查看: 1316|回复: 2
[求助] INNOVUS中IMPCK-3173的ERROR怎么办
发表于 2024-1-9 21:37:49 | 显示全部楼层 |阅读模式
求助各位前辈,我在使用INNOVUS时,进行opt就会报错并退出,这是因为我的capTbl不对还是设置不对呢,capTbl是根据ict文件生成的,我使用工艺的金属层为1p6m_5Ia_1tm1,但是smic没有提供对应的ict,我就拿1p6m_5Ia_1mtt2来转的,想着只是小模块,我不要顶层金属应该没区别。log如下:
**ERROR: (IMPCK-3173):        CTS cannot find valid wire capatances for the route type, FE_CTS_DEFAULT. Check the route type definition and capTables.
**ERROR: (IMPCK-1044):        Due to earlier errors, failed to generate consistent RouteType FE_CTS_DEFAULT.
Exiting due to previous error.
 楼主| 发表于 2024-1-9 21:40:20 | 显示全部楼层
顶顶顶顶顶顶顶
 楼主| 发表于 2024-1-10 09:13:05 | 显示全部楼层
顶顶顶顶,有没有前辈指导一下
GMT+8, 2025-12-20 19:28 , Processed in 0.015459 second(s), 3 queries , Gzip On, Redis On.
