.0 noise-free bits) at 10SPS (Gain= 1)
  • Offset Drift: 3nV/℃(Gain = 128)
  • Gain Drift: 0.5ppm/℃
  • Integral Non-linearity: 3ppm
  • Reference input current: 500nA
  • Internal or External Clock
  • Simultaneous 50Hz/60Hz Rejection
  • 2 Differential/4 Pseudo Differential Inputs
  • Current: 2.5mA
  • Specified Temperature Range: -40℃ to 125℃
  • Package: 24-ld TSSOP
  • Power Supply
                  AVDD :2.7V to 5.25V or ±2.5V
                   DVDD : 2.7V to 5.25V
 楼主| 发表于 2024-1-18 15:49:22 | 显示全部楼层
性能更佳
SIG7792/SIG7793
4.17SPS to 890SPS ADC with PGA and Reference
Compatible Parts
AD7792/AD7793 pin/register fully compatible (10nV/℃ and 3ppm/℃).
Features
Data Rates: 4.17SPS to 890SPS
RMS Noises: 20nV at 4.17SPS (Gain = 128)
23.2ENOB (21.0 noise-free bits) at 4.17SPS (Gain= 1)
Offset Drift: 5nV/℃ (Gain = 128)
Gain Drift: 1ppm/℃
internal reference: 4ppm/℃
Reference input current: 1uA
4 Differential Inputs
Current: 0.5mA
Package: 16-ld TSSOP
Power Supply
AVDD: 2.7V to 5.25V
DVDD: 2.7V to 5.25V
Applications
Weight Scales and Strain Gauges
Flow/Pressure Measurement
Temeprature Measurement
Industrial Process Control
Medical Instrumentation
 楼主| 发表于 2024-1-18 15:52:38 | 显示全部楼层
性能更佳
SIG5532B / SIG5534B
1.6SPS to 3840SPS 32-bit ADC with PGA and Reference
Compatible Parts
CS5532BS/CS5534BS pin/register fully compatible (15nV/℃ and 2ppm/℃).
Features
Data Rates: 1.6SPS to 3840SPS
RMS Noises: 11nV at 7.5SPS (Gain = 64)
26.0ENOB (23.4 noise-free bits) at 7.5SPS (Gain= 1)
Offset Drift: 5nV/℃(Gain = 64)
Gain Drift:0.5ppm/℃
Internal Reference: 5ppm/℃
SINC3/SINC1 Filter Option
2/4 Differential Inputs
Current: 5.0mA
Package: 20/24-ld TSSOP
Power Supply
AVDD :4.75V to 5.25V or ±2.5V
Applications
 楼主| 发表于 2024-1-18 15:57:58 | 显示全部楼层
性能更佳
SIG1232A
10/80SPS 24-bit ADC with PGA
Compatible Parts
ADS1232 fully compatible  (10nV/℃ and 2.5ppm/℃).
Features
  • Programmable Gain: 1/2/64/128
  • Data Rates: 10/80SPS
  • RMS Noises: 19nV at 10SPS (Gain = 128)
  • 23.0ENOB (20.9 noise-free bits) at 10SPS (Gain = 1)
  • Offset Drift: 5nV/℃ (Gain = 128)
  • Gain Drift: 1ppm/℃
  • Reference input current: 30nA
  • 2 Differential Inputs
  • Power Supply
    AVDD:
    DVDD:
    2.7V to 5.25V
  • Current: 1.5mA
Applications
  • Weight Scales and Strain Gauges
  • Flow/Pressure Measurement
  • Temperature Measurement
  • Industrial Process Control
  • Medical Instrumentation
发表于 2024-1-18 17:09:31 | 显示全部楼层
不错
GMT+8, 2025-12-21 01:45 , Processed in 0.023346 second(s), 6 queries , Gzip On, Redis On.
