查看: 10300|回复: 1
Silvaco 仿真FET输出特性曲线IdVd 报错
发表于 2024-1-2 14:15:27 | 显示全部楼层 |阅读模式
悬赏10资产未解决
Silvaco 仿真JFET,器件结构建立好后运行输出特性曲线仿真,报错如图: *Invalid parameter specification* 请问是哪里有问题?device 电极gate/drain/source 皆有定义,且转移特性曲线IdVg 仿真一切正常
.# Output characteristics_IdVd
go atlas
mesh infile=JFET.str
# model
models mos print
# contact
contact  name=gate workf=4.5
# method
method newton gummel itlimit=25 trap atrap=0.5 maxtrap=4 autonr nrcriterion=0.1 tol.time=5e-3 dt.min=1e-25 damped delta=0.5 damploop=10 dfactor=10.0 iccg lu1cri=3e3 lu2cri=3e2 maxinner=25
# IdVd curve
solve init
solve vgate=-90 vsource=0
log outf=JOut_90.log
solve name=drain vdrian=5 vstep=-1 vfinal=0
tonyplot JOut_90.log
发表于 2024-2-29 16:27:13 | 显示全部楼层
Vdrain
GMT+8, 2025-12-21 01:01 , Processed in 0.014983 second(s), 6 queries , Gzip On, Redis On.
