查看: 40662|回复: 152
ASIC Backend Flow using Synopsys Astro
发表于 2008-2-4 16:09:48 | 显示全部楼层 |阅读模式
Seong Chew, Lim
Integrated Circuit Design Services Sdn. Bhd.
seongchew.lim@icdsgroup.com
ABSTRACT
Using Synopsys Astro place n route tool for ASIC physical design flow is presented in this paper. The paper will introduce the Astro methodology flow from synthesized netlist to gds. The paper will cover Design database setup, floorplan, power pre-route, placement, clock tree synthesis, and route phases. This paper will also cover some of the physical design sharing like power pre-route pattern and scripts that being used for physical design and also some introductions on the clock timing. The paper will not cover topics like IR drop, Power Leakage and Cross Talk issues that are critical to the UDSM design.
ASTRO.pdf
219.39 KB, 下载次数: 763 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-2-4 19:18:09 | 显示全部楼层
定,谢谢
发表于 2008-2-9 19:31:09 | 显示全部楼层
謝謝你 太需要這個文見了
发表于 2008-2-15 08:47:05 | 显示全部楼层
Thanks for sharing
发表于 2008-2-26 03:24:24 | 显示全部楼层
Thanks for sharing
发表于 2008-2-26 16:42:33 | 显示全部楼层
TKS!!!!!!!!!!!!!!!!!
发表于 2008-3-1 03:48:59 | 显示全部楼层
ding!
发表于 2008-3-2 21:55:02 | 显示全部楼层
Thanks. Very good information.
发表于 2008-3-5 21:18:20 | 显示全部楼层
先谢过了啊
发表于 2008-3-11 06:49:19 | 显示全部楼层
很小很贵,希望物有所值,先谢谢了
GMT+8, 2025-9-18 12:25 , Processed in 0.018078 second(s), 4 queries , Gzip On, Redis On.
