查看: 2906|回复: 4
[求助] spyglass fatal 求助大佬指教!
发表于 2023-12-26 15:04:39 | 显示全部楼层 |阅读模式
  在使用spyglass batch模式下designread时提示1个FATAL:include file(./xxx.v)could not be found or opened in read mode from current working directory or other include directory paths
  在spyglass文档里找到如下说明:
If set_option incdir is not specified correctly, you will get STX_VE_485 as
STX_VE_485 Syntax …. Include file ( … ) could not be found or opened in read mode from current working directory ( ….. ) or other include directory paths ( if any )
If “included” file name is also included in the sources.f, you might get errors/warnings related to duplicate definitions (depending on what was there in the included file)
但我不知道具体该如何操作,请大佬们不吝赐教!
 楼主| 发表于 2023-12-26 15:30:33 | 显示全部楼层
我在.prj文件里添加了:set_option incdir <inc_dir_path>提示该文件不存在
 楼主| 发表于 2023-12-28 14:00:31 | 显示全部楼层
通过在current working directory下添加include文件已解决
发表于 2023-12-28 14:19:19 | 显示全部楼层
恭喜找到问题
发表于 2024-10-18 15:56:23 | 显示全部楼层
学到了,在shell里set_option incdir <inc_dir_path>  就可以了
GMT+8, 2025-12-18 22:39 , Processed in 0.608177 second(s), 3 queries , Gzip On, Redis On.
